Author Topic: well i think it has started  (Read 3108 times)
Offline poopmat
« on: Fri, 14 September 2012, 11:24:26 »
about 2 weeks ago i got a cm storm rapid with browns on the recommendation of the other folks here
all i can say is wow
now since then i have purchased a dell at101w for work which is nice and im now looking for something else
not that i need a keyboard all my computers now have mechanical setups
even my 13yr old daughter took my ibm model m (her friends ask whats that noise when shes on skype she tells them its the sound of awesome)
so i really want to stay 10 keyless and i will prob want to stick with the browns cause they are  really nice for gaming and typing
back lighting isn't my thing and im too poor to afford a topre set up
so whats the next logical progression?
Leopold? filco?
please help me frivolously spend my $$
thanks
oh and id like to get a white board if possible
Budget 150$
« Last Edit: Fri, 14 September 2012, 11:27:02 by poopmat »
REΛLFORCE 103u, Ergodex DX1, IBM model M, Daskeyboard II, QFR brown,
Offline dreamingftw
Re: well i think it has started
« Reply #1 on: Fri, 14 September 2012, 11:46:10 »
If your budget is around $150, I would try to find a Filco. You won't regret it.
Offline imersa
  • clickclack's #1 fan
« Reply #2 on: Fri, 14 September 2012, 11:48:03 »
My Filco experience was wonderful :)
« Reply #3 on: Fri, 14 September 2012, 11:49:29 »
You would totally regret the filco after you buy a quickfire rapid, and realize it's the exact same thing but $100 less. ;D
« Reply #4 on: Fri, 14 September 2012, 11:51:13 »
Everyone who keeps pushing the filcos when they own one is simply entrenched in effort justification.
Offline longweight
  • philanthropist
Re: Re: well i think it has started
« Reply #5 on: Fri, 14 September 2012, 11:56:57 »
Obvious troll is obvious.
Offline poopmat
« Reply #6 on: Fri, 14 September 2012, 11:58:53 »
who carries said filcos??
Offline longweight
  • philanthropist
« Reply #7 on: Fri, 14 September 2012, 12:13:01 »
Where do you live?
Offline swagpiratex
« Reply #8 on: Fri, 14 September 2012, 12:17:56 »
I think his location says Florida...
For Filco in the US, Amazon will be your best bet. I'm more with tp4tissue on this though. The only reason why I dropped the dough for a Filco is because it was Multicam, Full-Size, with brown keys.
If I didn't have a multicam fetish, I would have been happy with the QFR and spent the money saved on some nice keycaps.
Offline imersa
« Reply #9 on: Fri, 14 September 2012, 12:18:58 »
'was' being the keyword for me. I no longer own a Filco. My experience was still amazing!
I was lucky enough to try many a mech keyboard at the last keyboard meet and the Filco certainly performed.
Offline poopmat
« Reply #10 on: Fri, 14 September 2012, 12:37:22 »
well if not filco who else???
luepold, ducky??
Offline TheProfosist
  • Custom Layouts Only!
« Reply #11 on: Fri, 14 September 2012, 12:40:31 »
Leopolds are nice but dont forget that they have cherry stabilizers.
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #12 on: Fri, 14 September 2012, 12:56:37 »
I don't think I could justify paying 110% more for a Filco when the specs are so similar to the CM.
The next step up for me would be a Truly Ergonomic or the upcoming Tactile Pro 4. I'd consider getting the latter even though I promised myself to stick with compact/TKL for future purchases (that's assuming the new Matias switches are that good). I would also probably have a Unicomp Spacesaver by now if it were still TKL (the moniker seems pointless with the tenkey on it).
Many Cherry-brand keyboards will save on space, being closer in width to TKL (but have the tenkeys). The compact Deck Ice has also gotten good reviews, but it uses black linear switches.
If you really want to go in the direction of a Filco Majestouch, consider saving some money and getting the Leopold instead.
FWIW, I still love typing on my AT-101W.
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
Offline daerid
    • Rossipedia
« Reply #13 on: Fri, 14 September 2012, 21:10:01 »
I have a Filco MJ2, and two Quickfire Rapids. Yes, the QF's are comparable. But the Filco still feels much more solid. Maybe it is confirmation bias, but I still think the Filcos are a bit higher quality.
However, I'm probably going to get rid of them since they're just collecting dust now (pretty much addicted to the Realforces)
Offline karljs
« Reply #14 on: Fri, 14 September 2012, 21:22:40 »
Just to make things harder for you, I'll put in a recommendation for WASD. Plate mounted, no flex or creaking, and they have a helpful subforum here.
Offline stingrae
« Reply #15 on: Sat, 15 September 2012, 00:56:37 »
Pretty much this (although I don't have the realforce bug).  The filco is a bit heavier, I also prefer the finish, plastic cover and the attached cord (I like detached but it's sometimes annoying to get in). I wouldn't have got it if I could have got a cm storm quick fire rapid with browns though. At double the price for some side printed caps, it isn't worth it.
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
« Reply #16 on: Sat, 15 September 2012, 01:06:24 »
Mine creaks a little under torsion. It's 11 months old now, so maybe they've updated the design since I got it.
Still, I recommend it. WASD looks like one of costar's reference designs, and it looks good. It's a solid keyboard. WASD is also a great person (company) to deal with.
That said, you might want to wait for the WASD version 2 to come out later this year (Hopefully). It should also be good.
See if you can get a IBM Model F AT or a terminal keyboard and a soarer convertor. You have ALPS and Cherry. Now try Buckling Spring: The best switch type ever.
