Author Topic: Gaming PC Parts discussion thread.  (Read 837522 times)
Online tp4tissue
Re: Gaming PC Parts discussion thread.
« Reply #800 on: Tue, 12 August 2025, 17:41:33 »
Pretttty kewls.
Beating stock hynix sets with the default cheapo samsung microcenter bundled ram.
Most of those hynix stock sets are 30 40 40 96 or 30 36 36 96 at 6000mhz
This set's doing 32 34 34 80 at 6200mhz
314016-0
Online tp4tissue
« Reply #801 on: Wed, 13 August 2025, 07:46:15 »
Why does Tp4 feel compelled to buy 8000rpm fans.  He hasn't done it, but it's always in the back of his mind.
8000rpm could be his, yet with absolutely no where to put them.
Online tp4tissue
« Reply #802 on: Wed, 13 August 2025, 17:45:47 »
You know what's weird.   There are so many "brand new" ugly PCs out there.
It's one thing if someone was taking alot of old stuff and pushing forward, but you see these people with all new parts, and it's ugly as hell.
Tp4 can't understand this. Are they even trying?
Online tp4tissue
« Reply #803 on: Wed, 13 August 2025, 17:54:32 »
Ram settings verified. Prime95 stable.
32-34-34-80 6200mhz 1.435v from  36`36`36`96 6000mhz 1.35v
Pretty solid gains. Beats most stock hynix sticks.
32 33 32 80 should be possible, buhhhh does Tp4 want to use another 5KW of electricity to find out? No.. not really. :-X
Offline Sniping
« Reply #804 on: Wed, 13 August 2025, 20:31:00 »
Speaking of ram, I can't get my sticks to run at advertised speed on my kinda crappy motherboard (prime b650m-a). I feel like I might spring for a different motherboard just to address this. sticks aren't on QVL list. not too concerned with the extra cost of a different motherboard, but more concerned about whether it'll actually make a difference. no difference would seem like a waste of time for me lol.
Online tp4tissue
« Reply #805 on: Wed, 13 August 2025, 21:27:38 »
Do you have the samsung kit or hynix kit.  List your exact kit.
Set vsoc to 1.2- 1.225
vddq and vddio to 1.25 for samsung, 1.35-1.4 for hynix
Set BCLK to 100mhz
set infinity fabric to 2000.  mclk = uclk 3000mhz (60x multi).
set gear down mode to auto (motherboard dependent), auto works in most cases.
set power down mode to disable
set memory context restore to disable. (required for max stability, even at 6000)
There's nothing wrong with the board, if it's on an older bios, it probably just has a low stock vsoc, which can cause some processors to not boot 6000.  Most new bioses move the default vsoc to 1.2-1.25
Memory context restore is also a big one, very rarely can you enable it and be stable. It might be stable with it on for a day or a week, and then crap out randomly.  That's just how it is on this platform.
Online tp4tissue
« Reply #806 on: Thu, 14 August 2025, 08:21:04 »
Sitting back, Can Tp4 feeeel CL 32-6200 vs CL 36-6000.
LOL, in testing an old CPU bound game, 1000fps is now roughly 1150fps. That's nice, but can you feeel that. hrrm..
:D
Online tp4tissue
« Reply #807 on: Thu, 14 August 2025, 11:23:36 »
These fans are ugly, they should be removed from the market.
Infinity mirrors are horrid, there's absolutely no context for their existence in the presentation itself.
The Antithesis of Aesthetic.
314054-1
Online tp4tissue
« Reply #808 on: Thu, 14 August 2025, 11:24:32 »
The new Phanteks are not bad, solid lines. Massssively overpriced though.
314058-0
IN general ,  You just don't want so many led bars/ protrusions, it just looks messy like LIGHT ACNE.
Simple circles are balanced on their own.  Tp4 demonstrates this perfectly with budget fans.
Also important is understanding that RGB 255,255,255 is NOT white, on most fans, it's Cyan, approximately 1000-1500nits of green and 2000nits of blue.  The RED is gone.
