Author Topic: Poll: Costar or Cherry Stablizers?  (Read 6283 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Mon, 29 October 2012, 19:22:55 »
What do you prefer in terms of stabilizers?
Poll
Results
Then in the comments below, why
Re: Poll: Costar or Cherry Stablizers?
« Reply #1 on: Mon, 29 October 2012, 19:55:55 »
Cherry Plate Mount - I only have experience of this and Costar, and the Costar on the CM QFR was a bugger to get the pins out of the key cap to swap key caps, and then the pins would not stay in the replacement key caps - far too loose.  Plus all the fiddling around to wiggle the key caps on and off - Cherry seems simpler, just lift off or push on and it's done.
« Reply #2 on: Mon, 29 October 2012, 19:57:48 »
My good old Leopold.  First mech keyboard and still love typing on it.
Offline Kensy
« Reply #3 on: Mon, 29 October 2012, 20:23:56 »
I prefer Costar as personally I think it feels better ! However there's a offset, as the sound is more distinct than Cherry stabilizers
IBM Industrial M / IBM M13 Trackpoint II / Topre 104UB / Matias Quiet Pro / Filco MJ2 Ninja / Filco Minila JP Layout
Offline sth
  • 2 girls 1 cuprubber
« Reply #4 on: Mon, 29 October 2012, 20:29:00 »
cherry pcb mount stabilizers are easily modded to feel like costar with the added benefits of everything else about cherry stabilizers that makes them better :P
check out the kmac DIY thread for a video guide by the ever lovin Litster.
Offline WhiteFireDragon
    • youtube
« Reply #5 on: Mon, 29 October 2012, 20:58:25 »
Except plate mounted Cherries are harder to source.
How many difference part numbers are there for these plate mounted stabilizers? I believe you can mount it so the wire can be either on the top or the bottom, but you can't just turn the mount around because of the different size holes. So are there two different parts we can choose from?
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #6 on: Mon, 29 October 2012, 21:01:36 »
Costar stabilizers feel damn nice, but when it comes down to changing keycaps... Dear god...
But anyway, I don't think I'll be changing my Das Keyboard's keycaps, but for those who want to do that, avoid Costar.
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline sth
« Reply #7 on: Mon, 29 October 2012, 21:05:12 »
except what? i was talking about pcb mount not plate mount.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Mon, 29 October 2012, 21:08:13 »
Costar takes 5 minutes max to do. I'm more scare to remove caps from a PCB mount board since I always snag the switch
Offline shibbyllama889
« Reply #9 on: Mon, 29 October 2012, 21:23:45 »
I only have experience with Costar and Cherry pcb mount. I prefer Cherry because they allow the modifiers to sound the same as the rest of the keys. Costars always have a louder, metallic, clinky sound when you press on the keys. I like a constant sound across all the keys. I don't find them any mushier either; I think their lack of sound makes people think they feel mushier. Just a hypothesis. Also, removing the keycaps is way easier. I haven't had any trouble with pulling up the switch yet.
Offline jeroplane
« Reply #10 on: Mon, 29 October 2012, 21:29:56 »
This. I was so scared of ripping out the switches when I first removed the key caps on my 11900, but I think I've got the hang of it now.
I've only had experience with Cherry PCB Mount and Costar stabilisers, but Costar feels better to me. I feel that Cherry PCB Mount stabilisers somewhat dampen the keys, which I guess some may like.
Concerning the fit, sellotape takes care of that and it's not like you'd be changing caps that often anyway, so that's not really a deciding factor to me.
Edit: Interesting contrast with shibby's post above, haha. I guess it really is personal preference as to whether you like the "mushy" or "clinky" sound/feel.
« Last Edit: Mon, 29 October 2012, 21:32:08 by jeroplane »
My signature hasn't changed since 2012. I should really update it.
    • youtube
« Reply #11 on: Mon, 29 October 2012, 22:57:19 »
It honestly takes me less than 1 minute to take off the all the modifiers with costar stabilizers. This doesn't include taking off the white stems though, because usually never have to change those. I have a few stem sets around. If you get use to taking modifiers off from costar, the motion is pretty fast. With cherries, it take me longer because I'm more caution of just ripping it out.
Ah the reply was out of context, it wasn't directed towards you. I looked at the poll results and during the time, nearly all of them preferred plated-mounted cherries, so my post was directed at the poll lol.
« Reply #12 on: Mon, 29 October 2012, 23:21:52 »
Mine were jammed in to the stock CM key caps, at first I thought they were glued in they were that tight.  Took ages to get them all out.
Then in complete contradistinction they would not stay in the SP key caps as they were far too loose.
Go figure.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #13 on: Mon, 29 October 2012, 23:23:11 »
Blame SP not Costar. SP keys tend to be loose
« Reply #14 on: Mon, 29 October 2012, 23:27:56 »
The Costar ones were too tight IMHO.
