Author Topic: Bough new lapprr (Pretty good sale)  (Read 6125 times)
« on: Mon, 21 September 2026, 09:37:53 »
Dat Acer 16 inch on sale $999
3K oled 2880x1800 (amoled?),
intel 358H (B390 igpu)
16gb ram,
1TBssd
@ bestbuy
So, Tp4 has been waiting for this chip for a long time,  benches around 9500 on passmark, which means it's ALMOST as fast as an nvidia 1060  @ 3.5lbs.
The issue Tp4 had with the previous 140v  from the 258v processor, is it's just not fast enough for HDR tonemapping.
IDEALLLLLY, Tp4 would like a 1660ti lvl power in an integrated setup, buhhhhh that doesn't fit the wattage as of yet.
Probably next generation.
As a portable work maboob, solid.
Tp4 was thinking about the 32G,  but honestly, for $700 more ? IDK.....
Should arrive tomarrow.
:D
Re: Bough new lapprr (Pretty good sale)
« Reply #1 on: Mon, 21 September 2026, 10:53:40 »
32G
$700 more ?
Prices for storage have gone completely insane over the past year.
I put together a legit but rather modest build last December - appalled by the prices THEN - but they have easily doubled again since then.
Thanks, Republicans
- D Trump 2026-10-24
« Reply #2 on: Mon, 21 September 2026, 13:41:22 »
Fohat, you must realize by now, the 2 parties are identical.
They are equally responsible for the current Ram-pocalypse.
« Reply #3 on: Mon, 21 September 2026, 16:14:32 »
Having trouble remembering a war that the Democratic Party started.
The Vietnamese people had been struggling to eject France for years before Kennedy stupidly decided to take to take it off deGaulle's hands, and Clinton was helping the UN in Bosnia.
« Reply #4 on: Mon, 21 September 2026, 16:35:18 »
Clinton, Kosovo, Bosnia, Haiti
Obama, Libya, Yemen, +cyber warfare, stuxnet on 1rnnn, damaged centrifuges>
Biden,  UKRANNNNNINNINI
Either you're blind, or you're just being american, Blue-Maga.
« Reply #5 on: Mon, 21 September 2026, 21:06:51 »
False equivalencies are the hallmark of MAGA double talk.
« Reply #6 on: Mon, 21 September 2026, 21:40:17 »
Fohat, the problem is you're not well read enough to grasp the geopolitical reality,  but you're smart enough to know you've been wrong about everything.
There's nothing complicated with the world,  the cognitive conflict likely occurs due to early dementia, the inability to admit ignorance or to change mental tracks..
« Reply #7 on: Tue, 22 September 2026, 15:39:05 »
Testd' some gamz.  :D
Runs Hades 2, 1080p @ 240-310fps
So,  clearly NOT as powerful as the ol' 1660ti mobile, which can lock 360fps with 8% headroom, but it also doesn't use 80watts.
« Reply #8 on: Thu, 24 September 2026, 11:24:20 »
The System is fighting itself.
Tp4 believes the way the power balancer works is too smart for its own good, leading to more load imbalance.
Wish they'd have a MANUAL balancer,  Just let the user determine how many Jigers the GPU vs CPU should have.
And a Manual core conductor would be interesting as well.
The screen is prettty gud',  Buh, hrrm.. IDK, it has raised black floor,  I can understand why they chose that for a laptop, but it's not as nice for movies, because it kills off quite alot of shadow detail.
Specifically this is the RGB values representing between 0 and 0.5 nits,  You'd be surprised how important that is.
They're using a samsung panel, so it's not a capability issue, samsung dithering is state of the art, so this is a deliberate choice, one that Tp4 is not enamored with.
The 120hz is gud, gamz look great.
This laptop has a pretty high power allowance for its size, 70watts,  but it heavily gates it, even while plugged in, which Tp4 mentioned in opening statements.
« Reply #9 on: Thu, 24 September 2026, 14:38:07 »
This is ridiculous
Tp4 reformated the drive from scratch, after jumpping through all these weird bios hoops which lock out.