Below is Properly calibrated 93K White. Different on different fans, but approximately RGB 255, 181, 115
Running max bright also Turns other colors BLACK due to contrast. It's important to lower the brightness so the color from the other components are visible.
Colorimeters really help dial things in, Tp4 recommends everyone get a colorimeter to setup their case LEDs.
Below, we also see yellow rgb, 255, 165, 0. If you just turned on RGB 255, 255, 0, you actually get a very bright green.
314060-1
« Reply #809 on: Thu, 14 August 2025, 18:58:16 »
RGB is too bright and keeps me up at night since my home office in in my bedroom. I used to open up RGB components and snip the led wire or just pull them off, but more modern components have the led tied to the main wiring and you can't just circumcise your leds anymore :(
I have been looking for more carbon fiber parts though. Got CF fans/shroud/trim/and bracket for my gpu and it looks sick as hell
This case is so slick, but I cannot justify the $300 for my old rig
https://www.amazon.com/dp/B0DCF358YG/?coliid=I3REA6UT35TAXE&colid=FSX56MC2IH3B&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
« Last Edit: Thu, 14 August 2025, 19:01:04 by noisyturtle »
Online tp4tissue
« Reply #810 on: Thu, 14 August 2025, 19:05:56 »
Nothing wrong with carbon fiber as a texture, but again, like infinity mirrors, they're there out of context, which makes it gauche.
« Reply #811 on: Thu, 14 August 2025, 20:21:34 »
I hated that, and also worry about lightning. I got something similar to this so that I can shut down the entire computer ecosystem at night with 1 switch.
https://www.homedepot.com/p/15-ft-5-Outlet-Industrial-Heavy-Duty-Power-Strip-for-Garage-Workshop-HOU515A1/329096128
PS the modem/router is across the room and has a power strip of its own.
- D Trump 2026-10-24
« Reply #812 on: Thu, 14 August 2025, 22:39:41 »
tp u cray cray, carbon fiber, I mean REAL carbon not a plastic wrap, is sheer class. I'd even say moresoe than a precious metal like gold. Look at who demands cf - the top of their fields for weight reduction, heat dissipation, and durability without compromise on manufacturing or cost. Look at who likes gold - Saudi Princes and Donald Dump.
CF is all class, without the gaudy gaucheness, an understated representation of the peak in human manufacturing.
Online tp4tissue
« Reply #813 on: Fri, 15 August 2025, 05:00:13 »
Let's say you make dumb-bells out of carbon fiber,  Stupid right?  WHY is it stupid,  ___CONTEXT___.
Same with desktop PCs.
Online tp4tissue
« Reply #814 on: Fri, 15 August 2025, 05:03:59 »
PSA,
DO NOT buy current expensive Ram,
AMD's new memory controller will change the landscape for AM5.
Online tp4tissue
« Reply #815 on: Fri, 15 August 2025, 05:13:20 »
Thin flat FFC cables in mice.
Yea, the weight savings, but honestly, they're not nearly as resistant to drops as the older ribbon cables with thin tube sleeves, mainly due to the connector.
The connector is the problem for FFC, the clamping plastic insert can shake loose or turn slightly making poor contact for the cable. It doesn't take much to loosen them.
314085-0
Offline phinix
« Reply #816 on: Fri, 15 August 2025, 05:27:44 »
carbon fiber is great, perfect for building things like... commerical submersible boats for rich people to go and see Titanic for example ;P
Online tp4tissue
« Reply #817 on: Fri, 15 August 2025, 05:37:48 »
All excellent choices by the world's greatest engineers.
Offline Sniping
« Reply #818 on: Fri, 15 August 2025, 13:20:06 »
reminder that bf6 beta is open for this weekend only. put those fancy computers to use
Online tp4tissue
« Reply #819 on: Fri, 15 August 2025, 13:59:07 »
Did you try the TP4 motherboard tuning suggestions for ddr6000 ?
Offline Sniping
« Reply #820 on: Fri, 15 August 2025, 16:25:33 »
will give it a shot over the weekend, I haven't had time to tinker the past two days. my motherboard doesn't support the advertised speed that my sticks run at, which is why I'm not certain it can do it.
