Author Topic: Keycool 87 First Impressions/Mini Review. PCB Photos Added.  (Read 6319 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Mon, 01 October 2012, 20:41:01 »
Since there isn't really much information and pictures of these here, I figured I would make some : )
I ordered this from qtan. It took 7 days to get to me in Michigan. Not bad at all.
Here's what came in the box. A key puller, usb cable, lavender and brownish WASD keys, USB to PS/2 adapter, extra stabilizer pieces, and Keycool esc key.
(sorry for the blurry pics)
The keyboard came in a nice little bag. Pretty awesome for transporting it!
Some alignment issues with the F keycap. It's only the keycap though.
Weird scratches on the case below the spacebar.
Very solid and nice feeling flip down feet.
I broke the stabilizer bar clip when I was taking off the keycap. They're pretty cheap and flimsy. I can see why the included replacements.
A shot of the odd spacebar stabilizer size.
Pretty sexy with Red Alert 2.0's
Weighs 2 lbs, 1.1oz
This thing has the most grippy rubber pads I have ever seen on a keyboard. I can get it to like 60-70 degrees without it sliding down.
The keyboard feels really nice and high quality. I was expecting it to be worse than it really is. I'd say  the quality is pretty close to filco, excluding the keycaps. but the board itself is great. The texture of it kind of reminds me of the original RK-9000. It's kind of rough, but smooth at the same time, and it feels thick and solid. I really like the look of the case too. kind off a bit different, but not over the top.
The only issue with the fit and finish I could find was that little scratch below the spacebar that almost looks like it was painted over. It's very subtle though. hardly noticeable unless you're looking for it.
The keycaps aren't too bad really apart from the not so sexy font. I am Told They're POM from some guy on youtube. not sure though. The texture of them feels pretty good. It's a nice rough texture.
I guess my overall thoughts/opinions are, Really pleased! This keyboard exceeded my expectations by a lot. It came with a bunch of extras that I wasn't expecting, and It's build quality is great! I would say this keyboard seems bit under-rated. It would be a really nice alternative to a Leopold, or maybe even filco If you plan on changing your keycaps anyway. I guess people still prefer the quickfire though. pretty understandable since it's a bit cheaper. I personally much prefer this over the quickfire however. (which I do own)
Well that's about all I have to say. Hope people interested in this keyboard found this a bit useful. :D
Here are some pics of the PCB solder as requested : )
Only shoddy looking thing. I'm not even sure what it is.
« Last Edit: Thu, 04 October 2012, 16:26:36 by Lethal Squirrel »
Re: Keycool 87 First Impressions/Mini Review.
« Reply #1 on: Mon, 01 October 2012, 20:48:58 »
awesome review...
How does the stabilizer work without the guides, when you put a seperate keycap set on it, or is the space bar one of those universal spacebars.
  • I <3 60%
« Reply #2 on: Mon, 01 October 2012, 20:52:22 »
It's a universal one : )
Offline khaangaaroo
« Reply #3 on: Mon, 01 October 2012, 21:43:46 »
Nice review. I like how the cable routes away from you instead of directly out the side. The last photo also caught me by surprise...haha
Offline WhiteFireDragon
    • youtube
« Reply #4 on: Tue, 02 October 2012, 00:24:23 »
How is this to a lesser quality than a Filco?
And your yellow lighting kind of screw the color of the keyboard, but it look like the case has a brighter white than the beige color of a white Filco?
Offline Reason
« Reply #5 on: Tue, 02 October 2012, 01:16:15 »
is the color more close to beige than pure white?
the pictures make it look a bit beige
  • I <3 60%
« Reply #6 on: Tue, 02 October 2012, 10:04:47 »
The quality is lesser than filco because of the keycaps, and the little marks below the space bar. The color is more white. You're right that my pictures are a bit yellow. Ill get some pics today in the sunlight with my white balance dialed in correctly. : )
Offline kaiserreich
  • HHKB Elite
« Reply #7 on: Tue, 02 October 2012, 10:06:42 »
Keycool offers keycaps made of POM/PBT in 37 keys format.
I think these are ABS.
