Author Topic: How muhs' R^m does gekhr use.  (Read 7238 times)
« on: Wed, 13 August 2025, 13:34:04 »
Tp4 got
32gb and 64gb machines
No 96gb yet.
Tp4 suspects the Next Ryzen might really open up memory OC on AM5.  Because the hynix dies are ready to do 9000, but the imc on zen 5 can't really go above 6400, 6600 is golden sample already.
:D
Re: How muhs' R^m does gekhr use.
« Reply #1 on: Wed, 13 August 2025, 21:19:29 »
I had 32gb for 13 years, but was forced to downgrades to 16gb because I wanted a cool motherboard that for some stupid reason cannot run the RAM that is right there on the compatibility QVL. It is really pissing me off and I do notice a difference in performance. I've now purchased 3 sets of memory, and NONE OF THEM WORK!
« Reply #2 on: Wed, 13 August 2025, 21:23:18 »
Use 2T command rate instead of 1T if you're at 2400mhz.
Offline Leslieann
« Reply #3 on: Sat, 16 August 2025, 07:41:09 »
32gb in desktop, 32gb in the file server, 16gb in the laptop and 12 in the media server.
I considered 64 for the latest desktop but I looked at ram draw and my system rarely even crosses 24gb, let alone coming close to 32.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #4 on: Sat, 16 August 2025, 07:48:52 »
We all know LLann secretly has a 1TB ram server hidden in her basement running nefarious hookups for a state enemy.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #5 on: Sat, 16 August 2025, 07:53:41 »
Used 32GB for long time, but had to upgrade to 64GB because some software would crash (video editing and 3D rendering).
VRAM is much more of a problem tho. Running AI on the GPU can require ludicrous amounts of VRAM, crashing even on a 32GB card.
A Ghost From The Past
Offline smarmar
  • It don't mean a thing if it ain't got that swing
    • Short Stories from an Old Library
« Reply #6 on: Mon, 01 September 2025, 20:40:10 »
I'm sitting back here with 16GB in the 2015 Alienware daily driver, 16GB in the gaming rig, and 16GB in the laser show programming PC.
Oh, I almost forgot the 2015 iMac that's too slow to do much, other than for online D&D sessions. It might have 8GB.
1992 IBM Model M | Tesoro Durandal[Browns] | Hi-Tek Series 725[Space Invaders] | Tandy Enhanced[Sliders] | Dell Quiet Keys | Mitsumi[AT]
