Author Topic: Is this a good camera?  (Read 3729 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Sat, 22 September 2012, 03:06:00 »
http://www.newegg.com/Product/Product.aspx?Item=N82E16830111462&nm_mc=EMC-EXPRESS092212&cm_mmc=EMC-EXPRESS092212-_-EMC-092212-Index-_-PointShoot-_-30111462-L03B
I've read some reviews and it seems like a good camera but it's starting to get old sooo.....
My main use would be for macro shots n stuff
Re: Is this a good camera?
« Reply #1 on: Sat, 22 September 2012, 03:10:59 »
Good macro with a $200 budget.... hmm.......... challenging.........
Offline GMC
  • Shiny.
Re: Re: Is this a good camera?
« Reply #2 on: Sat, 22 September 2012, 05:48:02 »
I wouldn't - sensor is tiny.
Better to pick up a big sensor with smaller zoom with manual controls. Look at the pro compact end of the market and consider 2nd hand to get price down.
Think the canon g series, Nikon p7xxx, could also look at Fuji x10. Olympus xz-1 worth a look too and prices on this will fall with announcement in the last week or so of a replacement model
WASD V1 - waiting on R4... - MX Brown
KBT Pure - Zinc caps - MX Brown
Cherry G80-1800 ISO WKL - SkiData caps - MX Clear
Offline isp
« Reply #3 on: Sat, 22 September 2012, 17:40:15 »
no
hhkb
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Sat, 22 September 2012, 17:43:15 »
Good, I was going to buy it a month back when it was that same price. I'm glad I restrained myself.
When I do decide to stop talking photos with my potato I'll ask you guys :D
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #5 on: Sat, 22 September 2012, 17:46:34 »
I use a simple point and shoot Canon Elph 300HS.  I bought it on Black Friday last year for $100 plus a ton of other accessories and gift card.  It isn't a DSLR, but can take some pretty good macro shots under proper lighting.   Here's some more recent shots:
Offline The_Beast
  • I like wood ಠ_๏
« Reply #6 on: Sat, 22 September 2012, 17:52:00 »
^^ That's what I want, something cheap but still decent macro shots. I think a DSLR would be over kill to take pictures of keyboard 'n stuff
Offline DanGWanG
  • Higher Standards
« Reply #7 on: Sat, 22 September 2012, 17:54:08 »
I might actually be selling mine soon...maybe we can make a trade for a custom wrist rest when you get back from school =)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Sat, 22 September 2012, 17:59:33 »
I'm sure we can work something out when the time comes ^___^
Offline SmallFry
« Reply #9 on: Sat, 22 September 2012, 18:20:02 »
What's wrong with potatoes? I seem to like them just fine...
Offline khaangaaroo
« Reply #10 on: Sat, 22 September 2012, 22:45:57 »
Another option for macro is to get a dslr paired with a $5 reverse ring adapter. This allows you mount the lens on the camera backwards, turning a normal lens into a macro lens.
This can give excellent macro shots even with a cheap camera body and cheap lens. Any old sub-$200 dslr will work fine. However, everything needs to be set manually on the camera. So either you need to know a bit about photography or be willing to spend some time experimenting until you get the hang of it.