Offline xenon_chris
« Reply #8 on: Tue, 02 October 2012, 10:19:28 »
Nice review, think this has tipped me over the edge on my indecisiveness on a cheap board for work :D
Ducky Dragon/Browns
  • I <3 60%
« Reply #9 on: Tue, 02 October 2012, 10:39:43 »
It would be a great choice. :D
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #10 on: Tue, 02 October 2012, 11:20:38 »
I love the Keycool 87, especially the white one. As you said, the only downside is the standard keycaps, but that is easily solved. It's a good quality board and it feels really good to type on. :)
It looks great with the Red Alert's. I'll be putting some Group Buy 4 Noir on them when they finally arrive. (Probably around December ?) That way you get this nice white case/black keys effect.
« Last Edit: Tue, 02 October 2012, 11:22:27 by JaccoW »
|||My other keyboards :
x
  • I <3 60%
« Reply #11 on: Tue, 02 October 2012, 11:48:57 »
That's one of my favorite looks. :D
Offline Skull_Angel
« Reply #12 on: Tue, 02 October 2012, 13:03:49 »
Has anyone cracked one open to get a good look at the soldering? I'm still curious about the build quality.
  • I <3 60%
« Reply #13 on: Tue, 02 October 2012, 13:34:33 »
I might do that soon. I don't know if I wanna take off the rubber feet though.  : (
Offline Skull_Angel
« Reply #14 on: Tue, 02 October 2012, 14:20:08 »
My GF's successfully reapplied plastic decals by cleaning the sticky part with isopropyl alcohol. I haven't tried it for reapplying rubber feet yet, but a small amount of solvent should fix any sticky that comes unstuck, just don't go overboard or you'll end up with a gooey mess, lol.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #15 on: Tue, 02 October 2012, 16:37:04 »
I'm very interested in this, too.
Keep us updated about wear n' tear and functionality of it, please. :D
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #16 on: Tue, 02 October 2012, 18:09:20 »
good review.............you did a good job and thumbs up with the different pictures
so what the heck is up with those scratches- did he pull that one off the scratch and sniff section :eek:
would be nice to see what his/they're reply is after making aware you're bumper came with a dent in it :(
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
  • I <3 60%
« Reply #17 on: Tue, 02 October 2012, 20:14:58 »
It's really not something I was gonna bring up to him. It wouldn't really be worth getting a replacement. It's really hard to see unless you get really up close.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #18 on: Tue, 02 October 2012, 20:56:23 »
gotcha............not trying to hammer anybody and we know the seller has a good rep
as long as you're happy!
Offline inzov
« Reply #19 on: Wed, 03 October 2012, 10:33:38 »
i got mine a little over a week ago and i love it, i very much prefer the keycool to a quickfire rapid aswell.
Offline w4rtortle
  • QFR Black Switches
« Reply #20 on: Thu, 04 October 2012, 06:36:01 »
do you guys think the backlit version is the exact same quality? sounds like a decent buy.
  • I <3 60%
Re: Keycool 87 First Impressions/Mini Review. PCB Photos Added.
« Reply #21 on: Thu, 04 October 2012, 16:28:14 »
I'm sure it is. :D
    • youtube
« Reply #22 on: Thu, 04 October 2012, 17:01:13 »
Did you just add those PCB shots? The solder job looks pretty good for the most part. Each contact does look it like has more solder than needed though.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #23 on: Thu, 04 October 2012, 17:05:11 »
Thanks for delivering on the additional pictures.
Offline Skull_Angel
« Reply #24 on: Thu, 04 October 2012, 19:57:13 »
Thanks for popping it open and taking some shots! Have to agree that there does seem to be a bit much on some points and it looks like the temp may have been slightly on the cool side for some as well, but over all it doesn't look bad at all (except whatever's going on in that last shot :eek:).
Offline Human
« Reply #25 on: Sat, 06 October 2012, 14:23:12 »
That part is the locking scheme of PCB to the steelplate. Just unsure why they do those messy soldering on it.
BTW, this is how mine's PCB look like.
« Last Edit: Sat, 06 October 2012, 14:26:47 by Human »
