Author Topic: Gaming PC Parts discussion thread.  (Read 844281 times)
Re: Gaming PC Parts discussion thread.
« Reply #750 on: Wed, 30 July 2025, 14:00:31 »
9070xt, Finally.
Still way overpriced.
313817-0
Offline phinix
« Reply #751 on: Wed, 30 July 2025, 15:18:38 »
formatting a 4Tb hdd taking all day zzzzzzzzzzz
I haven't even started the cloning process yet, dyin' over here
noisy should ditch the platter drive and go with solid.
« Reply #752 on: Wed, 30 July 2025, 16:41:18 »
4Tb 870 EVO is like $275 and the WD Black was was only $80
that's the real reason
« Reply #753 on: Wed, 30 July 2025, 16:52:24 »
You should've gone with a pcie ssd riser card, and used the x16 slot with x4 bandwidth to get pcie2.0x4 which is still 1.5gb/s and supports all the usually ssd stuff.
« Reply #754 on: Thu, 31 July 2025, 09:47:57 »
Should we sign up 4 gamepass? That is the question.
« Reply #755 on: Thu, 31 July 2025, 14:54:16 »
When dat amazon app says, yous com'uter stuff is being delivered in 5 minutes.
Then it says, still coming, but heck if we know when it's coming, but probably today, but then maybe not. Anyway, trust me bro, it's coming.
« Reply #756 on: Thu, 31 July 2025, 14:55:22 »
It's like, damn, did my guy's truck lose tracking?
« Reply #757 on: Thu, 31 July 2025, 15:44:47 »
Having experienced traffic in New Jersey firsthand, I can believe it.
- D Trump 2026-10-24
« Reply #758 on: Thu, 31 July 2025, 16:06:47 »
My guy just ping'd up on the app.
Thank god he is not dead. His truck went dark during a big rain cloud.
« Reply #759 on: Thu, 31 July 2025, 16:37:37 »
Gosh darn, the pcie cable extensions, they're completely different from the color on the website.
:-X
« Reply #760 on: Thu, 31 July 2025, 17:14:36 »
Like, the cables are not white, they're purple. More violet than purple, a very gawdy lifelessly toxic kind of white.
Tp4 is looking for a near beige, regal kind of white. The white of the snow that covers a recently storm broken tree trunk.
« Reply #761 on: Thu, 31 July 2025, 18:49:51 »
Tp4 is so mad. Still can't believe how different it looks.
The internet is messed up.
Offline Sniping
« Reply #762 on: Thu, 31 July 2025, 22:29:51 »
just get a refund man there's always people trying to sell you shoddy product out there, don't overthink it too much.
« Reply #763 on: Thu, 31 July 2025, 23:44:39 »
The total deep clean and rebuild took 14hrs. Exponentially less time than it would've taken to build it new, but MUCH less money.
I'm a little upset I cannot get my 4x32Gb to work on the Sabertooth Z77, everything I read said 32Gb was totally possible with the latest BIOS update. LIES! I can only get 16Gb to post without the MEMOK going red  :mad:
Temps are on average 40-50°F cooler across all cores (how is that in C 4.4-10°? is that correct? seems like a weird gap, crazy Europeans)
« Reply #764 on: Fri, 01 August 2025, 00:26:24 »
Tp4 is 100%accurate 100% of the time.  Sweet tears of I told you so's
« Reply #765 on: Fri, 01 August 2025, 00:28:20 »
This is a huge problem even culturally.  The uneducated masses will prefer the trashy whites, because they have little reference other than that it's an unlikely color, therefore desirable.
Offline phinix
« Reply #766 on: Fri, 01 August 2025, 04:26:11 »
So tp now has 9070 XT, same as phinix? Nice :)
What games does tp play?
« Reply #767 on: Fri, 01 August 2025, 08:18:30 »
Right'mao,  mozzying over signing up for xbox game pass,  But is it "feeding the beast" and "killing developers."
Tp4 is twinsies'n with noisyturtle on building pcs at the moment.
« Reply #768 on: Fri, 01 August 2025, 08:25:58 »
Real purples can be dramatic and beautiful, but those puce/puke off-white non-lavenders really are dreadful.
