Author Topic: Selfone cases.  (Read 3214 times)
Selfone cases.
« on: Thu, 02 July 2026, 17:09:16 »
It's upsetting that they're made out of TPU,
Which deteriorate over time, and turn into a goopy oily mess, as the oil starts to migrate out of it.
Apparently, you can't get the oil back in without high temp+ Pressure, which would destroy the case.
This is a HUGHHHGEe,  waste of resources. It shouldn't be like this.
>:D
Re: Selfone cases.
« Reply #1 on: Thu, 02 July 2026, 23:10:33 »
Re: Selfone cases.
« Reply #2 on: Fri, 03 July 2026, 04:18:31 »
Cell phone cases (or the enclosure they come in !!) should come with metal loops for wrist straps — like every cell phone and camera before the iPhone did, so that people wouldn't drop them in the first place.
« Last Edit: Fri, 03 July 2026, 04:22:42 by Findecanor »
Re: Selfone cases.
« Reply #3 on: Fri, 03 July 2026, 06:43:40 »
Also bad for the market is old stock cases, basically if it was injected 5 years ago, wev got a few more months before it becomes greazy.
Re: Selfone cases.
« Reply #4 on: Sat, 04 July 2026, 05:49:54 »
Cases should be entirely made out of PC, THEN they should sell liners of soft TPE stripes which is the only disposable section.
Also unlike TPU, PC can be made to resist plastic discoloration for much longer.
Re: Selfone cases.
« Reply #5 on: Sat, 04 July 2026, 06:41:17 »
I am still using a cell phone that is 7 years old - much older than normal. Why does a case need to have a longer life span than the item it is protecting?
- Plato
Re: Selfone cases.
« Reply #6 on: Sat, 04 July 2026, 07:27:09 »
People are buying 10-20s of cases per phone, due to discoloration etc.
This is a ridiculous amount of waste.
The other portion is,  TPU having a shelf-life,  you can just leave it on the shelf, and it'll still start to become oily and unusable, because it's inherently not a stable mix.
So everything that is stored, is extra waste.