Online tp4tissue
« Reply #822 on: Sat, 16 August 2025, 07:41:08 »
Youtubers reviewing monitors.
Tp4 shakes head,  they don't know anything about monitors. Literally nothing. It's worse than 0, because they perpetuate misinformation.
Online tp4tissue
« Reply #823 on: Sat, 16 August 2025, 07:44:30 »
Also, 27" monitors in 2025.  /big sigh.
Online tp4tissue
« Reply #824 on: Sat, 16 August 2025, 08:03:22 »
Don't know how to feel about the Western Digital 8100 ssd.
They're not using a custom controller this time, just off the shelf. If that's the case, what are we paying for ? Does it have the same WD stability/tuning standards/durability of previous Gen ?
Online tp4tissue
« Reply #825 on: Sat, 16 August 2025, 12:52:18 »
Understanding Gamut Narrowing.
Notice these gamut measurements correlating to Luminance.
On LCD and W-OLED, as luminance rises, the gamut coverage goes down, because white light (lcd leakage) and w-oled pixel pollute the color purity, reducing / narrowing the gamut (saturation) of the color primaries.
VS  QD- Oled, which is PURE RGB, with no pollution, very pure color, the only technology which beats it in gamut is Trichroma-Laser, but that has more limitations for use with modern media.
LCD
314150-0
W-OLED
314152-1
QD-OLED
314148-2
Offline Sniping
« Reply #826 on: Sun, 17 August 2025, 05:21:54 »
Set BCLK to 100mhz
Looked up my kit and it’s F5-6400J3239G16GX2-TZENRW, not sure if that changes anything. gonna try these settings tomorrow morning
Online tp4tissue
« Reply #827 on: Sun, 17 August 2025, 06:31:35 »
That's a 6400 hynix kit.
Most Ryzen cpus will not boot 6400. Nothing to do with the board.
You need 1.35 to 1.45 vddq to  and vddio for hynix
The other settings should help. 6000 and 6200 will for sure boot at 1.25 vsoc, If you want 6400, you will probably need 1.3, and if you want that latency minimizer thingie, you can try 2133mhz infinity fabric instead of 2066 or 2000.
Start the infinity fabric lower at 2000, and get the other settings down first.
Online tp4tissue
« Reply #828 on: Sun, 17 August 2025, 12:45:47 »
NE1 know how steam link works?
Latency seems way too high to play anything.
Offline Sniping
« Reply #829 on: Sun, 17 August 2025, 15:52:56 »
Was able to bring the ram from 4800 it was running at to 5400, but would crash when I set to 6400 (no post) and 6000 (crashes as I get into windows). I got a bit lazy and found the motherboard had a preset memory setting for Hynix 2x16 6200mhz, where the vdd voltage was set to 1.4 and there were a bunch of other settings and just used that for now. Might have to do some extra tweaking to bring it up further. The motherboard spec page only goes up to 5600 so I assumed that was the limit.
Offline phinix
« Reply #830 on: Sun, 17 August 2025, 17:37:50 »
If same price, no costs, would you jump 9070 XT -> 5070Ti Super?
« Reply #831 on: Sun, 17 August 2025, 18:20:14 »
The 5070 Ti has 24gb memory vs 16 the 9070 XT has, which gives it significantly improved ray tracing. Otherwise they are basically the same in performance.
Online tp4tissue
« Reply #832 on: Sun, 17 August 2025, 18:20:50 »
You can pump 1.8V into hynix without blowing it up. But you need active cooling beyond 1.45.
Online tp4tissue
« Reply #833 on: Sun, 17 August 2025, 21:16:29 »
People who buy boards based on PCIE lane sharing on M.2
Lan sharing = bad yes,  but if they're routed to m.2, they're basically worthless cuz, who the hell cares, sata 600 already peaked.
Online tp4tissue
« Reply #834 on: Sun, 17 August 2025, 22:52:48 »
These igpus now reaching basically 80% of a gtx 1060.
That's actually pretttty enough for most things. If they threw Overclocking in there, it's basically done.
Of course, ideally, 7800xt lvl as base would be more enduring. It wouldn't be that big a problem to deliver 350watt for a desktop APU.
