Author Topic: Gaming PC Parts discussion thread.  (Read 696118 times)
0 Members and 7 Guests are viewing this topic.
Offline Sniping
Re: Gaming PC Parts discussion thread.
« Reply #1050 on: Thu, 07 May 2026, 12:50:44 »
Dell also released a $350 USD 27" OLED late last month - Alienware 27 240Hz QD-OLED Gaming Monitor - AW2726DM.  Looks like a solid option, I can't move up to a 32" due to desk space and don't like to have to pan and scan when I'm gaming, now if it's like Expd. 33 or D4/PoE I could do it - but playing GZW and EFT I need to see all with in tighter line of sight.
QD oled for 350 is pretty sweet
« Reply #1051 on: Sat, 09 May 2026, 15:16:30 »
Tp4 is hoping they'd upgrade oled soon to the ipad tandem line.
It's otherwise perfect.
Don't think an active heatsink is really that big of a deal if they'd just make it big enough.
« Reply #1052 on: Tue, 12 May 2026, 12:53:25 »
Tp4 remembrs when PS1 emulation was only for very high end PCs,  Pentium4 4ghz+
Now it's near perfect + crt beam simulator + xbrz + disable dithering.
Megaman X4, probably the most perfect Megaman game. So balanced in play mechanix, though a bit on the easy side.
317016-0
« Reply #1053 on: Tue, 12 May 2026, 22:08:17 »
It doesn't really make sense that oled monitors are this expensive.  When Oled TVs are orders of magnitude cheaper.
« Reply #1054 on: Tue, 12 May 2026, 23:25:45 »
[size=11p
been sayin' this for years.
X4 is everything X3 was, but with the power of CD which means bigger sprite files, more animations, better music, and anime cutscenes!
Offline yuppie
« Reply #1055 on: Thu, 14 May 2026, 09:35:50 »
I was able to crawl r/hardwareswap and the SFFHub discord to piece together a 5080FE x 9800X3D build recently, all so I could get wiped on Tarkov and re-addicted to Factorio: Space Age, once again.
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline Sniping
« Reply #1057 on: Thu, 14 May 2026, 19:00:05 »
Nice build, short cables help a lot on the T1
« Reply #1058 on: Mon, 18 May 2026, 07:23:16 »
People who actually blow up stereo amplifiers, how loud are they listening, that's insane, 5 watt is way over 85db, where 70 is pretty loud and uncomfortable.
« Reply #1059 on: Tue, 19 May 2026, 16:37:27 »
Arctic releasing what is probably a pretty gud' thermalpad, /not official endorsement.
317131-0
« Reply #1060 on: Sun, 24 May 2026, 10:03:21 »
Listen to Tp4,  BUY GPUS NOW.
9070xt is the only GPU that makes any sense. Current sales $630-750.
No other GPU makes any sense Performance vs. Price wise.
DO NOT buy 5070ti unless it's $750 or less.
DO NOT buy a 5080, those 12pins WILL BURN, it's only a matter of time, nothing can stop it short of you soldering the psu side together into a 12gauge.
DO NOT buy anything slower than a 5070ti.
NEVER EVER touch a 5060ti.
When the economy Xplodz, GPUs are going to be far more scarce, and cost way more.
It's almost guaranteed the Economy Xlodz..
Also buy motherboards now,  You can get a great board for $120-150.  Tp4 recommends Gigabyte, good ram compatibility.
Check the vrm table, make sure it has at least 500 amp configuration. 12x40, 8x70, etc.
« Reply #1061 on: Mon, 25 May 2026, 06:45:37 »
DO NOT BUY the upcoming 9070GRE,  it's got gimped ram. 12GB, 192-bit bus, very low bandwidth (for a modern card).
Basically another 5060ti to 4070super-ish lvl performance.
Even the Old 7900gre had 16GB @ 576GB/s on 256bit
The ram will hold it back when you go higher res.
UNLESSSSS,  it's $200,   which is imposssssible.   Even @ $300,  you're better off buying 9070xt.
« Reply #1062 on: Tue, 26 May 2026, 18:36:10 »
Tp4, You don't need a 98" Qm8k. The sony argb backlights aren't even out yet.
