Author Topic: What is your WPM?  (Read 173393 times)
Offline BlindRAGE606
  • Prince of All Saiyans
Re: What is your WPM?
« Reply #250 on: Wed, 02 January 2013, 16:52:03 »
Like 50WPM, +/- 5 when generating content.
I don't transcribe or mindlessly drone paragraphs. That's for secretaries, or those with 120+WPM e-peen.
DUCKY TKL MX BLACK | HHKB PRO 2 | BEAST PH&LACEWOOD
Offline esoomenona
  • Gnillort?
« Reply #251 on: Wed, 02 January 2013, 16:54:03 »
I type around 65-75 WPM. I can probably type faster than that when I know what I want to say, but when doing the tests, and you have to read and then type, I feel like it slows me down.
Offline file_id
« Reply #252 on: Thu, 03 January 2013, 10:06:37 »
Average WPM 99 over 50 tests.
DS3 White YOTS (Blue)|Poker 2 (Blue,Clear)|QFR Rapid-i TKL (Brown,Blue)|QFR Rapid TKL (Blue,Red,Brown)|KBP V60 (Blue,Clear,Matias Click)|Code TKL Clear|Filco MJ2 TKL (Blue)|Filco MJ2 Ninja Beige TKL (Brown)|Novatouch
Offline rek55
« Reply #253 on: Thu, 03 January 2013, 11:18:35 »
I type at 97-103 WPM apparently (tried at both hi-games and keyhero.org) on this rubber dome keyboard. I'll need to try again when I get back to my Das.
When I attempt to use Dvorak it drops to 11 WPM. That's quite the gap to try to overcome!
« Last Edit: Thu, 03 January 2013, 11:29:30 by rek55 »
My future Das Ultimate S, all modded up. For now, it's a bit more black.
Offline Guillairmo
« Reply #254 on: Sun, 13 January 2013, 17:43:12 »
Reckful, a twitch.tv streamer, easily gets 150+ WPM on typeracer. Quite impressive.
Offline razorsharpgears
  • TheOriginalBecker
    • Becker's 市場 рынок Markt - Sell/Buy/Trade
« Reply #255 on: Sun, 13 January 2013, 17:44:11 »
I prob only get around 80-120 WPM :/
« Last Edit: Sun, 13 January 2013, 19:24:25 by razorsharpgears »
Here at GeekClack, time isn't worth anything because CCs are money.
"You cannot plan the future. Only presumptuous fools plan. The wise man steers."
— Cosmo Lavish
|WTB/T/S| Thread ←Link
Offline Preach
  • The Insane
« Reply #256 on: Sun, 13 January 2013, 19:21:00 »
using 10fastfingers I range around 75-80ish. Not sure if that's down or up since many years ago heh.
QFR - Browns |
« Reply #257 on: Sun, 13 January 2013, 20:09:39 »
what's with all the necro recently.
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #258 on: Sun, 13 January 2013, 20:50:17 »
My wpm is ~95, but slightly slower on black switches.
Having a bad day?
Offline npgatech
« Reply #259 on: Sun, 13 January 2013, 20:55:29 »
Here is mine. Tested today.
Offline durainello
    • Free cheap and fast International shipping solution to fellow Singaporean.
« Reply #260 on: Thu, 31 January 2013, 08:49:58 »
Getting a decent fast WPM is not hard, getting the correct finger positioning is hard.
Offline Finwens
« Reply #261 on: Thu, 31 January 2013, 10:46:42 »
There's no correct finger position, imo. Type whatever is the most comfortable position for you. For example, the word "intro" the 'correct' way would be to type the T and the R, would be the index finger. But since they are so close, it's faster to type the T with the index finger and the R with your middle finger.
________________________
btw, in 10fastfingers my record is 113 wpm (steelseries 6gv2 with mx blacks) and in typeracer, 106wpm.
« Reply #262 on: Thu, 31 January 2013, 11:46:02 »
well, there MAY be an "ideal" finger layout... but that would vary with language.
The standard "home row" technique is terribly out of date. asdfjkl   is silly...    awefjio;  is the best home row
If you want to take it a step further replace ; with "right shift",   this way you don't have to  turn your right wrist to type "left" hand capitals.. ;D
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
« Reply #263 on: Thu, 31 January 2013, 11:51:24 »
or i guess you could learn how to use your fingers / hands / wrists / body.