Offline blighty
« Reply #15 on: Tue, 30 October 2012, 00:26:11 »
I must say that I'm a fan of Cherry PCB mounted stabilizers.  I like the fact that they seem to make less sound than Costar, or feel more solid? They don't seem to rattle as much, or sound as "hollow," especially noticeable on the space bar. I know the Costars can be adjusted somewhat to lessen noise, but eh.  The only downside is when you accidentally rip one of the stab mounts off the board while rushing to switch caps.
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline Terrorsathan
« Reply #16 on: Tue, 30 October 2012, 07:33:35 »
Costar... duh...
to everyone crying about having to change keycaps on a costar based board...
Offline Lethal Squirrel
  • I <3 60%
« Reply #17 on: Tue, 30 October 2012, 09:34:17 »
Can't stand cherry : P
Offline exousia7
« Reply #18 on: Tue, 30 October 2012, 11:20:12 »
Cherry PCB mounted ftw =)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #19 on: Tue, 30 October 2012, 11:52:59 »
Cherry all the way. Costar is rubbish, the inserts are fiddly and harder to remove or fall out on many keyset, they tend to rattle and make a lot of noise, and seem to be more prone to binding up and getting stuck. I only have 1 board with costar style, and I'm currently working on modding the plate to fit Cherry plate mount. I already removed all the stabilizer except the spacebar since I couldn't stand all the rattling and the inserts were always falling out of my Cherry keys anyway.
Offline SmallFry
« Reply #20 on: Tue, 30 October 2012, 12:22:51 »
Says the Cherry Friend...:P I don't have any Costar's but from what I've tested at the Chicago meet up, I definitely prefer Cherry as well.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #21 on: Fri, 02 November 2012, 17:40:55 »
Costar - 21
Plate Mount Cherry - 8
PCB Mount Cherry - 5
Other - 2
Looks like costar is the big winner here
Offline aesthetics1
« Reply #22 on: Fri, 18 January 2013, 00:01:21 »
OK, I'm sorry for the necro-bump, but I searched and couldn't really find a great answer.
Regarding removing and reattaching keys from/to costar stabilizers, what is the best (safest, not fastest) method? I have been using a tiny flathead screwdriver to pop the metal bar off to the side, but I have only done it on two keyboards so far. Hopefully there's something simpler. I feel like I'm going to break something!
Home: Filco Majestouch TKL MX Red | Work: Ducky Shining (Blue LED) MX Black | Collection: CM Quickfire Rapid MX Red
Offline wetto
« Reply #23 on: Fri, 18 January 2013, 08:51:55 »
Now I can finally compare Costar Stabilizers and Cherry stabilizers since I now have a Das Keyboard and a CM Trigger.
Anyways, what they say it's true. Costar stabilizer does feels better, but removing keycaps on Cherry stabilizers is soo damn easy...
My collection:
Offline daerid
    • Rossipedia
« Reply #24 on: Fri, 18 January 2013, 11:40:55 »
Costar, all the way. I've removed caps on costar stabs so many times that it's not even an issue in the slightest.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #25 on: Fri, 18 January 2013, 12:04:48 »
lol I agree.
It's true, like if you've never done it then it might seem hard.  But it's one of those you either know or you don't type of thing, so after you do it once it's super simple.  I seriously don't know why people think it's hard.
Look how simple it is !!!
Oh another note, I tried CM Storm Trigger the other day at a local shop.  Since I never tried cherry stabilizers so I never knew what the complaint was about (my friend didn't like his Ducky because of that), then after that I finally understand.  It's actually pretty noticeable.
Offline firebt
« Reply #26 on: Fri, 18 January 2013, 12:11:28 »
lol I agree.
I think the funniest thing is that such a simple process requires a 1:31 minute video.  LOL I thought it would have been like 5 seconds
Offline Ahlitah
« Reply #27 on: Fri, 18 January 2013, 12:18:35 »
I prefer Cherry!
I really don't notice a difference when typing on them, compared to Costar (other then Costar squeeking!).
But when changing keycaps, Costar are a PAIN!
« Last Edit: Fri, 18 January 2013, 12:20:32 by Ahlitah »
Offline Hyde
« Reply #28 on: Fri, 18 January 2013, 12:25:08 »
Watch the video above, the guy did it with 1 hand and like 5 seconds.
« Reply #29 on: Fri, 18 January 2013, 18:13:13 »
The poll is pointless, it's unanimous that Costar is preferred by the masses....
Cherry stabilizers is mechanically complicated but achieves a more even keystroke at greater variety of "keypress angles"  However, it sacrifices that "crisp feel" in order to do so.
« Reply #30 on: Fri, 18 January 2013, 18:18:30 »
Also a pain in the ass to reliably lube.
ah... you could just go "mega-sploooge" all over it.. as long as it's non conducting lube.