« Reply #1063 on: Tue, 26 May 2026, 23:02:43 »
cute and clean!
« Reply #1064 on: Thu, 28 May 2026, 05:47:19 »
Tp4 thinks people will start to realize how stupid it is to download 24bit music now that SSD space is @ a premium.
One of the most insane waste of computing power and space. 16bit 44100hz, All you ever need.
« Reply #1065 on: Thu, 28 May 2026, 06:51:18 »
Hrrm... Samsung's new monitor, 4k 360hz + 1080p 680hz dual mode.
This uses DSC, Tp4 doesn't understand why they couldn't go higher.
If they're gonna use DSC,  they should be doing 4K 643hz,  and 1080p 1352hz.
So mad right now.  Why are they sandbagging this, JUST DO IT.  It might need active cooling, so what?
Offline phinix
« Reply #1066 on: Thu, 28 May 2026, 12:39:57 »
When this price madness going to cool down and RAM and SSD prices get back down?
2027?
I bought a litely used external 4TB Shield SSD for Ł150, now I could sell it on ebay for Ł500. Thing is, I need more SSD :(
« Last Edit: Thu, 28 May 2026, 12:43:44 by phinix »
« Reply #1067 on: Fri, 29 May 2026, 04:56:18 »
People who bought the $800-1000 steamdecks.
You're an idiot.
These things have the performance of 10yr old entry lvl laptops.
« Reply #1068 on: Fri, 29 May 2026, 05:11:17 »
The first demo-ed 1000hz 1080p moniotr,   it's tiny and it's IPS,  YUCK...
IPS is ok for the Office, but Tru G4mrz needs to have OLED burn-in for max motion clarity.
IPS GtG pixel response time is also not suitable for anything higher than 360hz.  The motion clarity is about the same.
In principle if they can flash the backlight also at 1000hz, it might make up the difference, but they've yet to solve the Color crosstalk problem because of that slower GtG.
The other thing is, these monitors would need temperature stabilization and continuous compensation now, because the effective window for each backlight blink is much smaller.   Yet, another technology aspect not even talked about.
They also didn't report the contrast ratio, suspects it's probably still crap.
« Reply #1069 on: Fri, 29 May 2026, 06:56:30 »
I built a new computer last winter (when my 5 or 6 year-old rig died) and was absolutely appalled at the prices. Especially when Newegg sold me 2 motherboards in a row that were defective.
The other day I thought it would be nice to get a 2TB NAND but had to nix that idea. I wish that I could hope that the prices would come down in the foreseeable future, but I wonder ....
« Reply #1070 on: Fri, 29 May 2026, 08:07:08 »
2tb is only $250, that's not a fun price, but it's not impossibly expensive.
Offline phinix
« Reply #1071 on: Sat, 30 May 2026, 04:37:21 »
Yep, I noticed that too - about 2 years ago I built new PC for my daughter and had constant issues with GPU. Sent it back, they tested it and sent back without replacement saying nothing's wrong. I tested it in 3 different PCs and proved it being faulty, but no. HDD issues as well. Dont know why but in last 5 years hardware quality went down to drain.
I hope prices will go down next year, what its now is a total madness.
« Reply #1072 on: Sat, 30 May 2026, 06:47:34 »
If the prices go down, it would be because the economy blew up,  so not going to win this, unless you're holding millions in Cash.
Ur00p might go into full scale war. We'll be fighting for the billionaires at that point, to the death. The prices might come down, but inflation would've gone so high anyway that demand destruction occurs.
The n4 z1's have taken over the Gerblemen gobament,  it doesn't seeeeem like,  they're planning for anything other than the war path.
They're actively advertising that kiz should join the army.
« Reply #1073 on: Sat, 30 May 2026, 07:35:32 »
$300 5060Ti 16gb,
DO
NOT
BUY
THIS.
Get 9070xt for $650-700 instead.  WAY better deal.
ESPECIALLY a better deal, because the BASE price of a PC includes inflated ram and ssd,  which means, the + $350 price difference represents an even LOWER % of the total.
