Author Topic: Best linear switch nowadays (2026)  (Read 11904 times)
Offline phinix
« on: Tue, 09 June 2026, 10:39:16 »
Last few years I've been using Oil Kings.
I dont follow new releases - what is the best linear switch now?
Pre lubed, ready to use.
Offline pixelpusher
Re: Best linear switch nowadays (2026)
« Reply #1 on: Tue, 09 June 2026, 13:57:58 »
Hard to say what is "best" because of personal preference.  But I put my money on HMX when it comes to linear switches lately.  HMX is all about loud and clacky sound profile, though, and that's not for everyone.  They do offer a few lower pitched switches. You will have to look over the details of the plastics used, as they are usually pretty good at documenting the plastics used and the sound qualities of their switches.  MAaaaybe BSUN for lower pitched, but that can be hit or miss.
« Last Edit: Tue, 09 June 2026, 14:16:54 by pixelpusher »
Offline phinix
« Reply #2 on: Tue, 09 June 2026, 16:45:12 »
I prefer lower sounds. So oil kings gonna stay then.
Offline PandaKB
  • Ergo Evangelist. Your wrists can thank me
    • PandaKB
« Reply #3 on: Tue, 14 July 2026, 20:27:04 »
It’s crazy how many people are still rocking Oil Kings, even though I’ve personally never tried them! They definitely have a massive, loyal fan base for a reason.
Offline tavapataor
« Reply #4 on: Tue, 14 July 2026, 22:07:37 »
Sure love the KBDfans Roller V2s.
Offline phinix
« Reply #5 on: Wed, 29 July 2026, 08:31:43 »
I tried Gateron Smoothies - jeez, what a crap of switch - I dont know what is wrong with it, but somehow it is very sluggish, it says its 40g, but feels heavier and cap doesnt return as quick as it should, like they were over-lubed. Like pressing switch submerged in thick engine oil...
It says it has double stage spring - Idont know how this is different from regular spring - does it feel like there is higher force on top, then easier in the middle and then more force at the bottom out?
Anyone, I personally am very disappointed in those - I was looking for a nice lighter version of Oil Kings and ordered these - shoked how they felt after ount just 5 of them, took off straight away.
Terrible.
I guess I better go back to Oil Kings and if I want lighter, just order some 67g or 70g 22mm long single stage springs, to have it lighter but still responsive in terms of bottom out returns.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #6 on: Wed, 29 July 2026, 16:38:06 »
I like the DUROCK Sea Glass as a lighter alternative to the Oil Kings
A Ghost From The Past
Offline BossKeebs
« Reply #7 on: Fri, 31 July 2026, 01:42:19 »
HMX makes some nice switches. Try those.
Offline phinix
« Reply #8 on: Fri, 31 July 2026, 03:23:52 »
I was going to try those HMX Swifts, but was so disappointed in Gateron Smoothies, then decided just to buy different springs and mount them in Oil Kings.
Haven't done it yet, but tired of buying batches of switches to try and end up selling them on ebay losing money...
Offline phinix
« Reply #10 on: Sat, 08 August 2026, 14:37:08 »
They make springless now.
Really? which ones?
Offline tulip
« Reply #11 on: Tue, 11 August 2026, 12:14:36 »
i like the way the sea salt smoothies feel though i haven’t tried the regular smoothies for comparison. i don’t think the sea salt smoothies feel sluggish!
Offline phinix
« Reply #13 on: Wed, 12 August 2026, 13:47:01 »
I wonder how they gonna control/change force. Maybe it could be adjustable?! That would be something.
One day I want heavy linear, 80g, next week, light 55g ...
« Reply #14 on: Sun, 23 August 2026, 01:32:05 »
Maybe try out some Keygeek stuff if you like deep, Y3s for exemple are dirt cheap and in my opinion significantly better than Oil Kings.
But there's a ton of options depending on how muffled you want it, Little Luckies, Goldens, Butterflies, Y2s/SU Color V2s...
Offline Shimene
    • Web site
« Reply #15 on: Thu, 10 September 2026, 14:01:43 »
I hadn't really looked into Keygeek before. The Y3s sound interesting though, especially if they're noticeably smoother than Oil Kings. I'll have to give them a try sometime.
Offline pixelpusher
« Reply #16 on: Fri, 11 September 2026, 13:52:51 »
I still have a gripe with keygeek though.  I’ve used 3 different keygeek sets, including the Y3s and they all develop a little tick.  You can make it happen by tapping on the bottom edge of a keycap.  It’s a rather annoying high pitched tick that doesn’t sit well with me.  I’ve desoldered 2 of 3 boards with keygeek. I’d say if you try them out, make sure to use a hotswap board.
Offline Sup
« Reply #17 on: Fri, 11 September 2026, 16:27:49 »
Gateron Clears and never look back or just switches in general with 30g 35g. Once you make the switch you can never go back because your fingers are in heaven.
current
Coming soon
Offline phinix
« Reply #18 on: Fri, 11 September 2026, 19:32:33 »
Gateron Clears? Are they nice and smooth? prelubed? I prefer stock, so needs to be prelubed.
Offline phinix
« Reply #19 on: Fri, 11 September 2026, 19:33:32 »
I got those gateron milky switches and swapped their weird double stage springs with TX super long 22mm 67g. Pretty nice. I almost cannot tell the difference between 67g and 80g.
Offline Sup
« Reply #20 on: Mon, 14 September 2026, 03:33:28 »
I would try the latest Pro versions. They aren't milky, but they are buttery smooth, and for me, it's more the weight at this point. Everyone kinda reached the smoothness level unless you buy some crazy no name switch brand. Beyond a certain smoothness, you don't really notice a lot, and over years of use, it will smooth out even further. But it's more for the lightweight. embrace 30-35G and you can never go back to heavy switches.
current
Coming soon
Offline Shimene
    • Web site
« Reply #21 on: Sat, 19 September 2026, 09:45:03 »
Terrible.
If you decide to check out Gateron Clears, make sure to get the G Pro 3.0 Clears! The original vintage Clears came unlubed, but the Pro 3.0 version comes factory-lubed right out of the box and is super smooth.
Just a heads-up though: 35g is extremely light compared to Oil Kings (55g actuation / 65g bottom out). You might end up getting accidental keypresses just by resting your fingers on the board. Going with your idea of spring-swapping your current setup might honestly be the safer and cheaper bet!
Offline iri
« Reply #22 on: Wed, 23 September 2026, 15:04:47 »
lighter switches don't spring your fingers to jump to the next key
-Ray Bradbury
Offline phinix
« Reply #23 on: Wed, 23 September 2026, 18:44:41 »
That is why I always swap springs in my switches to 22mm single stage 85g :D
Offline foamicide
« Reply #24 on: Fri, 16 October 2026, 05:07:41 »
always been more into tactiles but when i do use linears im almost always using HMX xinhai's, super nice sound and pretty good stock smoothness.
most HMX switches are great honestly especially for the price.
Offline SKYP.Lab
« Reply #25 on: Sun, 18 October 2026, 02:52:42 »
Did the Smoothies still feel sluggish after the 85g swap, or was it the stem itself?
Offline phinix
« Reply #26 on: Tue, 20 October 2026, 02:58:21 »
No, it helped, I mounted them on one of my keebs, all good.
