Author Topic: Ergo Clears  (Read 3577 times)
Offline gameaholic
Ergo Clears
« on: Mon, 01 October 2012, 22:27:50 »
I am interested in converting my new Filco Tenkeyless MJ2 Ninja with Reds to Ergo Clears (coming from buckling springs has me missing the tactile click) Is soldering required?  I've never soldered anything.  Could someone point me to a guide?  I've seen a video on someone popping out stems but it says they must be pcb mounted to do it that way and I've read my keyboard is plate mounted.  Which tenkeyless keyboards are pcb mounted?I've tried pming a member that offers this conversion service but I have yet to get a reply.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline Lethal Squirrel
  • I <3 60%
Re: Ergo Clears
« Reply #1 on: Mon, 01 October 2012, 22:39:13 »
Soldering is required. For me it's not really the soldering part that's a pain, it's the desoldering.
The only way you can switch them without desoldering is if the switches are PCB mounted. I don't know of any tenkeyless that are PCB mounted. : (
BTW, if you're looking for a tactile click, clears aren't what you want. clears have no click, only a bump.
Offline WhiteFireDragon
    • youtube
Re: Ergo Clears
« Reply #2 on: Mon, 01 October 2012, 23:44:52 »
You'll need to first desolder every switch off, do the ergo-clear mod, then solder everything back.
Re: Ergo Clears
« Reply #3 on: Mon, 01 October 2012, 23:46:25 »
It's not so bad, if you use soldering wick// braid... this is incredibly important in efficient de-soldering.
Re: Ergo Clears
« Reply #4 on: Tue, 02 October 2012, 18:53:19 »
If you just want to make the typing area into ergo clear, you don't have to remove every switch. This can save time.
Offline SmallFry
Re: Ergo Clears
« Reply #5 on: Tue, 02 October 2012, 21:19:38 »
Also, a solder sucker works wonders better than braid. Since you have to heat the board longer when using braid, you have a higher chance of lifting a trace. Either way works though. :)
Re: Ergo Clears
« Reply #6 on: Tue, 02 October 2012, 21:30:33 »
Solder sucker is amazing, just got one recently, soldering is ezpz now.
Re: Ergo Clears
« Reply #7 on: Tue, 02 October 2012, 22:43:07 »
WOW, solder sucker, life changing............................
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Re: Ergo Clears
« Reply #8 on: Tue, 02 October 2012, 22:50:48 »
Which Brand/Model do you recommend?
Offline alaricljs
  • I be WOT'ing all day...
Re: Ergo Clears
« Reply #9 on: Tue, 02 October 2012, 22:51:48 »
Edsyn Soldapullt, the only manual sucker worth spending money on.
Filco w/ Imsto thick PBT
Offline SmallFry
Re: Ergo Clears
« Reply #10 on: Tue, 02 October 2012, 23:09:01 »
I usually pay for my sucker...oh, whoops...I use a generic one. It does the job for me without any hassle.
Offline The_Beast
  • I like wood ಠ_๏
Re: Ergo Clears
« Reply #11 on: Tue, 02 October 2012, 23:12:23 »
I haven't used wicks, only suckers. They work ok, but sometimes it leaves a bit of solder in the hole and you have to work pretty quick
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: Ergo Clears
« Reply #12 on: Wed, 03 October 2012, 00:30:56 »
100% agree look at the silver or gold one in my opinion i got the silver as it was onsale when i was ordering.
Re: Ergo Clears
« Reply #13 on: Wed, 03 October 2012, 04:15:54 »
Ok, guys, is there an "automatic one" since all of these are manual?
I have near unlimited funds when it comes to tool purchases..
Offline SmallFry
Re: Re: Ergo Clears
« Reply #14 on: Wed, 03 October 2012, 07:53:52 »
GIYF.Look it up.
Offline alaricljs
Re: Ergo Clears
« Reply #15 on: Wed, 03 October 2012, 08:05:52 »
Hakko 808
Or if you *really* mean unlimited, look at either Hakko or Weller rework stations.
Re: Ergo Clears
« Reply #16 on: Wed, 03 October 2012, 15:09:15 »
Hakko 808
i want that 808 but dont have funds :(
