Author Topic: MX Blue Keys do not click  (Read 2244 times)
Offline davewolfs
« on: Fri, 18 January 2013, 12:04:44 »
Second Filco.
There are keys which do not click.  Brand new out of the box.  I assume this is not normal.
Re: MX Blue Keys do not click
« Reply #1 on: Fri, 18 January 2013, 13:28:23 »
ok... first...... mash the helll outta the non click key, and see if it's a burn in issue...
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #2 on: Fri, 18 January 2013, 14:07:48 »
Second Filco.
DOA keyboard. Don't talk to Diatec - talk to the seller. Period. Exchanging should not be an issue.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
« Reply #3 on: Fri, 18 January 2013, 15:35:51 »
Second Filco.
right, but first... press the key a few hundred times...
Offline Leslieann
« Reply #4 on: Fri, 18 January 2013, 17:03:24 »
It's a manufacturing issue on Cherry's end.
http://geekhack.org/index.php?topic=39278.msg770043#msg770043
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #5 on: Fri, 18 January 2013, 19:03:50 »
This has reared itself a few times recently, wonder if there was a bad batch of switches that has made its way into a few keyboards?
« Reply #6 on: Fri, 18 January 2013, 20:02:27 »
Post serials? and manufacture dates?
Maybe we can get some data together.
