Author Topic: Cooking and dat Lung Cancer  (Read 5709 times)
« on: Fri, 06 December 2024, 10:30:53 »
Thoughts on high temp cooking, vaporizing oil smoke + Gas stoves.
Re: Cooking and dat Lung Cancer
« Reply #1 on: Fri, 06 December 2024, 10:35:17 »
Smoke from canola oil is known to cause lung cancer, yes. But in normal cooking you never heat it up so much that there is smoke.
When seasoning a pan though...
  • Live long and prosper
« Reply #2 on: Fri, 06 December 2024, 11:00:23 »
Everything causes cancer these days, why bother fighting it, enjoy life while you can. They'll cure cancer someday.
*smokes cigarette*
tp thread is tp thread
« Reply #3 on: Fri, 06 December 2024, 12:22:37 »
*smokes cigarette*
Ah yes, delicious cigarettes. The drug of the anxious.
It also makes you 500% more cool.
« Reply #4 on: Fri, 06 December 2024, 13:20:45 »
vaporizing oil
Plus trans fats begin forming over 400F/200C
- D Trump 2026-10-24
Online phinix
« Reply #5 on: Tue, 07 January 2025, 03:43:23 »
*smokes cigarette*
Exactly. I already had cancer in age of 43, I changed my thinking after that. I'm going enjoy my life and do things I would like to do, as I may finish my run in 10 years (or live till high 90s like my grandparents). Who knows what is going to happen, cancer is covering whole population now, no point in worrying all the time.
"They'll cure cancer.." - dont think so, might sounds like I like the conspiracy theory, but I think pharmacology companies won't release cancer killer cause that is one of the best population control nowadays. Plus all that money they getting from chemo stuff...
Offline Leslieann
« Reply #6 on: Tue, 07 January 2025, 03:58:52 »
Worry more about the non-stick pan you're using.
If they do cure cancer it won't be a U.S. based company.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #7 on: Tue, 07 January 2025, 03:59:59 »
It's not great for you but if you have reasonable extraction it's not that bad. PAHs don't form that readily under cooking conditions if you're using appropriate oils for the temperature you're using.
