Author Topic: CCnG on Camo Filco TKL?  (Read 4031 times)
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« on: Mon, 01 October 2012, 13:38:05 »
so I want a white filco Majestouch TKL, only because it would match CCnG pretty well. But what about a camo TKL? Does anybody think the CCnG would match it at all?
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline The_Beast
  • I like wood ಠ_๏
Re: CCnG on Camo Filco TKL?
« Reply #1 on: Mon, 01 October 2012, 13:39:33 »
I had the same thought about a month ago, then I decided I already had too many keyboards (there is such a thing) and didn't pursue the camo any longer. I think it would look really good
Offline shadewolf
  • ಠ_ಠ
« Reply #2 on: Mon, 01 October 2012, 14:27:30 »
Looks pretty sick on the 104 if you ask me :eek:
http://geekhack.org/index.php?topic=29325.msg666498#msg666498
« Reply #3 on: Mon, 01 October 2012, 19:26:40 »
Those two greens actually clash asthetically. The key green is far too yellow, while the keyboard green is far too "BLUE"/"Grey"
I wouldn't put it together with the CAMO.
« Reply #4 on: Mon, 01 October 2012, 19:27:35 »
IDK where many geekhackers are learning to color match, LOL, it's proabably not their fault, and more due to the lack of options, but still... blechhh....
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #5 on: Mon, 01 October 2012, 20:12:29 »
I think it looks pretty good, yet it also kinda clashes which is why I preferred initially the beige / white tto match the CC part. But of course, there's no such thing as a white filco TKL with browns anymore... I can only find black and camo. I might just have to go for it and trade it for a beige down the road.
TOO BAD FOR YOU
« Reply #6 on: Mon, 01 October 2012, 20:29:58 »
bah.. plastidip.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #7 on: Mon, 01 October 2012, 20:36:27 »
bah.. plastidip.
Have you used the stuff yourself? Im familiar with it but I have no idea how it would withstand a keyboard element.
TOO BAD FOR YOU
« Reply #8 on: Mon, 01 October 2012, 20:52:47 »
bah.. plastidip.
It's durable to the "touch" for sure, but if you Rub the keyboard hard against something, you'll probably rip the plastidip off.  Not likely though..
Yes i've used it, as that's my board.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #9 on: Mon, 01 October 2012, 20:54:46 »
So I would assume no tears from daily rubbing of hands on it and whatnot?
TOO BAD FOR YOU
« Reply #10 on: Mon, 01 October 2012, 20:55:35 »
I prefer CCnG on white/beige
« Reply #11 on: Mon, 01 October 2012, 21:43:58 »
Hand is no problem