« Reply #264 on: Thu, 31 January 2013, 13:27:21 »
too slow.. and the more variance between motion, the more easily it can break rhythm
Offline davkol
  •  Post Editing Timeout
« Reply #265 on: Thu, 31 January 2013, 13:52:00 »
QWERTY is out of date. Oh wait, it has actually never been suitable for typing in any existing language. I can't think of any human for that staggered typewriter physical layout would be suitable either.
« Reply #266 on: Thu, 31 January 2013, 14:01:39 »
so you won't be getting the GH60?
« Reply #267 on: Thu, 31 January 2013, 14:21:58 »
Hmm, probably like 95-100.
Offline davkol
« Reply #268 on: Thu, 31 January 2013, 15:01:27 »
Right, probably no GH60 for me. I'd like to stick with ErgoDox.
Offline SmallFry
« Reply #269 on: Thu, 31 January 2013, 15:06:19 »
I suck at typing. I don't look either. -_-
Offline regack
« Reply #270 on: Thu, 31 January 2013, 15:53:26 »
I've been teaching myself to type on the Race (with it's smaller right shift key) and that has recently brought my Typeracer average down from 85wpm to 78wpm... I have a lot of problems with the " and the : for some reason... mostly because I learned bad habits a long time ago and don't use the left shift like I should.
Offline stonejoint
« Reply #271 on: Thu, 31 January 2013, 16:02:57 »
My accuracy is better with blacks but I have 80 wpm with reds.
CM QFR Black Filco MJ2 Red
Vortex Poker 2 Brown
Offline ozziegt
« Reply #272 on: Thu, 31 January 2013, 16:08:37 »
At typingtest.com, I can hit about 100-105 wpm on a good day...otherwise around 90-95. Which is the reason I can't get a blue switched keyboard for my cube.
Offline ozziegt
« Reply #273 on: Thu, 31 January 2013, 16:12:23 »
Got much faster at 10fastfingers...without punctuation and stuff I guess I can type faster.
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #274 on: Thu, 31 January 2013, 17:12:11 »
65-90 with a horrible membrane keyboard :C
Offline precarious
« Reply #275 on: Thu, 31 January 2013, 18:18:25 »
http://data.typeracer.com/pit/profile?user=precariousgray
not too slow.  like i said, learn to use your hands.
« Reply #276 on: Thu, 31 January 2013, 18:19:20 »
One up
« Reply #277 on: Thu, 31 January 2013, 18:20:29 »
I'm just saying in the grand scheme of things... the little extra "technical" challenges will hold you back.
Offline sordna
« Reply #278 on: Sat, 02 March 2013, 15:39:08 »
Hi there,
if you know 2 or more layouts (ie QWERTY and one of Dvork/Colemak/etc) please post your WPMs in a new thread I created here:
http://geekhack.org/index.php?topic=40823.0
Offline badcop
  • thorpe thocking master race
What is your WPM?
« Reply #279 on: Sat, 02 March 2013, 16:45:15 »
Anywhere from 75 to 100.
Offline Grim Fandango
« Reply #280 on: Sat, 02 March 2013, 17:18:25 »
Anywhere from 60 to 80. Though that is my actual normal speed, not some high score on a webpage.
It may not seem very fast compared to some people here, but I think my typing speed is fairly fast, and fast enough for me.
Offline purple_haze
« Reply #281 on: Mon, 01 April 2013, 15:57:38 »
My typing speed varies from 70-90. I seem to be in the bottom of the category here compared to ya'll typing freaks, but it gets the job done for me.  Though i wish to break the 100 some day, but in my 27 years of my life i still have yet to get there.
Das Keyboard Silent S MX Browns | Filco Majestouch 2 MX Browns | Filco Majestouch MX Blues TKL
Offline Reomero
  • Manual breather
« Reply #282 on: Mon, 01 April 2013, 16:58:55 »
On 10fastfingers I can manage 110-130 WPM, although in the "real world" it's around 90-100.
Offline Macsmasher
« Reply #283 on: Mon, 01 April 2013, 17:32:51 »
Quote from: cactux;455256
very impressive :-) . To reach such spead you must spend severals hours typing (straight hours) per day. Let me guess you are a writter :-)
I wish. I just love typing. Maybe some day I'll start a novel or a script, but I can't guarantee finishing anything.
