Author Topic: Raptrops shopping Christmas 2025  (Read 14197 times)
« on: Fri, 17 October 2025, 09:03:28 »
Which Laptops are ya'll lookn'  @  this holiday?
 :cool:
Re: Raptrops shopping Christmas 2025
« Reply #1 on: Sun, 19 October 2025, 13:19:18 »
Can't find modern laptops , that are not giant g4m3r laptops that have barrel plugs.
It seems all the smaller portable tops have gone USBC.
This is not good. USBC power delivery relies on very complicated controller ICs for logic because it has to deal with different voltages and current restrictions. These burnout and are not very durable.
Offline ivanh98
« Reply #2 on: Sun, 19 October 2025, 17:08:07 »
framework laptops.
« Reply #3 on: Sun, 19 October 2025, 17:31:48 »
Wayyyyyyyy overpriced, you can support their philosophy, but their product is cray cray priced.
Offline Leslieann
« Reply #4 on: Sun, 19 October 2025, 19:28:56 »
I don't support new laptops except Framework.
Just no point.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #5 on: Sun, 19 October 2025, 19:50:10 »
Those are interesting. I have been assembling my desktops piecemeal for 25 years.
Are the Framework keyboards any good?
- D Trump 2026-10-24
Offline Leslieann
« Reply #6 on: Mon, 20 October 2025, 21:34:08 »
I haven't heard any complaints but I have seen people trying to mod them with stiffeners, Thinkpad keyboards, mechanicals and RGB.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #7 on: Mon, 20 October 2025, 22:23:58 »
It actually isn't that hard to make a stiff keyboard, they just refuse to put bigger and more screws where it'd be "less pretty" THE MIDDLE. Which is dumb, cuz it's the bottom.
Offline Sniping
« Reply #8 on: Tue, 21 October 2025, 16:06:41 »
gaming laptop still isn't on my list yet. I've actually been considering a steam deck recently though if thats similar. I've been using my friends and I think it's a pretty decent experience.
« Reply #9 on: Tue, 21 October 2025, 16:48:48 »
RDNA 5 hasn't really come to mobile yet, you'll want to wait for that on the next handheld. Might be pretty expensive.
Offline Sniping
« Reply #10 on: Tue, 21 October 2025, 17:22:48 »
it'll take a while before it gets released, integrated into a new model, and gets sold for cheap on second hand for me to buy.
Offline Leslieann
« Reply #11 on: Wed, 22 October 2025, 09:15:44 »
Another note regarding XPS which I only heard about today,  Dell is no longer ensuring that their systems are 100% Linux compatible, particularly XPS.
While this may not have mattered to Windows users in the past the death of Windows 10 and the price crash of non-Win11 compatible systems means that maybe that should be a consideration since it's possible Win12 or 13 may not also be compatible with current XPS models and that means they won't work on Windows or Linux and that will make them worth their weight in scrap metal.  Can't happen? It already has, remember the Surface RT tablet, an ARM based Windows tablet? Linux users were drooling at the idea of a quality ARM tablet they could buy for cheap once MS dropped support for it, unfortunately for everyone they released a Bios update shortly before the end that locked out Linux from being installed.
This also happens to wireless routers, old routers are pretty worthless, but ones that use open source firmware tend to hold value and can be used for far longer. One model actually sold for retail price or higher for probably a decade after it stopped being produced simply because it had so many alternative firmware with support than any other wireless router you could buy and this was long after we had transitioned to much faster wireless bands.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #12 on: Wed, 22 October 2025, 09:38:36 »
The XPS has this weird ceramic coating on the keyboard now. it's just weird. And it noticeably makes the keys pop up slower because of the extra mass.
« Reply #13 on: Wed, 22 October 2025, 13:30:33 »
I miss e-machines. My Dad has an old one with a fold-out keyboard he uses just for writing and sending emails. It is just so small and convenient.
Offline Leslieann
« Reply #14 on: Thu, 23 October 2025, 11:15:57 »
You can get all sorts of small computers these days.
From large to small...
Most major manufacturers make toaster size boxes these days as small or smaller than old Emachines.
Example https://www.newegg.com/p/3F8-0005-00320
You can even build desktops this size and about half this size using ITX parts, my old gaming system was smaller than an old Emachine even with a GTX 1070 GPU. While you can, these are often somewhat more costly and definitely need research to ensure parts compatibility and sufficient cooling if you D.I.Y. it. My newer one is about the same size in volume as an old Emachine yet it has a Radeon 9700 XT.
Dell, HP and Lenovo both offer SFF boxes 6x6x2inches. Businesses LOVE these.
For example https://www.newegg.com/p/3F8-0003-00X86
And then you have the NUC and ultra small stuff, 4x4x2inches. You can even get these in kits where you add memory and drives to them.
https://www.newegg.com/p/N82E16883151449
Note, many of these are poorly made and do have a slightly shorter lifespan (4-7 years or so), usually due to poor thermal design. Despite that drawback, people love these.
