Author Topic: 5600x3d bundle  (Read 4733 times)
Offline Leslieann
Re: 5600x3d bundle
« Reply #1 on: Sun, 12 November 2023, 09:01:29 »
I always hesitate on tech like this.
First off, it's a chip that failed testing for half it's cores, once electronics start to fail it tends to cascade. While this isn't necessarily true on CPUs (and it's how binning works on lower end chips), it's hard for me to change that view. If you;re buying low end, it;s fine but higher end you should just buy higher end.
Second, it's a limited edition chip, not all boards will work with it and as it ages out some could lose support for it as companies get lazy on supporting it and finding replacement boards down the line should you need one or try and resell this chip could very well limit your options or resale value.
Lastly, it's a limited edition chip which can mean less support if there's an issue. Some of this is the same as the previous entry but not entirely. This is a big problem on laptops where companies will focus on fixing mainstream products before fixing high end stuff. While you would think having top of the line means being first in line for fixes/repairs on a major issues, the reality is that companies see it as you're a smaller group and in the case of high end, a group who can afford to just buy a replacement... because f-you. This right here is one reason I soured on Nvidia (and Sony) when they pulled this on me.
That said, it's smoking deal for the money assuming it has none of the above issues and you live near Microcenter.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Re: 5600x3d bundle
« Reply #2 on: Sun, 12 November 2023, 09:04:06 »
Yea, there's really nothing close in terms of performance you can buy for that money.
Re: 5600x3d bundle
« Reply #3 on: Sun, 12 November 2023, 19:28:09 »
Should wait for BF ?
Offline Leslieann
Re: 5600x3d bundle
« Reply #4 on: Mon, 13 November 2023, 04:24:29 »
Maybe, but who's to say the deals will be much better.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Re: 5600x3d bundle
« Reply #5 on: Mon, 13 November 2023, 08:42:08 »
Just a little worried they might run out of 5600x3ds, since it's a limited run.
Offline Leslieann
Re: 5600x3d bundle
« Reply #6 on: Mon, 13 November 2023, 18:44:38 »
It's not a limited run, it's cast-offs.
There will be be more, the question is when and if they will offer them again.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