Me too. I don't admit this outside of this forum. Everybody thinks I'm weird, even my fellow nerds. But to me, the sound of a nice key switch is just as musical as playing a piano. I go to a number of typing sites after working all day on my keyboard just to play music and relax. I even go to youtube just to listen to other keyboards that I like.  ;D
Offline shadowness
« Reply #284 on: Wed, 03 April 2013, 11:12:55 »
not so good at typing... 51 WPM at 1 minute test.
but became 19 WPM at 2 minute test -_-"
Offline ihasmario
« Reply #285 on: Wed, 03 April 2013, 11:45:36 »
Burst speed of 163 on colemak for invented text, average speed of 120.
Burst speed of 136 on colemak for read text, average speed of 110.
My speed on qwerty and colemak is exactly the same for read text. I don't really read ahead
I'm getting slower because I have CTS in my left hand. I mostly use only my index finger in my right hand (one without CTS).
« Reply #286 on: Wed, 03 April 2013, 12:44:23 »
uh oh,, someone should cut back.... on the p.... I mean typing
Offline sordna
« Reply #287 on: Wed, 03 April 2013, 13:48:20 »
Hold on, typing with one finger is slow. Are this words per minute or characters per minute you posted?  :-)
Hey, are you able to switch between qwerty and colemak on the same keyboard and still achieve the same WPM ?
Or do you have different physical keyboards for each layout? I'm asking because I can type both dvorak and qwerty,
but not on the same keyboard, I find it confusing. Instead, I've associated dvorak with split/matrix keyboards (Kinesis Advantage, Ergodox, etc), and can only type QWERTY on normal flat keyboards and laptops.
 So I'd like to learn about your experiences here.
« Reply #288 on: Wed, 03 April 2013, 14:36:11 »
Question to the ergodox people... have you experienced any speed+
Offline davkol
« Reply #289 on: Wed, 03 April 2013, 14:41:25 »
I've experienced only frustration with customs so far.
Offline sordna
« Reply #290 on: Wed, 03 April 2013, 20:37:31 »
I did 99 WPM today on the Ergodox, it's on par with what I get on my Kinesis Advantage.
Offline Panoptic
« Reply #291 on: Wed, 03 April 2013, 22:27:45 »
On 10fastfingers I usually run about 95-100 on MX Browns and the Quiet Pro, and 105-110 on buckling spring or MX Greens.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #292 on: Wed, 03 April 2013, 22:36:13 »
DAMN what is your layout?
SmallFry! <3
Offline F u r u y á
« Reply #293 on: Wed, 03 April 2013, 22:46:12 »
100wpm+ in BS seems tough!
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline Panoptic
« Reply #294 on: Thu, 04 April 2013, 10:34:56 »
What can I say, I'm a big guy (about 6'6" / 2m) with heavy fingers.  I'm thinking about modding my Filco to Greens, but I need to try 45 and 55g Topres first...
Offline F u r u y á
« Reply #295 on: Thu, 04 April 2013, 10:38:54 »
45g? You're gonna smash the poor little guys.
Offline lazerpointer
  • ya gotta stay phresh
« Reply #296 on: Thu, 04 April 2013, 14:10:56 »
45g actually hurts my left pinky from using the shift.
I'm also a big guy (six foot five) with freakish lanky hands, but there's something about the way the left shift really HITS the bottom on a 45g (I have a 55g realforce and it does NOT have this problem because of the cushioning effect from the 55g rubber dome.)
Typing on this scissor switch right now is actually less painful and I'm typing faster.
Now at home I will still be using my 55g Topre Realforce 87u.... it's amazing how much better 55g is (at least for little old me)
i type, therefore i geekhack
Offline linziyi
  • The one with many questions
« Reply #297 on: Sat, 01 June 2013, 14:52:31 »
97 with a rubbish rubber dome....
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline inteli722
« Reply #298 on: Tue, 03 December 2013, 11:50:31 »
Powering through, I can usually get 97 WPM
Waiting for: Phantom Plate
Offline ynrozturk
« Reply #299 on: Tue, 03 December 2013, 18:17:30 »
I average at about 90 WPM. Not the best obviously, but it serves my needs well enough. I do try to put in some practice time whenever I can, though.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
