Author Topic: Will constant key press (race car gaming) damage switch spring?  (Read 7060 times)
Offline AmigaDisk
  • Formerly ohm-ish
Hi
I just got a Keychron Q3 max. Very nice, and most expensive keyboard for me so far
So I'm already a bit protective of it
I'm playing a race game a lot where I hold down one key for acceleration almost constantly
Won't this easily damage the switch spring, I mean weaken the spring tension?
It's not an issue yet and I must say I haven't had an issue with it before.. just being cautious this time
« Last Edit: Mon, 16 June 2025, 06:33:27 by AmigaDisk »
Offline Leslieann
Re: Will constant key press (race car gaming) damage key spring?
« Reply #1 on: Mon, 16 June 2025, 06:36:06 »
It can but it will take years.
Since you have hot swaps, you can always just replace the spring or the switch later.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline AmigaDisk
  • Formerly ohm-ish
Re: Will constant key press (race car gaming) damage switch spring?
« Reply #3 on: Tue, 17 June 2025, 02:55:17 »
hehe ok :)
Offline Leslieann
« Reply #4 on: Tue, 17 June 2025, 06:22:07 »
You will die before that key dies. :D
Springs can go flat, seen it a few times on older used boards.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #5 on: Tue, 17 June 2025, 20:55:05 »
Those were probably stored with the key held/pressed down by the cord or stuffed in a box.
Spring steel absent corrosion remains pretty decent over time.  If it does die, it will die of neglect on part of the OP before it dies of metal creep.
