Author Topic: Gaming PC Parts discussion thread.  (Read 837520 times)
Online tp4tissue
Re: Gaming PC Parts discussion thread.
« Reply #700 on: Sun, 13 July 2025, 10:58:36 »
Downloaded this new firmware for the the ol' JMS583-chipped ssd enclosure, seeeems to work gud now.
Althhghhghghgouhgggg,  Fastcopy can still crash it, despite only it being able to hit dat max theoretical 980MB/s
Windows copy can only do 730MB/s sustained, but no crashing.
Offline Sniping
« Reply #701 on: Sun, 13 July 2025, 13:58:28 »
Why are they so stingy with the usbc ports?
How much can these chips possibly cost?
This is pretty accurate from what I've seen. I was shopping between motherboard models and features earlier this year and you'll realize they're really giving you the bare minimum even on $200-$300 boards. I hear that motherboards are more robust than in the past but really there hasn't been any explosive advance in features that you get at a given pricepoint, vs for keyboards for example a $100 keyboard now has the features of a $400 keyboard 5-10 years ago. I wanted a motherboard that was ITX, had good connectivity and had display connectors that allow for GPU passthrough that support 4k 120hz and up, and that narrowed it down to like 2-3 models and they were all $300 or more.
Online tp4tissue
« Reply #702 on: Sun, 13 July 2025, 14:27:53 »
One can understand why gpu passthrough would be expensive, if they have to all be 80gbps ports. But surely you can give people 2 of the damn things. and the REST be 40gbps.
Online tp4tissue
« Reply #703 on: Sun, 13 July 2025, 16:05:26 »
SSD price fixing.
This has got to stop.  We should be at roughly half the current price.   Hopefully Heroic-Y|\|\TC comes through for the world and destroys the Evil Nand Cabal.
Online tp4tissue
« Reply #704 on: Sun, 13 July 2025, 16:20:30 »
Pcie gen 6 ssds, might not be affordable to average consumers.
Online tp4tissue
« Reply #705 on: Sun, 13 July 2025, 18:24:01 »
Throughly tested the new jms583 firmware, gotta hand it to startech, they make stuff work. Even on stuff you don't buy from them. LOL.
Online tp4tissue
« Reply #706 on: Mon, 14 July 2025, 06:38:05 »
Batteries are alot cheaper thanks to aliexpress.
Remember when they used to be over $200.
They still sell them for $130 oem (who knows if they're even oem), $50-90 on amazon (non oem), $30 on Aliexpress.
Online tp4tissue
« Reply #707 on: Mon, 14 July 2025, 15:30:52 »
Whenever Tp4 gets nervous, he compulsively browses computer parts.
This is a grave illness.
Online tp4tissue
« Reply #708 on: Mon, 14 July 2025, 15:52:13 »
Most platforms don't even properly support  2x  gen 5 ssd.  You end up having to bifurcate down to 8x for gpu.
What the hell is the point of Gen 5 ssds then even, if you can't transfer anything that fast TO or FROM anywhere without kinda gimping the GPU.
« Reply #709 on: Mon, 14 July 2025, 15:56:10 »
SSDs are literally 3x more expensive than they were just 2 years ago
gee - 4Tb platter drive for $55 or 2Tb SSD for $170? what would you do?
Online tp4tissue
« Reply #710 on: Mon, 14 July 2025, 17:18:30 »
Only if you buy the latest Gen 5 ssd model.
Tp4 just got a used 4TB sn850x for $205 from amazon resale prime day, 0 read/write. Basically a return brand new.
Offline Sniping
« Reply #711 on: Mon, 14 July 2025, 22:59:36 »
$50/tb is the goal for ssd, don't pay much more than that.
Online tp4tissue
« Reply #712 on: Tue, 15 July 2025, 06:38:20 »
We should be at $25 per TB. It's all price fixing.
There's no reason they should be this high.
Online tp4tissue
« Reply #713 on: Tue, 15 July 2025, 14:10:29 »
Bwwwahhh.. Got scammed.  /CRYyy
Bought this enclosure, says 40gbps, but it's actually a JHL7440 chipset, which is Tunderbolt 3, and tops out at 2800MBps.
Online tp4tissue
« Reply #714 on: Wed, 16 July 2025, 09:38:00 »
Most these drawing tablets still stuck at 60hz.