  • Live long and prosper
« Reply #769 on: Fri, 01 August 2025, 14:35:26 »
Sup guys, it's been a while!
Looking to build a new rig, with these as the core components:
https://www.microcenter.com/product/5007086/amd-ryzen-7-9800x3d,-msi-x870e-p-pro-wifi,-gskill-flare-x5-series-32gb-ddr5-6000-kit,-computer-build-bundle
Swapping the GSkill for Corsair VENGEANCE RGB, with the plan to get an MSI VENTUS RTX 5070 Ti as the GPU. Probably a 1TB Samsung 9100 PRO for the OS and a cheaper 4TB NVMe for storage.
Any other recommendations? PSU/cooler/case?
tp thread is tp thread
« Reply #770 on: Fri, 01 August 2025, 16:15:10 »
No, bad build.
Get the 9700x $460 upgraded motherboard bundle. That motherboard is good for future zen6 upgrades.
The 9800x3d makes minimal difference unless you play esports at 720p. You can get it if you're RICH.
Anything 1440p and above, you're GPU bound. 9800x3d price difference can be put towards GPU
There are PNY 5080 going for $1000 at bestbuy now and then, get that instead of the 5070ti.
The 9700x is more than enough for now, and ZEN 6 is going to be 7.4-7.8GHZ  it will absolutely surpass the 9800x3d.
1TB is not enough.  You want 4TB WD 7100. OR wait for sale and get a 4TB with Dram, like SN850x for $205 used.
Tp4 just got one, 0 writes, brand new amazon return.
PSU lasts a long time, would go for the best, like LEADEX VII XG 850 or 1000.  Most stable voltage regulation and ripple suppression. They have a history of low-coil-whine due to very strong leadex platform. Not all leadex are the same, VII is what you want.
All gpus have coil whine, but really Bad coil whine is mostly due to PSU.
Offline phinix
« Reply #771 on: Fri, 01 August 2025, 18:32:22 »
No, bad build.
Some time ago Leslieann said that we should not buy any memory, cards or ssds on Amazon.
« Reply #772 on: Sat, 02 August 2025, 08:13:43 »
Cards in general is a minefield amazon or not.
Used SSDs that are NOT samsung are ok. Samsung has the most faker write data smurfing.
Memory is ok usually, as long as they haven't been thrown in a bin where the chips crack.
Offline Leslieann
« Reply #773 on: Sat, 02 August 2025, 08:46:11 »
You want Amazon for motherboards for the easy return policy. Newegg is terrible regarding bent pins.  It's a high warranty item that can be put back on the shelf.
You want an authorized dealer for your SSD, particularly Samsung, same with GPU because Amazon will sell foreign market models and reject your warranty. Well, not reject but make you do the warranty overseas which is tough if you don't speak the language. I do buy Crucial drives from Amazon.
On my last system I bought my GPU local and the rest from Amazon (no ssd).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #774 on: Sat, 02 August 2025, 15:26:24 »
I had one super bent pin on the used mobo I just swapped into. Tried bending it back and it snapped like an old dry hair. I clipped a pin off my old P867, VERY carefully at the base, and used a pinhole attachment for my heatgun to loosen the solder around the broken one just barely enough to where it was pliable and with extreme frustration and infinite patience, was able to hold the doner pin long enough to solidify. I seated the cpu and prayed - and it posted! The process took nearly 2hrs, and most of that was trying to figure out a way to get the doner pin to stand up in it's new home. NEVER again.
I think it is permanent, if the cpu is ever removed it will destroy the socket
« Last Edit: Sat, 02 August 2025, 15:27:56 by noisyturtle »
« Reply #775 on: Mon, 04 August 2025, 14:33:01 »
Yoyo, just got a KTC H32S25E gmrn' monitor. 32inch, 2560x1440
It were on sale, for $250.
Crazy good for the price these days.  VA, 240hz, PFS wide gamut colors,
Measured 4100:1 contrast out of the box in 5500k > red shifted. At 6500k, Tp4 measures 3630:1, very respectable for monitors of this type, since we usually only get ~2800-3000ish.
