Author Topic: Need a new black cherry keyboard  (Read 2650 times)
Offline The hobo gamer
« on: Thu, 13 September 2012, 12:29:01 »
hello i want a new mechanical keyboard but it shouldnt be to loud because my friends are always saying that my keyboard is too loud but i cant get a normal keyboard because mechanical just feels so much better i have heard that the cherry black switches are less noise the the cherry blues is that true and i dont want the num pad so is there a keyboard you guys and girls recommend? and thank for the help
Offline Terrorsathan
Re: Need a new black cherry keyboard
« Reply #1 on: Thu, 13 September 2012, 12:32:50 »
here ya go: http://tigerimports.net/sunshop/index.php?l=product_detail&p=11537
:D
Obviously has more keys than you want, but their TKL is not back lit
« Last Edit: Thu, 13 September 2012, 12:35:06 by Terrorsathan »
« Reply #2 on: Thu, 13 September 2012, 12:35:35 »
is that one not noise and is there a chance that i can get on without the num pad?
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #3 on: Thu, 13 September 2012, 12:49:10 »
If I was in your position I would probably grab one of the new unbranded CM Storm's with MX-Reds and get some O-Rings for it. Thicker keycaps might help too
« Reply #4 on: Thu, 13 September 2012, 12:50:20 »
what is good about the MX reds?
Offline Magna224
« Reply #5 on: Thu, 13 September 2012, 13:04:21 »
He pretty much summed it up. Any non-clicky keyboard + Orings + thick keycaps should quiet it up a lot.
Offline Dajm
« Reply #7 on: Thu, 13 September 2012, 16:47:50 »
Reds and blacks are both non-tacticle (as opposed to browns and blues). They are less noisy than blues/browns and can be even further dampened with o-rings.
The difference between reds and blacks are that the blacks are "harder" to press down. That doesn't mean they're HARD to press down, but it's just that the reds offer less resistance when pushing the keys down.
The best would be if you could try them both before buying.
But yeah, I recommend the CM Quickfire Rapid as well (if backlight is not one of your requirements), it comes with black or red switches and is relatively cheap. And then I'd simlpy add o-rings to make it even more quiet.
What exactly are your requirements? You already said that you want a TLK (no numpad). What else? Backlight? ISO or ANSI layout? Danish layout?
Offline BucklingSpring
« Reply #8 on: Thu, 13 September 2012, 20:10:04 »
How about a backlit Deck Legend?
Boards I own, click ->
Offline spiralsc2
« Reply #9 on: Thu, 13 September 2012, 20:17:04 »
yeah some of those CM Storm MX Blacks are REALLY nice
Offline jeroplane
« Reply #10 on: Thu, 13 September 2012, 20:40:26 »
Not necessarily. They are definitely quieter than Blues, but arguably one would bottom out more on Reds than on Browns, hence making it much louder. The tactile bump on Brown is simply tactile (and even then it's slight) and does not click like Blues. Many have said Browns are probably the quietest and some say Red/Black; it depends on your typing style.
My signature hasn't changed since 2012. I should really update it.
Offline jwaz
  • * based mod
« Reply #11 on: Thu, 13 September 2012, 20:50:01 »
You bottom out about the same on both (brown and red), very similar, and if typing any sort of speed then they will be effectively making the same amount of noise.
So with o-rings any switch (sans ones with audible feedback) will be adequate... keep in mind that something PCB mounted will prove to be quieter, especially with o-rings.
