Author Topic: MX The Jesus Switch  (Read 4902 times)
MX The Jesus Switch
« on: Sun, 16 December 2012, 02:28:10 »
Was perusing this article, and these seem like the perfect switches. I need to have them. Where in the world can I get a good supply for a custom build?
http://wiki.geekhack.org/index.php?title=Cherry_MX
Offline GMC
  • Shiny.
Re: Re: MX The Jesus Switch
« Reply #1 on: Sun, 16 December 2012, 03:35:41 »
That is a truly ridiculous name for a switch.
WASD V1 - waiting on R4... - MX Brown
KBT Pure - Zinc caps - MX Brown
Cherry G80-1800 ISO WKL - SkiData caps - MX Clear
« Reply #2 on: Sun, 16 December 2012, 04:10:50 »
Offline gameaholic
« Reply #3 on: Sun, 16 December 2012, 04:47:19 »
I've been looking for some 55g springs for quite a while.  Hopefully keyboard story's new site will have them.  Is there a name for vintage blacks/modern blacks or reds with 55g springs?  I like my ergo clear the best so far so I wonder what super ergo clears are like.  Maybe there should be a section or thread dedicated to just reviews of cherry mx switch/spring combinations.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline TheProfosist
  • Custom Layouts Only!
« Reply #4 on: Sun, 16 December 2012, 06:28:18 »
Super sergo clears probably wont work or will be super laggy as regular ergo clear can already be laggy.
Offline iri
« Reply #5 on: Sun, 16 December 2012, 09:29:27 »
ever experienced lag on ergo clears?
-Ray Bradbury
« Reply #6 on: Sun, 16 December 2012, 09:40:40 »
Keyboard lag? ;D   silliness....
Offline alaricljs
  • I be WOT'ing all day...
« Reply #7 on: Sun, 16 December 2012, 12:58:16 »
I've had stabilized ergo clears hang up a bit on the return.
Filco w/ Imsto thick PBT
« Reply #8 on: Sun, 16 December 2012, 13:29:56 »
regular ergo clears lag for me a little
« Reply #9 on: Sun, 16 December 2012, 13:34:40 »
you mean it doesn't have enough force to travel back?
« Reply #10 on: Sun, 16 December 2012, 13:35:08 »
What lag are you guys talking about.... input lag, or key return latency....
Offline TotalChaos
  • Indy Game Coder
« Reply #11 on: Sun, 16 December 2012, 15:46:06 »
They mean the key does not pop back up fast enough.
Offline Batmann
« Reply #12 on: Sun, 16 December 2012, 16:58:51 »
Offline WhiteFireDragon
    • youtube
« Reply #13 on: Sun, 16 December 2012, 17:05:56 »
This is the most random switch name. Did JesuswasZombie made this up after himself?  8)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #14 on: Sun, 16 December 2012, 17:12:23 »
LOL watdafuq. They are called 'milk' in Asia, so maybe call them skim milks lol.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #15 on: Sun, 16 December 2012, 17:13:59 »
I don't get any on my ergo clear board. Is it lubed like how daddy likes it?
« Reply #16 on: Sun, 16 December 2012, 20:27:55 »
MMB lubed mine yeah. It's not bad but I gotta find my own lube settings.
Offline sth
  • 2 girls 1 cuprubber
« Reply #17 on: Sun, 16 December 2012, 20:35:53 »
i came up with it. follow the light white!
sometimes certain stems have trouble with lighter springs, but it's mostly a manufacturing tolerance issue. if you find a switch is not popping back open, try another spring. always order +20 springs when it comes to light mods, some of them just don't have the umph for tactile switches.
Offline BossBorot
« Reply #18 on: Sun, 16 December 2012, 21:09:48 »
I really want to try browns with the light korean springs as well as linear stems with the light springs.
Right now my favorite two combos are ergo clear and red/ghetto red. To me brown with light springs seem like they would have a similar feel to an ergo clear only lighter where as super ergo clears would likely be a pain due to rebound issues.
I guess following the ergo clear name these would be ergo browns and ergo reds as they are lightened.
Offline sth
« Reply #19 on: Sun, 16 December 2012, 21:18:11 »
like i said if you are thorough you can completely avoid rebound issues. super light ergo clears are one of my favorite switch. it feels 'clunky' in a good way :)