Video Renderer went from 42ms to 32ms.  THat's insane, WTH was it running in the background.
« Reply #10 on: Sat, 26 September 2026, 16:28:44 »
Why do laptops come with "color profiles"  if they just mess everything up.
And most people have no idea how to even use them.
For example.  I've got a P3 profile here, and it under saturates,  there's no legitimate use for it, the display is more accurate without it.
So if someone who's never measured anything, just clicks on it and think, oh this must be accurate, well, it's not, not even close.
/tru angre.
« Reply #11 on: Sat, 26 September 2026, 20:42:28 »
Cries in Drmless SSD.
Brb, gonna go killz hisself.
« Reply #12 on: Mon, 28 September 2026, 09:04:41 »
Geekbench cheaters,  Meanwhile, Tp4 thinks to himself, he must also cheat, turns on AC cold feed.
« Reply #13 on: Mon, 28 September 2026, 16:07:00 »
Laptop speakers, honestly, Headache.
« Reply #14 on: Thu, 01 October 2026, 17:17:52 »
So, if you leave a controller/ mouse transmitter in the laptop,
That actually uses power. Depending on device, 0.1-0.4 watts.
It may also prevent the ac supply from entering deeper sleep mode.
« Reply #15 on: Sun, 04 October 2026, 08:42:41 »
There are so many good things about this laptop.
So many quirks Tp4 has to work around,
Does Tp4 keep it, or look elsewhere.
The only other viable options at the moment for 358h chip are much heavier laptops.
« Reply #16 on: Tue, 06 October 2026, 07:57:00 »
Bah, Tp4 is returning this lappr,
Is'' Ok... buh, honestly, the throttling is too difficult to manage.
The heatsink does not truly allow this pantherlake to operate @ its full potential.
Otherwise a fantastic laptop @ a gud' price.
The only option other than this one is a pretty heaffty build. Hrrrm...
« Reply #17 on: Thu, 08 October 2026, 09:54:58 »
Overall, Tp4 would say b390 is Great despite not being able to stretch its legs in most current available chassis due to cooling/power constraint.
As of current, In far too many games/applications, the thing pulls back on performance even though the system is well within the thermal envelope.
Whatever comes after b390 may finally be Excellent.
« Reply #18 on: Tue, 13 October 2026, 22:46:21 »
Dell charging ridiculous prices for their b390.
In what universe is tandem oled panel worth $1000 premium.
People are stupid.
« Reply #19 on: Mon, 02 November 2026, 06:51:42 »
Sigh...
358h  b390 is the best chip intel has released in ages.
Yet, supply is constrained because they've moved 18a to produce xeons instead of pantherlake.
So...  we got like almost no options in the laptop market.
Only 2 models right now that's remotely reasonable, the $1300-1500 omnibookx, and $1000 acer.
The other ones are absolute junkkk, they either overheat or just caps tdp super low, while charging people $3000.
It's insane, there's so much potential here, and ACER is apparently the only one pushing the envelope.
The $999 swift 16 though, if they only made the heatsinks about double the size, would be more sustainable,  as is, it's on the hot side, and you have to resort to tricks to keep it topped out.
The omnibook is heavier than gaming laptops and have a way cheaped out screen...  This is unacceptable.
« Reply #20 on: Mon, 02 November 2026, 08:04:59 »
Still even at $1000, these laptops are not good deals.
They really should be $600-700 or so.
« Reply #21 on: Tue, 03 November 2026, 00:24:00 »
g4m3r laptops are the only ones with remotely "decent" specs.
yet, they are heavy, and if you tried to actually game, the experience is DOMINATED by gerrrbrrrreeeeiiiishhhhiiiiiiiiiiiiiiiiiii....
You pay at the minimum $1500 to experience gerrrbrrrreeeeiiiishhhhiiiiiiiiiiiiiiiiiii.... **** at potato graphics 100fps or potato epic 50fps.