Seems like a straight forward thing to have Maxxed out on given what's possible.
In theory, they can do 4K 325hz 8bit, or 270hz 10bit,  on the latest 4-lane HBR20. ~77.4 Gbps
That would be pretty awesome. 3DLut that can power that in gsync motion would be difficult, you'd need some pretty powerful chips, but it's certainly within the realm of possibility.  But static is probably more than enough, would artists care their pen tip has a slightly different shade on the leading edge for 1/300th of a second, I doubt it. so they probably don't need that pixel boost strobe compensation table.
But now that entry lvl artists are replaced by AI, they will be too poor to afford such things.
Without the individuals to drive demand, it falls to corporations, and if you supply corporate, the prices will massively inflate, and we're back to wacom prices.  And all innovation stops.
Online tp4tissue
« Reply #715 on: Wed, 16 July 2025, 12:26:48 »
Gud' ssd heatsink (HR10) vs,  bundled motherboard flat aluminum bar.
It's a pretttty sizable difference, now that Tp4 has 2 identical drives to compare.
Online tp4tissue
« Reply #717 on: Thu, 17 July 2025, 17:31:21 »
Such bad thermal design on the new razer blade 16.
This is not only bad for the OLED, but it would be bad for LCDs too because most LCDs are "EDGELIT" on laptops.  Gonna have a blow out.
Offline Kavik
« Reply #718 on: Thu, 17 July 2025, 23:14:43 »
Of course, just a month after building my computer, the 5070 TI I bought is $110 cheaper as of yesterday. And my CPU is about $20 cheaper now.
« Reply #719 on: Fri, 18 July 2025, 00:23:35 »
i was also noticing a drop in gpu prices the past week or so
Online tp4tissue
« Reply #720 on: Fri, 18 July 2025, 06:29:26 »
Consumer confidence is in the pewwps.
Online tp4tissue
« Reply #721 on: Fri, 18 July 2025, 06:59:54 »
Razer blade 16,
This is the dumbest design ever. Absolutely disgusting.
There're reasons laptop keyboards have had tape under the keys to prevent the fan sucking air through it.
1, DUSTTTT,  now your keys will bind over time, because of dust and oily air ingress. Gamers also eat things like doritos and cheetos.
2,  Imagine pouring some liquid on the keyboard, Now the FAN will suck that cococolo throughout the motherboard. NICE..
Razer is fn stupid,  Seriously, they've gone full re****.
Worst lifestyle brand on the planet, the fact that they and the likes of Klipsch and Marshall (speakers) make any money is proof that Idiocracy is today the norm. Humanity is entirely hopeless.
5090 mobile GPU is $5000 for the same performance as a desktop 5070ti (non super).
Offline Leslieann
« Reply #722 on: Fri, 18 July 2025, 13:45:42 »
Most peripherals on a desktop are still USB-A.
Logitech in particular has been dragging feet on USB-C for ages. Get them and HP onboard with supplying Type-C to Type-C cables and you'd probably see a shift in the market pretty fast. Peripheral companies are traditionally VERY slow to adopt new standards, probably due to lead time and molding costs.  And while you see it as just a cable change for them it means new packaging, manuals, support staff training, product codes and ultimately new cables. They also need to be early rid of current inventory before they even start that.
As for costs and such, while it seems like  they could easily just put type C port instead of type A (even if only USB 2 or USB 3 speeds) type-C doesn't stack like type A ports do so they would need to rebuild the whole rear I/O including new port molds and wiring (possibly daughter board)  to add a few more and I don't think anyone has done so yet. Currently you could probably get three type-C and three type A along with display, audio and ethernet and while that may appeal to you, most people want more than 6 ports, let alone 3 type A. It also means a lot more traces as Type C requires a lot more wires. So yeah, it's a cost issue.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Online tp4tissue
« Reply #723 on: Fri, 18 July 2025, 18:52:07 »
Got another one, Don't love it, but this is supposedly a better chipset than jhl7440.
Tp4 isn't Loving the design. We'll see how well it performs.  The top has no screw, so will probably have to zip tie it for proper tension.
Online tp4tissue
« Reply #724 on: Sat, 19 July 2025, 09:24:55 »
The biggest problem with SSD enclosure is,  Most people buying them don't use peak SSDs, and/or don't have thunderbolt.