The motion quality, not as good as ips, but nothing like the smearing we saw in the past va-panels.
it has 1000mm curvature, Very nice looking up close.
The image quality for anything other than absolute competitive fps is stellar, Far in excess of what IPS can do with its crappy 1000 to 1500:1 grey black contrast.
KTC is not known in the west, but it's a Huge brand in Asia.
« Reply #776 on: Mon, 04 August 2025, 15:56:05 »
I was looking at that exact monitor as well. Screaming good price for anything else in that bracket of technology.
Curious how it is
Offline Leslieann
« Reply #777 on: Mon, 04 August 2025, 19:19:24 »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #778 on: Mon, 04 August 2025, 19:24:11 »
Everyone always forgets their mobo has like 2-4x extra USB ports as well
« Reply #779 on: Tue, 05 August 2025, 07:25:34 »
Why are they so stingy with the usbc ports?
How much can these chips possibly cost?
Here you go... 10 Type C ports.
https://www.amazon.com/ASRock-Z890-LGA1851-Motherboard-Thunderbolt/dp/B0DJRRF6MH?tag=bngsmtphsnus-20&hvqmt=e&hvlocint=
Will Ultra Richy Rich Leslieann please buy 4 Tp.   Tp4 very poor this month.
« Reply #780 on: Tue, 05 August 2025, 14:08:32 »
The Drmp government hindering broadband access.
Well.. blessing in disguise maybe,  what has broadband really done, produced incongruent members of society such as Tp4.
Not worth the tradeoff. Let's just not have dat internet.
« Reply #781 on: Tue, 05 August 2025, 18:36:55 »
Same as with the weather satellites - All future communications to be routed through the Muskrat's satellites and all satellites shall belong to the Muskrat.
Offline phinix
« Reply #782 on: Wed, 06 August 2025, 06:51:09 »
Sorry, what do you mean by Muskrat? I googled it and got a nice face of an animal :)
« Reply #783 on: Wed, 06 August 2025, 08:03:00 »
« Reply #784 on: Thu, 07 August 2025, 12:30:14 »
Tp4 is genuinely impressed by KTC H32S25E.
After a few days with it,  everything works, the colors look good.
Yellow is a little weak due to the weaker Green primary. Green is fine, because there isn't that much saturated bright green used in content.  If you want stronger yellow on lcd you need quantum dots, and currently only samsung does it, and it's gon' be $800.
Would it be better if it were 4K 240hz, yea... but you need a very expensive driver for that, and it wouldn't be $250.
1440p 240hz is gud'nuff for general gaming.
Would you be better served by a "Smaller" Oled for $500ish, Honestly, NO, 27" is just too small these days. there's no reason to squint or sit so close to smaller monitors when 32" is $250.
Really, Do Not buy anything under 32" for any reason.
« Reply #785 on: Thu, 07 August 2025, 16:22:09 »
Unpopular opinion.
White CPU COOLERS look really bad paired with white cases/white motherboards.
The correct choice is, SILVER.
Nzxt h7 flow (2024)
6x 140mm, 1x f360 3-fan (came with case), 1x 120mm top right,
Scythe Mugen 6 cpu cooler. + 1x arctic p12 pro 3000rpm cpu fan.
The new p12pro is decent, its quiet relative to its rpm, but also of course, it's a very low cfm fan like its earlier cousins.
313903-0
313901-1
« Reply #786 on: Thu, 07 August 2025, 17:44:09 »
Heads up, Dramless drives seem more sensitive to cpu/ram instability, leading to write corruption.
« Reply #787 on: Fri, 08 August 2025, 12:09:57 »
Weren't Bling enuff.
Installed some Gskill Royals paid $60 extra for dat silver.  ;D
313905-0
« Reply #788 on: Fri, 08 August 2025, 22:04:09 »
I bought a SSD off Amazon as new and it had a photo of a woman's passport, birth certificate, and family photos already on it.
WTF Amazon! It was sealed and everything, but the bracket holes were all scratched up when I opened it, so I checked it and, oh boy...
good thing I'm not evil
« Reply #789 on: Sat, 09 August 2025, 05:36:10 »
Spent all night calibrating the colors.
