Author Topic: CM Storm Quickfire Rapid  (Read 2124 times)
Offline dachef
« on: Wed, 26 December 2012, 20:15:33 »
Anyone know how I can go about taking the logo off? It's a great keyboard but I prefer it without the logo.  Anyone know how I can remove it without damaging the surface of the keyboard?  Thank! :eek:
Offline Vintage
Re: CM Storm Quickfire Rapid
« Reply #1 on: Wed, 26 December 2012, 20:37:09 »
If you are looking to buy a new one the new boards have the branding removed out of the box.
Otherwise I would wait for the brandless top covers that are supposed to be getting released. The CM rep was mentioning them earlier.
I would not try to remove the branding yourself unless you want to sand it down and repaint the case.
CM QFR w/ MX Reds  | Logitech G900
Offline oluf
  • formerly olaph
« Reply #2 on: Wed, 26 December 2012, 20:40:49 »
Like Vintage says, you'll need to sand 'er down and repaint... Which also voids the warranty I believe. =(
« Reply #3 on: Wed, 26 December 2012, 21:47:17 »
I'm quite dubious as to the actually release of the case cover.. It's not exactly noob-safe easy to remove, and there's the warranty issue
Offline BlindRAGE606
  • Prince of All Saiyans
« Reply #4 on: Wed, 26 December 2012, 21:49:29 »
Was in the same predicament with my QFT branded, just sold it and bought a unbranded. I wasn't happy until I was rid of that annoying badge.
DUCKY TKL MX BLACK | HHKB PRO 2 | BEAST PH&LACEWOOD
« Reply #5 on: Thu, 27 December 2012, 00:10:56 »
The branding is not so bad once you swap out the keycaps - only one logo next to Esc and one just above the arrow keys.
It is possible to sand down the case to remove the logos - there are a couple of threads about that.
It is also possible to (spray) paint the case - there are threads about that too (mostly relating to Filco recently, but equially applicable).
