Author Topic: Advice requested with yet another Poker keymapping question  (Read 1959 times)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« on: Fri, 12 October 2012, 10:44:14 »
I've read http://geekhack.org/index.php?topic=22474.0, and am a proficient user of xmodmap, xev, etc. under Linux (where my editor of choice is vim.)  So I can and will make those mods.
What I don't see is how to move the {Fn}  key -- if that is even possible.
I'd like to change the bottom row from:
{Ctrl} {Win} {Alt} {Spacebar} {Fn} {Win}  {Menu} {Ctrl}
To:
{Ctrl} {Fn}  {Alt} {Spacebar} {Up} {Down} {Left} {Right}
But I suspect the {Fn}  key does some something entertaining in firmware before the scancodes exit the keyboard.  Is that the case?  Can I move/re-map {Fn}  and still get (e.g.) F1 through F12?
Again I am comfortable with xmodmap and xev and even keyboard layouts in Linux.  I am also happy to whip out the soldering iron if needed.
And there is a Poker in the Classifieds at this very moment.  ;D
If someone knows the answer, please advise!
Thanks in advance,
 - Ron | samwisekoi
Re: Advice requested with yet another Poker keymapping question
« Reply #1 on: Fri, 12 October 2012, 10:47:45 »
To:
Thanks in advance,
 - Ron | samwisekoi
Soldering iron is best.. You simply Cut a little slit into the trace, sand off some resin, and re-route with wires. pretty straight forward, 2 traces for every key.
DO NOT cut the trace too close to the END, because if you decide to go back to your old layout, you want to make sure you have some traces left near by to solder to..
Cut the trace where most convenient and where you can make the reroute using the SHORTEST amount of wire.
You want to make sure the wires in the back line up with there arn't support struts from the back plate..
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 12 October 2012, 10:47:47 »
Fn dosen't have a scancode, so you can't remap it. You can have fn instead of LWin via dipswitch though.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #3 on: Fri, 12 October 2012, 11:56:47 »
Fn doesn't have a scancode, so you can't remap it. You can have fn instead of LWin via dipswitch though.
Really?  Cutting traces is fun and all, but isn't this exactly what I wanted anyhow?
So if I flip the dip switch and move the keycap I go from:
To:
{Ctrl} {Fn}  {Alt} {Spacebar} {Win} {Win} {Menu} {Ctrl}
And then I can use Xmodmap to remap {Win} {Win} {Menu} {Ctrl} to whatever I want?
Or do I simply get another {Fn} key?
{Ctrl} {Fn}  {Alt} {Spacebar} {Fn}  {Win} {Menu} {Ctrl}
If it is the first result, this is perfect!
Thanks very much,
 - Ron | samwisekoi
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #4 on: Fri, 12 October 2012, 14:58:28 »
A wiki article would be great...I found some great info at http://deskthority.net/news-reviews-f4/kbc-poker-sixty-s-take-t125.html
That explains it!
From the article:
By pressing FN+Spacebar, you can enable the “arrow lock” mode.
When activated, the Windows key, Application key, Ctrl and Shift keys on the right side of the keyboard will permanently act as arrow keys!
So
SW 4 ON: Windows_L becomes FN_L
plus
FN+Spacebar
and a few new keycaps gives me exactly what I want!
Thanks all!
 - Ron | samwisekoi
p.s.  Mods, please close this thread.  Thanks!
Offline TheQsanity
  • SmallFry Lovin'
« Reply #5 on: Fri, 12 October 2012, 15:38:45 »
Confusing stuff someone should make a Youtube video!
SmallFry! <3
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #6 on: Fri, 12 October 2012, 15:46:04 »
OK.  Gotta get the stuff first...
 - Ron | samwisekoi
« Reply #7 on: Fri, 12 October 2012, 16:59:24 »
Yes, it is a little bit. Just imagine those of us that got them on release, looking at the Chinese manual that was totally wrong to boot!