Set white point to D93
Balanced ram stick colors, white is brighter than yellow. You have to lower the white to match the exact brightness of the yellow.  Can't do that without the colorimeter.
Cpu fan and Gpu plate + Ram + case fans all color matched.
TBH, they really need to fix this stupid color system.  Most of the manufacturers don't have any coordination, and they all use ridiculous white points.
I'm honestly not sure why Red Channel is so low, why blue pulls power from red even if red is well within the envelope.
Yellow is a big problem, because of the way the green led pulls on the red channel, you can only get it so yellow, if you want it brighter, the yellow turns GREEN.
Kinda bummed that the 120mm up top right is slightly bluer than the 140mm. Same brand fan, slightly different color. The nzxt f360 is slightly bluer as well, but that's understandable, different manufacturer.
Ideally, every fan would have its own color channel. Buhhhhhhhhhhh..
313911-0
313909-1
« Reply #790 on: Sat, 09 August 2025, 07:03:54 »
A few years ago I read about someone who bought a used hard drive and discovered that it had come from an ATM.
Not wiped, and full of accounts, card numbers, and  PINS !
« Reply #791 on: Sat, 09 August 2025, 17:34:34 »
Honestly this was always a problem, but it seems to have gotten worse over the years with volume production.
Fan, Sticker-Wobble.
It happens when they don't put the front sticker in the middle, at low rpm, it looks like a big googly eye shaking left and right.
Pain in the butt to fix, as you might ruin the sticker peeling it.  :-X
« Reply #792 on: Sun, 10 August 2025, 00:35:23 »
Wow whaaa... Gigabyte boards no have SSD secure-erase function? WThhh, literally every other board has this function.
« Reply #793 on: Sun, 10 August 2025, 22:57:21 »
Why are you not using PTM?
You should be using PTM.
« Reply #794 on: Mon, 11 August 2025, 06:55:59 »
Tp4 has official given up on IPS.
There's no justification outside of Esp0art, every other aspect of IPS looks -Drab.
Even Within
most IPS gaming monitors, their backlight strobing is tuned so poorly that the advantage in motion clarity is minimal.
« Reply #795 on: Mon, 11 August 2025, 07:16:15 »
This is very weird that they don't make 32" curved at 4K 240hz LCD monitors.
Probably at this point, people own a 4090+ and spring for the OLEDs at $1000.
Since the control boards for 4k240 is quite expensive, it exists at a point where it nearly directly competes with oleds on price while making little profit for being LCD.
« Reply #796 on: Mon, 11 August 2025, 08:10:00 »
Windows defender keeps flagging winring0,  anyone know how to stop it ?
It seems sporadic.
« Reply #797 on: Mon, 11 August 2025, 21:48:27 »
RAM listed specifically on my mobo's QVL still won't post
this has been 3 out of 4 different stick sets that do not work that should
very frustrating, this mobo is too picky and has no modern bios drivers for compatibility
« Reply #798 on: Mon, 11 August 2025, 22:08:18 »
Check the ram in a different pc, it's probably busted.
These things get tossed around in the bin, especially old sticks of ram.
Tp4's new Gskills royal wurks gud though,  Gskill in general is pretty gud.  Unless is the samsung ics,  the lastest aren't as fast as hynix.
Sams haven't been in the lead for a while now.  Hynix A-die been beating everyone.
« Reply #799 on: Tue, 12 August 2025, 08:59:21 »
Tp4 is officially, ANTI -gam3r laptop.
It's just unreasonable.  You can't actually game on battery, so it's not really a gaming laptop. It's a regular laptop. and a "low-end" gaming desktop, that also happens to require babying the heatsink/fan, or the processor/gpu desolders itself, Not being hyperbolic, that Literally happens over time if the fans aren't pristine.
What they should do, is release a laptop with 175 watts cooling all dedicated to a CPU w/ integrated gpu.
THEN, sell a portable GPU that has pcie 5.0 X8,  Perfect.  No compromise.
In general though, 7-10lb laptops + the power brick, it's just too much weight.
