Author Topic: Cant believe how much greasing Costar stabs actually helps....  (Read 5690 times)
Offline zoolzoo
« on: Mon, 21 January 2013, 20:58:49 »
Greasing the stabilizers on my Filco board makes me feel like I'm typing on a $160 keyboard  :cool:. I was skeptical, but my stabilized keys feel much more solid...especially the space bar. This probably the best "mod" for your board with Costar stabilizers. Do it!
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline Hyde
  • White Tofu Extraordinaire
Re: Cant believe how much greasing Costar stabs actually helps....
« Reply #1 on: Mon, 21 January 2013, 21:04:13 »
I tried that when I swap the stock keycaps to PBT keycaps on my g/f's keyboard.  I didn't find it make it too different.
Though I wonder maybe I didn't apply enough or maybe I didn't mix the white lithium grease properly (need to shake more maybe).
Offline zoolzoo
« Reply #2 on: Mon, 21 January 2013, 21:08:09 »
Well for what its worth I'm currently using ABS caps. Also, I used a bit more than a "dab" of white lithium on the key cap inserts and on the area where the stabilizer connects to the board. I was going for maximum coverage and I think it made a big difference.
Offline Hyde
« Reply #3 on: Mon, 21 January 2013, 23:18:55 »
lol ahhhhhhh that could be why, I think I forgot to grease the joint where the stabilizer connect to the board.  Maybe I'll try that next time  :P
Offline rknize
    • metaruss
« Reply #4 on: Mon, 21 January 2013, 23:22:26 »
I did it to some boards and not others.  Some seem to need it more, I guess.  Cherry stabs benefit from it too.
Russ
Offline daerid
    • Rossipedia
« Reply #5 on: Tue, 22 January 2013, 00:01:38 »
Make sure you get the plastic inserts that clip into the plate, not just the white keycap inserts. It makes a difference.
« Reply #6 on: Tue, 22 January 2013, 10:04:46 »
The plastic base tabs are all I really worry about lubricating. The holes/slots in the back of the keys are of little consequence, it seems to me.
This stuff is great and cheap, I recommend it:
http://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube
« Last Edit: Tue, 22 January 2013, 13:30:34 by fohat.digs »
Pete Hegseth:
"Trump changed the rules of engagement and untied the hands of war fighters .… We don't need burdensome rules of engagement that make it impossible for us to win these wars."
Offline link_tree
« Reply #7 on: Tue, 22 January 2013, 13:03:45 »
I don't know I don't feel the need to lube my own keyboard. it feels great as is.
Offline laffindude
« Reply #8 on: Tue, 22 January 2013, 15:56:22 »
Lube is to get rid of the rattling sound, not to make it feel better.
« Reply #9 on: Tue, 22 January 2013, 16:05:14 »
What kind of lube did you use?
Offline machmkv
« Reply #10 on: Tue, 22 January 2013, 16:09:35 »
Lubing is fun too.  I wouldn't mind if I had 100 keyboards laying around and just lubed them all in.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #11 on: Tue, 22 January 2013, 16:09:50 »
I use Superlube. Same stuff WASD uses and I guess he tested a bunch of other lubes before sticking with Superlube
Plus I used it to lube switches so it has a dual purpose. But you should test first to see if you like it. I like a thicker grease lube where others like a thinner oil type lube
Offline zoolzoo
« Reply #12 on: Tue, 22 January 2013, 17:45:56 »
I used a tube of white lithium I got from Autozone.  :)
Offline lazerpointer
  • ya gotta stay phresh
« Reply #13 on: Tue, 22 January 2013, 17:52:38 »
Saw this thread and noticed my HPE 87's spacebar and backspace were rattling like crazy. Went to Home Depot and got some Danco Sillicon Grease --- perfection. The board is much quieter and you get that solid, smooth feel. Highly recommended.
i type, therefore i geekhack
Offline zoolzoo
« Reply #14 on: Tue, 22 January 2013, 17:56:27 »
Awesome, yah it does add more of a solid "thud" feel as well.
« Reply #15 on: Tue, 22 January 2013, 18:48:12 »
Always be careful with lubricants.
The actual "lubrication" substance is usually carried by something else, and that something can often be a solvent to plastics, short-term or long-term.
Pete Hegseth:
« Reply #16 on: Tue, 22 January 2013, 18:53:55 »
Just the general Multipurpose Grease they have? Where do you get yours from?
« Reply #17 on: Tue, 22 January 2013, 18:55:03 »
Silicon grease is okay and I recommend it - use a q tip to apply. A little one ounce thing of it cost me like 3 bucks at home depot. Found it in the plumbing aisle lol
« Reply #18 on: Tue, 22 January 2013, 18:57:19 »
q-tip? what are you a woman???
I just slab that **** on with a butter knife... "totally serious"
« Reply #19 on: Tue, 22 January 2013, 19:07:16 »
Lol
Offline uJalled
  • Shrimp cracker enthusiast
« Reply #20 on: Tue, 22 January 2013, 19:41:39 »
Technically, you're typing on a 140-150 dollar board, so what does a 160 dollar board feel like?  :-[
btw I've figured out that white lithum grease is the best for the job
Offline Hyde
« Reply #21 on: Tue, 22 January 2013, 19:57:40 »
http://www.homedepot.ca/product/jig-a-loo-super-white-lithium-grease/902322
I use this it says "safe for plastic" and I hope they didn't lie to me  :P
Offline zoolzoo
« Reply #22 on: Tue, 22 January 2013, 20:57:42 »
Hi. It was 159.00 on Amazon.
« Reply #23 on: Tue, 22 January 2013, 22:12:25 »
The deminishing returns on a keyboard is like... 89* degree cliff after $80....
you can throw another $300 for an aluminum case, it does pretty much get nothing except a slightly more solid feel.
In retrospect, I think i could've achieved the same effect had I filled my keyboard with sand, which wouldn't have been all that hard to do......
Offline The_Beast
  • I like wood ಠ_๏
« Reply #24 on: Tue, 22 January 2013, 22:34:11 »
http://www.amazon.com/Synthetic-Grease-Syncolon-Purpose-Lubricant/dp/B000XBH9HI/ref=sr_1_1?ie=UTF8&qid=1358915637&sr=8-1&keywords=superlube
Got mine at Ace hardware
Offline zoolzoo
« Reply #25 on: Wed, 23 January 2013, 06:12:54 »
Interesting story, but it seems out of context posted on a forum where most of us over pay for little pieces of plastic anyway.
