Author Topic: Cooking and dat Lung Cancer  (Read 2453 times)
« on: Fri, 06 December 2024, 10:30:53 »
Thoughts on high temp cooking, vaporizing oil smoke + Gas stoves.
Re: Cooking and dat Lung Cancer
« Reply #1 on: Fri, 06 December 2024, 10:35:17 »
Smoke from canola oil is known to cause lung cancer, yes. But in normal cooking you never heat it up so much that there is smoke.
When seasoning a pan though...
  • Live long and prosper
« Reply #2 on: Fri, 06 December 2024, 11:00:23 »
Everything causes cancer these days, why bother fighting it, enjoy life while you can. They'll cure cancer someday.
*smokes cigarette*
tp thread is tp thread
« Reply #3 on: Fri, 06 December 2024, 12:22:37 »
*smokes cigarette*
Ah yes, delicious cigarettes. The drug of the anxious.
It also makes you 500% more cool.
« Reply #4 on: Fri, 06 December 2024, 13:20:45 »
vaporizing oil
Plus trans fats begin forming over 400F/200C
"Starting in 2011, the deficits again started to shrink. During Obama’s term  the deficit was reduced by $900 Billion  before finally in 2015 the GOP managed to wrangle a “reconciliation” bill out of Obama where he again cut corporate taxes, as well as made permanent some of George W. Bush’s original tax cuts. This is the year everything reversed. Before this, under Clinton, Bush and Obama the deficit in almost every year was gradually decreasing. The balance we had of taxes and the economy was bringing the deficit down, the money coming in was slowly catching up with the money going out until 2015. Trump’s subsequent tax cut has continued the new trend even after the rest of Bush’s cuts have since expired. Obama had an average GDP of 2.3%, with 11.6 million jobs created and unemployment peaking at 10% in 2009, then falling to 4.3% in 2016. If we had continued on that downward deficit track, we would have again reached balance and another surplus in 2017-2018.
– Frank V Walton 2025-07-01
Offline phinix
« Reply #5 on: Tue, 07 January 2025, 03:43:23 »
*smokes cigarette*
Exactly. I already had cancer in age of 43, I changed my thinking after that. I'm going enjoy my life and do things I would like to do, as I may finish my run in 10 years (or live till high 90s like my grandparents). Who knows what is going to happen, cancer is covering whole population now, no point in worrying all the time.
"They'll cure cancer.." - dont think so, might sounds like I like the conspiracy theory, but I think pharmacology companies won't release cancer killer cause that is one of the best population control nowadays. Plus all that money they getting from chemo stuff...
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
Offline Leslieann
« Reply #6 on: Tue, 07 January 2025, 03:58:52 »
Worry more about the non-stick pan you're using.
If they do cure cancer it won't be a U.S. based company.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #7 on: Tue, 07 January 2025, 03:59:59 »
It's not great for you but if you have reasonable extraction it's not that bad. PAHs don't form that readily under cooking conditions if you're using appropriate oils for the temperature you're using.