Base PC is roughly $900 now because of SSD/RAM inflation.
$800 + $650 = $1450 < better deal.
$800 + $300 = $1100
+32% the price for +72% the performance
« Reply #1074 on: Sat, 30 May 2026, 10:48:19 »
Motherboards step down are pretty severe,
For example, the MSI VC line built for OEMs, maximized profitability.
OLDer B650-VC, 2x6+2+1  75A (SPS-mosfet), very low loss.
Power delivery is so good, you don't even need a heatsink.
The mos will run 230watt and be barely warm to the touch.
317225-0
Notice the new boards need quite large heatsinks, because they've gone w/discreet components, no mosfets.
B850-VC,  2x6+2+1 discreet
B850m-VC,  7+2+1 discreet,  /GASPppppp,  you can see the 2+1 exposed section at the top of the m-board, going back to 2014 for cost savings basically.
317226-1
317228-2
« Reply #1075 on: Sat, 30 May 2026, 19:37:16 »
Gettn' prettty desperado out there, Tp4 see'n some Computer parts skus' shipping down 90%.. Shelf costs $.
After a few more months, most of the margin's gone.
« Reply #1076 on: Sat, 30 May 2026, 22:27:53 »
Not too many gud' Microled gaming monitors.
Kinda weird these aren't more popular.
OLED is probably more profitable at $700.
« Reply #1077 on: Mon, 01 June 2026, 05:06:34 »
9070GRE, they're going with $550, that's a NO.
9070xt at $650, no competition.
« Reply #1078 on: Mon, 01 June 2026, 06:04:55 »
What's with this "carbice" racket, <vertically aligned carbon nanotube cooling sheets>
The CLAIM: Trade performance for durability??
This is ridiculous, if PTM is just as good over the 5-10yr OBSOLESCENCE lifespan of a CPU, while performing 6 Celsius better, what use is carbice for the desktop market?.
It's like saying, I've built the hinges on my refrigerator to last 1000 years. OK, humans killed each-other 900 years ago, but you've still got those hinges for the refrigerator that doesn't cool anything where there's no food on a Dead-Earth for anyone..
:D
« Reply #1079 on: Mon, 01 June 2026, 15:33:19 »
Go out and buy PC Cases,   Support PC cases, or they's gon' die.
« Reply #1080 on: Tue, 02 June 2026, 07:30:44 »
Do not be tempted by $300 3060ti's,
3060Ti = REGRET.
Buy $660 9070XT.
« Reply #1081 on: Tue, 02 June 2026, 20:20:11 »
What is up with   zen3   Ryzen 5 5500 + B550M combo,  this seems the darling of amazon PC.
Why are so many people sticking with Am4 at this point.
« Reply #1082 on: Tue, 02 June 2026, 20:52:57 »
Guess you can make an argument for ddr5 prices.
But still, $70cpu + $80board + $160 32gb ddr4 used
$310
vs
used ryzen 7700 + new B650 + 32gb ddr5 used.
$150 + $120 + $300.
$570
That's not verrrry different, even with the hikes.
« Reply #1083 on: Wed, 03 June 2026, 08:08:17 »
$310
vs
$570
The way I learned math, that is about half. 54% to be exact ....
« Reply #1084 on: Wed, 03 June 2026, 08:10:03 »
Like Tp4 said, not a big enough difference.
Especially considering AM5 support is to 2029, it will probably get Zen 7 CPU which will hit 7Ghz.
So the $420 base cost is preserved all the way to 7ghz, FROM 5.5ghz.
Whereas AM4 has no economical path.
« Reply #1085 on: Thu, 04 June 2026, 07:11:33 »
Computex stuff, underwhelming, unimaginative.
The only thing that looked cool so far is the ferrofluid case displays, if they can make that sound / performance reactive, that could be kinda neat.
« Reply #1086 on: Thu, 04 June 2026, 07:49:45 »
27 inch Oleds for $350.
Guys, Don't, DO NOT do this.
27 inch = REGRET
32 inch minimum,  85 inch ideal.