So you don't know what you're getting, because the reviews are not thorough. The expectation is entirely unclear.
There is a huge gap between real world perf 16gbps, 22gbps, 30.4gbps, 40gbps Chipsets, and yet they're all sold under the 40gbps banner.
You can't even hit 40gbps unless you go to the latest Thunderbolt 5,  which again, most computers don't have.
Online tp4tissue
« Reply #725 on: Sun, 20 July 2025, 13:36:41 »
It's weird, why do some some new laptops feel slow, even though they are by spec way faster than desktops of yesteryears.
Online tp4tissue
« Reply #726 on: Sun, 20 July 2025, 15:33:59 »
Ok after playing with all the various enclosures on the market.
THEY ALL kinda suck, and are full of compromises.
Heat issues, disconnections, lanes, multi-chip handoff, connection handoff, loud fan, dumb fan, smart fan, no fan.
SOME of them do have high performance, but only under very specific circumstances. No enclosure maximizes all connections across the board.
It's crazy because some of these are $100 a piece. Ridiculous to have a $100 not "Just Work."
The only minor positive is, well, they are all significantly faster than external drives that come from the base brands.
Overall, Tp4's mind is unraveling as he ponders wth these designers were thinking.
>:D
Offline Leslieann
« Reply #727 on: Sun, 20 July 2025, 15:59:54 »
Crap UEFI settings, garbage memory/drives and insufficient cooling/ram of not just the CPU but also other parts. One or two of these and you might be okay but they add up fast.
You are right though, a modern laptop should in theory compete with desktops of a few years ago (minus GPU of course).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #728 on: Sun, 20 July 2025, 16:05:52 »
True that.
Don't worry, be happy.
- D Trump 2026-10-24
Online tp4tissue
« Reply #729 on: Sun, 20 July 2025, 17:58:04 »
313722-0
Okookok.. sold under qwiizlab, silver color one is onsale for $60,  other amzn flippers go from $75-100.
This 1 is the 1, Tp4 hates-the-least.
It's asm2464pd. 2025 Latest firmware out of the box.
The issue with the Fan'd enclosure models, which are more compact/smaller, Well, they're the same price $60, but when the fan eventually breaks, are you going to go hunt down and buy another fan that fits, and dig everything out, and replace it?  Without the fan, the smaller enclosure (heatsinking) is well undersized. Asm2464pd runs super hot, lots of reports of older small boxes overheating + disconnecting.
313724-1
OWC 1M2, a similar passive enclosure, but much more expensive, $100, slightly better designed heatsink, but overall, same shtick, not worth the upcharge.  The overall Fin and bottom plate design is better, but the clamping is less good vs the qwiizlab one with 4 screws. You see how in the picture, the front end has 2 bevel wedges. These are Small and made of aluminum, not only could you Snap these when dropped, it also means the load is more uneven as it creates a lever force against the internal pcbs.
313726-2
Finally, Avoid Tool-Less designs, they don't impart proper clamping force. Not enough to ensure the silicone pads are TIGHT.
Observe the little spring balls latches, if you use the right amount of silicone thermal pads, it will easily pop those balls, making the whole endeavor insecure.
The SCREW models, you can load up as much silicone as you like, and it's 100% fine.
313728-3
Online tp4tissue
« Reply #731 on: Tue, 22 July 2025, 07:28:06 »
Tp4 can tell the difference between 100hz and 120hz in racing games.  There is 100% a smoothness and responsiveness difference.
Online tp4tissue
« Reply #732 on: Tue, 22 July 2025, 08:31:52 »
Why are people so against DSP..
If a song goes through 100x DSP in production just to get to your door, what's 1 more DSP to normalize the speaker's frequency response?
Online tp4tissue
« Reply #733 on: Wed, 23 July 2025, 07:45:54 »
Everytime you listen to a soundbar, you're dying, in exchange for poor quality sound.
Online tp4tissue
« Reply #734 on: Wed, 23 July 2025, 16:37:30 »
Ok, if any one IS buying Demon-speakers.
JBL authentics wayyyy gud'r than Marshall equivalent.
Marshall also has jank electronics.
