Author Topic: WHEN is the CM STORM TRIGGER full size available for USA / North america Customers?  (Read 2783 times)
Offline spitfire6000
Hey guys,
I see that the Cooler Master SGK-4000-GKCL1-US Storm QuickFire Rapid Gaming Keyboard (blue switches)  available on amaZon...and also...
http://www.cmstore-usa.com/quickfire-rapid-mechanical-gaming-keyboard-red-switch/
The red and blue switch tenkeyless are both avaiable from Cooler master directly from this website here above.
Anyone know when the fullsize mechanical keyboard in this lineup is coming out in the USA?
I would much rather get the full size...
Offline laffindude
Trigger is from different OEM as Rapid.
Quote from: laffindude;552085
IMagine we get a full size filco for $110, 120,  Raff Out Rowld
Offline laffindude
Buy a Rosewill?
Quote from: laffindude;552148
Buy a Rosewill?
Yes, but only when they make it NOT shiny
Offline CaiSter21
wat difference does it make if the keys are shiny after a few months, its not like ur gonna keep the same keycaps for the entire time. just replace the abs keycaps with pbt and problem solved
Ducky Shine DK 9008S Red LED |Rosewill RK-9000BR
Offline absyrd
  • CPT HYPE PADAWAN
I believe the CM rep over at OCN has addressed some of the North America details regarding diff switches and layouts. That is where I read about browns by the end of March. You can try to ask there.
Quote from: CaiSter21;552244
No, i meant the keyboard case, being shiny = bad.. and gaudy in a bad way. like the das
Offline CaiSter21
lol,the rosewill's case is nothing like the das.
ive had a rosewill brown for about two months and it doesnt have any shine on it
Quote from: CaiSter21;552765
what,, realllllly????,,, i may have to buy one then.
OMFG,, you're right,,, ordered,, should come tomorrow as I live in NJ and get 1 day delivery
Offline battlesheep
he didnt even ask... whats your point?
if razer would suddenly make the BW at costar, it would make it a better keyboard becaaauuuuseee...? :)
so spitfire, did you get the roswill? whats it like?