« Reply #1087 on: Thu, 04 June 2026, 13:20:00 »
9070xt hitting $650 on amazon.
Economic depression is coming, plan accordingly.
« Reply #1088 on: Thu, 04 June 2026, 15:51:00 »
Hope every1 got their 9070xt's
It's goin'' fast...
« Reply #1089 on: Fri, 05 June 2026, 11:17:30 »
OMg, what? this looks awful, why would they do this? This new Zalman cooler.
It's supposidly "Inspired by" CNPS series,  but look at the fins.  They're just faking it with a useless plastic tube.
It has far worse performance as it loses surface area vs equivalent square blocks.
317389-0
« Reply #1090 on: Sat, 06 June 2026, 11:14:10 »
You go fix PC,  they be like, yea it's making a loud grinding noise.
Turns it on, they watch in horror as ExpurtP4 sticks his hands directly into spinning fans to figure out which bearing's worn out.
They asked if it damages the fans to be doing that.
Then Tp4 realizes, OMG,  these people don't know how Fans work either.
:-X
« Reply #1091 on: Sun, 07 June 2026, 10:38:04 »
How much m0ar ray trace do we need.
Hrrrrm..... Realistically, another 20x will probably do it for 4K.
Maybe 50x if we want to subsurface every element.
« Reply #1092 on: Sun, 07 June 2026, 16:29:13 »
Hrrrrm... qm7k 55 inch 144hz  LCD for $600,  mmmmmm.... maybe at $400 it would be irresistible, but $600 is mmm... nahh.
« Reply #1093 on: Mon, 08 June 2026, 16:16:50 »
7500x3d + mobo + 1x16gb stick ddr5,  $300 microcenter bundle
IDK..... Hrrrm.... Gud's starter build, but 6 cores, hrrmm...
It's got x3d, so even a single stick of ram is ok, buhhh, hrrrmmm...
« Reply #1094 on: Mon, 08 June 2026, 21:09:17 »
microcenter bundle
For 25 years I lived 15 minutes away from MicroCenter and just bopped down there whenever I needed something. Now I live 200 miles away.
When I went to build a new computer last winter, I discovered that that those nice bundles are "in-store only"
« Reply #1095 on: Tue, 09 June 2026, 09:29:53 »
Looking at the bundles
the Intel 270 bundle for $600 is unbeatable if you NEED M0ar Cores. It's as fast as 9950x for that sort of thing for <Half the price,
> Drawback,  Dead socket.
the 7800x3d bundle is probably the best gaming bundle at $600, the $630 motherboard upgrade is worth it, Performance vs Price king (accounting for longevity).
> but, drawback that $630 bundled motherboard has a weak vrm section (For the price), they're using this bundle to clear old stock boards they can't move.
the 9800x3d and 9800x3d bundles are too expensive, not worth the upcharge at the moment.  Wait for Zen6
the 9700  $570 upgraded bundle is ok if you really don't game much.  Still gives you path to Zen 6 which is coming soon and a decent motherboard that will support it.
« Reply #1096 on: Tue, 09 June 2026, 16:33:42 »
7900x and 9900x
The Cursed CPUs.
7900x refurb selling for $200 right now on amazon,  CRAZYYYY gud' deal if you need one...
12 corez...
« Reply #1097 on: Tue, 09 June 2026, 22:40:06 »
2304 dimming zones 32 inch 4k 160hz for $500.
Hrrrm.... interesting.. IPS, so, not super great contrast, but mm...
« Reply #1098 on: Wed, 10 June 2026, 16:25:58 »
That's honestly alot of zones for a 32 inch.  Wonder if it's real.
Large Tvs only have 1500ish in the mid range.
« Reply #1099 on: Thu, 11 June 2026, 22:28:15 »
Just painful to look at,
This is a mini pc with 2 yr old chips for $1160.
A laptop of this config with a 3K oled is usually less than that.
Tp4's walmart special desktop from 2 years back with 7900gre + amd 7700, 32gb+2TB was $1000 flat.
It might be somewhat acceptable if they let you overclock the hell out of it to the tune of 300watts and ddr6000, but as is, what's the point.
317434-0
317436-1
