Author Topic: Vortex Cases - New Colors  (Read 4952 times)
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« on: Sun, 27 January 2013, 11:51:20 »
Just saw this posted on their facebook.  Full album here:  http://www.facebook.com/media/set/?set=a.458751290859253.97506.241720585895659&type=3
Offline SmallFry
Re: Vortex Cases - New Colors
« Reply #1 on: Sun, 27 January 2013, 11:59:41 »
Tinlong told me about this a while back, glad it wasn't vaporware. :)) Aggiejy's looks better though, that "Red" looks pinkish.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #2 on: Sun, 27 January 2013, 12:02:34 »
those do look very light compared to the ones I had done....
Offline dirge
« Reply #3 on: Sun, 27 January 2013, 12:09:58 »
Someone force them to make a winkeyless top!
also I'll be getting the 2nd from the top :)
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Sun, 27 January 2013, 12:10:29 »
That blue looks hot. Almost makes me want to get a tenkeyless to put in one. They should make it easy for me and make some limited oni in these or something.
Offline AKIMbO
  • HHKBro
« Reply #5 on: Sun, 27 January 2013, 12:10:58 »
I hope they include feet this time.
| KBD75 (box reds)
Offline jabar
« Reply #6 on: Sun, 27 January 2013, 12:12:18 »
I'd be most concerned about them having standoff holes...
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline DanGWanG
  • Higher Standards
« Reply #7 on: Sun, 27 January 2013, 12:28:28 »
I asked in their facebook if they'll be including stand-offs this time.  Hopefully they will QA their products better this time around.
Offline 4LI4Z
« Reply #8 on: Sun, 27 January 2013, 12:34:14 »
I like the dark grey and black ones. Hope that they include feets this time.
BLING BLING GOLD SPRING
ErgoClear Filco MJT2 TKL || Apple EK II || Hall Effect Keypad || Cherry G81 HAD || IBM M SSK
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #9 on: Sun, 27 January 2013, 15:22:44 »
That dark grey one looks nice...
Offline eyesmiles
« Reply #10 on: Sun, 27 January 2013, 16:07:38 »
mmm that dark grey one. Was planning to get one anodized another color, but now I don't think I have to look for a shope anymore.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #11 on: Sun, 27 January 2013, 16:09:48 »
My wallet is thankful that these aren't 60%. Whew.
« Reply #12 on: Sun, 27 January 2013, 16:17:39 »
Those colors are quite generic, can't go wrong with any of um.
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #13 on: Sun, 27 January 2013, 16:23:31 »
Shame they're TKL and not full size :c
Offline Hyde
  • White Tofu Extraordinaire
« Reply #14 on: Sun, 27 January 2013, 16:29:20 »
Damn makes me want to buy a tenkeyless.
« Reply #15 on: Sun, 27 January 2013, 16:31:29 »
they'd make one, if full size got more popular amongst "us"
Offline Leslieann
« Reply #16 on: Sun, 27 January 2013, 16:33:15 »
It doesn't need standoff holes, it mounts the plate different (but more securely) than Filco. Standoffs could actually create problems trying to mix the two mounting systems.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline AKIMbO
  • HHKBro
Re: Re: Vortex Cases - New Colors
« Reply #17 on: Sun, 27 January 2013, 16:58:01 »
sad that these aren't QFR compatible
They are qfr compatible.  Where did you hear otherwise?
| KBD75 (box reds)
Offline AKIMbO
  • HHKBro
« Reply #18 on: Sun, 27 January 2013, 17:40:55 »
Facebook says Filco and ONI compatible - no mention of QFR.
I had a CM QFR in one of these metal Vortex cases before I sold it.  They are 100% compatible with the QFR.
| KBD75 (box reds)
« Reply #19 on: Sun, 27 January 2013, 17:44:25 »
The plate fits and innards fit..
you do have to do a re-cabling because the quickfire rapid has a second detachable pcb, so basically You put at the Other end of the cable.
Or you can keep the PCB close to the keyboard and just use the 4 pin cable as the detachable portion.. works just fine.
Offline AKIMbO
  • HHKBro
« Reply #20 on: Sun, 27 January 2013, 18:01:49 »
How difficult is this for the average joe?  Because I think it's really silly to not market it will work with the QFR given how many of them are out there.
It's not difficult at all.  Grab a spare cable from a Filco and pop it into the PCB on the QFR.  Viola...you now have 100% compatibility with the Vortex ALU case.
| KBD75 (box reds)
Offline Vintage
« Reply #21 on: Sun, 27 January 2013, 19:04:03 »
Looks really nice. Probably gonna be a bit until we get em though.
CM QFR w/ MX Reds  | Logitech G900
« Reply #22 on: Sun, 27 January 2013, 19:08:47 »
Um...
Ok, ah... yes it'll probably work.. but there seems to be some resistors and caps on the mini quickfire rapid detachable usb board...
So I'm assuming.... they're for signal filtering, and limiting excessive current...
Now, these resistors and filters may be on the PCB of a "filco" while they're on the daughter board in the quickfire..
Just an FYI.. careful...
The surface mounts on the daughter board looks like the insignificant kind though.
Offline laffindude
« Reply #23 on: Sun, 27 January 2013, 21:30:36 »
I still want a gun metal one, which is what I originally ordered...
Offline whiskytango
  • Don't touch the trim
« Reply #24 on: Mon, 28 January 2013, 10:40:50 »
anybody have an idea of what prices will be like for these?
edit: Nevermind, I see them here: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=212
Same case, correct?
« Last Edit: Mon, 28 January 2013, 12:13:26 by whiskytango »
Offline dieseldog49
« Reply #25 on: Mon, 28 January 2013, 12:41:58 »
I just want the option to order one in raw aluminum so I can have it anodized somewhere else.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #26 on: Mon, 28 January 2013, 12:46:32 »
That would be the link directly above your post.
Filco w/ Imsto thick PBT
Offline dieseldog49
« Reply #27 on: Mon, 28 January 2013, 12:48:46 »
No those are Anodized Silver, this has been confirmed in another thread.
Edit: It also says its silver in the description.
Offline alaricljs
« Reply #28 on: Mon, 28 January 2013, 12:55:38 »
It's clear anodized... either way step 1 of anodizing is an acid bath known as pickling which gets rid of anything on the surface including old anodize.  Having no colorant in the old anodize is just extra insurance that you won't get odd coloration.