A single dual tower can do 600watt easily as long as it's oriented correctly, standing vertically.
The ideal situation here,  APU, that's a 18core zen 6 x3d at 250watt + 9070xt at 350watt, bolted together, soldered 64gb ram + 24gb vddr7.  Dual tower cooler with 2x sanyo denkis,
12v psu, this thing can cook for at least 7-8 years no problem.   Make it microsoft xbox or steam machine premium for $ 1000.
Online tp4tissue
« Reply #835 on: Mon, 18 August 2025, 00:39:00 »
It's kinda stupid people buy fightsticks for $200.
There's at most maybe $15-25 worth of parts in there at the top tier. After marketing, they're easily making more than 50% a stick.
Offline phinix
« Reply #836 on: Mon, 18 August 2025, 02:31:47 »
Yeah, kinda more future proof.
Online tp4tissue
« Reply #837 on: Tue, 19 August 2025, 22:37:55 »
NE1 go wifi 7 yet?
Convenient o' no?  Range?
Online tp4tissue
« Reply #838 on: Wed, 20 August 2025, 10:57:53 »
What's the go-to thin and light laptop these days ?
« Reply #839 on: Wed, 20 August 2025, 18:53:23 »
What reasons would a used GPU have the wrong P/N sticker on it? I'm trying to figure out if the guy slapped the wrong sticker on it, or it is something EVGA does when they refurb something?
Online tp4tissue
« Reply #840 on: Wed, 20 August 2025, 20:24:35 »
Is it just me or is lenovo 14 too expensive.  ryzen 350 32gb for $1300,  dell/ hp sells basically the same thing for $800ish.
Online tp4tissue
« Reply #841 on: Thu, 21 August 2025, 03:38:59 »
You know, this ryzen 350 is looking better and better the more you  look at it.
Seriously, this processor is amazing.
Yea, they do soldered down ram to hit 7500MT/s  but that's a worthy tradeoff because it helps the iGPU greatly.
Online tp4tissue
« Reply #842 on: Thu, 21 August 2025, 05:04:07 »
That pixel 10 camera bump. seriously, facepalm.
Why does it still look like that.
Online tp4tissue
« Reply #843 on: Thu, 21 August 2025, 06:32:46 »
It boggles the mind people are still buying 5080 and 5090s.  That 12vhpr will burn, it's only a matter of time.
This is un-fixable.
Offline phinix
« Reply #844 on: Thu, 21 August 2025, 16:43:13 »
There are some good GPU prices now, I think. Dropped lately a bit, more in stock.
I'm getting 5070 for my daughter, comes with new Borderlands 4 code. Anyone interested in that?
Online tp4tissue
« Reply #845 on: Thu, 21 August 2025, 17:32:59 »
5070/9070 are mistakes.
5070ti or 9070xt is significantly higher in performance to cost ratio..
« Reply #846 on: Thu, 21 August 2025, 20:19:10 »
Last night I moved my OS boot drive from a platter to an ssd, and my boot time went from about 2.5mins to about 20secs
idk why I didn't do this 10 years ago...
Online tp4tissue
« Reply #847 on: Fri, 22 August 2025, 03:11:44 »
Get the x4 pcie bracket, switch to nvme, you should have an x4 pcie 2.0 slot on z97. Its faster than sata.
Online tp4tissue
« Reply #848 on: Fri, 22 August 2025, 10:15:54 »
Seriously, why are we still making 60% srgb laptop screens with trashy out of the box calibrations.
WHY, how much money can that possibly save.
The external cost of this is astronomical. You buy something on the internet, it's the WRONG COLOR, because the lcd is 60% srgb.  You make a return.   The cost of the fuel and labor on that return, far exceeds the cost of making a 99% srgb panel.
Now multiply these return costs by ALL laptops with these screens.
It just doesn't make sense.
Online tp4tissue
« Reply #849 on: Fri, 22 August 2025, 13:47:13 »
Unless intel's laptop iterations are much cheaper than AMD, Tp4 can't think of a single good reason to buy any intel mobile chips.
The iGPU on AMD works so much better.