You can even get keyboards now with laptops built into them, though these are few and far between and have some serious compromises.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #15 on: Thu, 23 October 2025, 11:17:57 »
The boards warp when it gets hot, so the solder underneath the cpu cracks over time.  Can't fix without re-balling.
« Reply #16 on: Thu, 23 October 2025, 17:47:02 »
Oh I meant more those tiny laptops that are purely functional for lite travel work. Like a cross between a laptop and a tablet, perhaps e-machine was the wrong term.
The one my Dad had a keyboard that gull-winged out when you opened the laptop to a full sized kb, yet could fit in the front pocket of a backpack.
Offline Leslieann
« Reply #17 on: Thu, 23 October 2025, 22:57:14 »
Check out GPD, they're pretty much the only ones making tiny laptops these days.
https://gpdstore.net/product-category/gpd-handheld-gaming-pcs/
Also a modern 13in is the size of older 12in (or smaller), though I always liked them a bit smaller..
There is a couple small HPs however they're so low power (M class at best) I'd consider it disposable and pretty much only going to work well with linux and light duty.
There is a sneaky one though.
You may have seen the 11.6in Lenovo 100e, they're usually Celerons or ARM and often running Chrome, but there was a (very, very) limited 3rd gen 100E run for education with Core I3 6100u, removable ram and ssd (m.2 sata, not NVME). They don't come up on Ebay very often and even finding info on them is difficult but they do exist (I have one). And while the laptop is hard to find, the only unique part is the motherboard, everything else is compatible with the Celeron and ARM models, so the most commonly damaged parts are plentiful.  I got mine 3 years ago (?)  for $80(?) it had no drive, ram or battery, so while they're cheap, they are not plentiful.
https://icecat.biz/p/lenovo/20gb000qus/thinkpad-laptops-thinkpad+11e+-3rd+gen-30812164.html
I should note, yes it's a 6th gen processor, Intel was pretty much treading water for quite a while and for basic computing, even 6th gen is usable, especially if you install linux.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #18 on: Fri, 24 October 2025, 08:56:48 »
Hesitant, should we skip this year, because AMD's releasing some mega GPU upgradz 2026.
« Reply #19 on: Tue, 28 October 2025, 13:54:40 »
HP has the win this year, tech side of things, because all their oled models have Variable Refresh. Most other camps don't have that.
This matters, because most of these low weight laptops can't get super high frames, and so they hover around that 80-120 range
Offline Sniping
« Reply #20 on: Tue, 28 October 2025, 14:00:07 »
how's noise on gaming laptops coming out recently? I feel that they're one of the last mainstream devices that still run quite loud. handheld consoles have always been able to avoid this problem somehow but gaming laptops always seem to have been pretty noisy.
« Reply #21 on: Tue, 28 October 2025, 14:44:10 »
They're all pretty loud.  The latest AMD max 395 handheld gpdwin is as loud as any gam3r laptop.
The steam decks class are quiet only because they use very little power, and are slow.
« Reply #22 on: Thu, 30 October 2025, 11:58:05 »
Okokokok,  Let's extrapolate.
8060s, in the the new ryzen 395+ apu, does about 18000 passmark (1080ti lvl)  using 55 watts.
This is RDNA 3.5
If we go to RDNA 4, there's at least 10-15% performance per watt increase. If we go to RDNA 5, there's another 15-30% potential.
So, REALISTICALLY,   it's very very possible, we see 15000-18000 in a 40watt laptop 14 incher.  Certainly 60watt 16 inchers will do it.
RDNA 5 is going to be a huge game changer.   Because You don't need much more for a 2.5-2.8lb laptops, there's no reason to have more horsepower than that.
It's probably going to require zen 6 or zen 7 to even out, but still, the timing's fine.
If you need more horses than that, then the BULK weight will be the power brick, at which point, just GO HOME and play your desktop PC.
« Reply #23 on: Fri, 07 November 2025, 18:33:07 »
Ok, so Target for THIS YEAR, buying,
For Thin/portables,  is HX370 AMD APU (and above), which has the 890m (a 1060 mobile basically),  $1100ish
    - 890m will run Hades 2 @ 1920x1080 @ nearly 300fps.
   - You can get lunar lake, but understand Lunar lake is still anemic for long haul and especially driver support.
For Sub-G4m3r,  any cpu + 5060/5070, $1200,  (Not enough vram)
For G4m3r, any cpu + 5070ti / 5080, $1500
Ideally, you'll need something around 1080ti / 1660ti / 2060 lvl to play Hades 2 at Max settings engine 360fps.
Sky's the limit if you want to use SSAA.