Bass is much more clear with the passive radiator.  The port tuning on the smaller Marshall of comparable size doesn't come close, too small of a port.
Stereo separation is non existent, so not much to say bout that.
But if you put it on a large wooden table, the bass hits pretty decent.
Tp4 finds the main drawback to this class of speakers is going to be positioning, as the bass floor reflection really muddies the mid tones a bit.
313740-0
313742-1
Offline Sniping
« Reply #735 on: Wed, 23 July 2025, 16:54:21 »
bluetooth speaker? jbl flip is an amazing product for that. I just have it in my bathroom for shower music and take it with me when I gotta bring it out. super good value and well built, very portable.
« Reply #736 on: Wed, 23 July 2025, 19:10:06 »
« Last Edit: Wed, 23 July 2025, 19:11:39 by noisyturtle »
« Reply #737 on: Wed, 23 July 2025, 19:11:27 »
Welp, the gang's all here! Gonna begin the deep clean & rebuild soon. A lot of used parts here, I'm a bit worried about this mobo since it was not tested  :eek:
Cooling and wattage will improve greatly. I'm looking forward to seeing how the sound card performs with a 7.1 setup  :thumb:
Online tp4tissue
« Reply #738 on: Sat, 26 July 2025, 05:11:44 »
This is really weird that they do this.
So, ADS Pro are IPS-panels, but TV manufacturers will mix them into mostly VA-panel model series.
IPS is somewhat better for daylight viewing, but its contrast isn't nearly as punchy as VA, for "HDR IMPACT."
Why not create 2 separate lines so people don't get confused.
Online tp4tissue
« Reply #739 on: Sat, 26 July 2025, 17:28:14 »
PC driving wheel,
Gave up on it years ago,   Worth another shot?
Offline Sniping
« Reply #740 on: Sat, 26 July 2025, 18:05:10 »
PC driving wheel,
I think there's more choices available now, I believe Moza is a new and cheap direct drive offering? I think there's only some PC compatible models so have to check. It's something worth scouting for used possibly.
« Reply #741 on: Sun, 27 July 2025, 02:19:00 »
What is a good tool for stress testing temps?
Right now I run 3DMark and monitor Core Temp while it is running, but is there a temp-specific software?
Online tp4tissue
« Reply #742 on: Sun, 27 July 2025, 10:12:00 »
Speaker reviews, that don't mention any form of objective measurements whatsoever. 0, none.
This is why people buy sound bars.
« Reply #743 on: Sun, 27 July 2025, 15:43:03 »
Klipsch and Audioengine is all you need to know about desktop/shelf computer speakers. Nothing else is worth the money and is a waste of time. Just spend the extra and be happy with the best.
Online tp4tissue
« Reply #744 on: Sun, 27 July 2025, 15:54:15 »
Klipsch has a distinct V signature "most of the time." That's a taste issue, they at least have competent crossover and flow directivity designs.
JBL is very strong of late, but they don't focus on a signature, their products can either be very transparent or very colored.
Audioengine is also hit or miss. Does not have a strong design pedigree.
Definitive Technologies,  very strong pedigree, strong design, but poor brand management, no one knows they're good.
Mofi has Speaker Jesus - Andrew Jones,  whatever he makes, solid.
« Reply #745 on: Mon, 28 July 2025, 21:41:14 »
formatting a 4Tb hdd taking all day zzzzzzzzzzz
I haven't even started the cloning process yet, dyin' over here
Online tp4tissue
« Reply #746 on: Tue, 29 July 2025, 07:37:32 »
Matter enabled smart keyboards,
Great, I love how my keyboard can join the wifi botnet. What a wonderfully smartttt idea.  :eek:
Online tp4tissue
« Reply #747 on: Tue, 29 July 2025, 07:40:18 »
Corsair advertising, DSLR quality lvl streaming face/webcam,  uses Sony starvis 2 sensor,  u know, that thing they put in dash cams. DSLR quality bro, trust me, DSLR..rrrrrrr
Online tp4tissue
« Reply #748 on: Tue, 29 July 2025, 09:19:53 »
Just started Wuchang,  runs fine, what are people complaining about ?
« Reply #749 on: Tue, 29 July 2025, 16:47:06 »
The new Coolermaster CPU V8's are so sick, makes me wanna do a full engine-themed build
