Author Topic: Will a Filco top panel fit other, cheaper keyboards?  (Read 5427 times)
Offline spash11
« on: Sat, 02 February 2013, 22:17:38 »
Was just wondering whether the top panel for a filco majestouch tenkeyless (camo) will fit a cheaper board such as a HPE 87 key or Keycool 87 key (e.g. this http://www.ebay.co.uk/itm/HPE-87-Mechanical-Gaming-keyboard-Cherry-MX-Black-switches-W-Black-body-/300738923231?pt=PCA_Mice_Trackballs&hash=item46056fcadf)?
Any feedback or ideas to make it fit, even if it won't right of the bat will be much appreciated :D
Filco Camo top:
HPE87 board:
Re: Will a Filco top panel fit other, cheaper keyboards?
« Reply #1 on: Sat, 02 February 2013, 22:34:32 »
It probably will...
But what's the point?
It's like girls who get major plastic surgery,, yea,, they're prettier, but you just got that little "emotional" hiccup where it's not "all there"....
Like you could buy a fake  Dali, and it could be a great forgery, but, there's just that little thing in the back of your mind.
Offline spash11
« Reply #2 on: Sun, 03 February 2013, 01:43:17 »
It probably will...
You make a very good point, however this filco board has become a very rare commodity in Australia (at a reasonable price). I think replacing the top panel of a cheaper keyboard could be a cost effective solution, although I'm even now considering spending a bit extra and one-upping the original filco with some shiny backlights :D
Offline Leslieann
« Reply #3 on: Sun, 03 February 2013, 01:59:26 »
You may need the bottom half and maybe even the plate.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #4 on: Sun, 03 February 2013, 02:05:29 »
You could also buy a QFR for a similar price and I'm fairly certain it works no problem.
I have been wrong, though, but everything else that fits that filco works with the QFR.
Offline spash11
« Reply #5 on: Sun, 03 February 2013, 02:11:44 »
Thanks for the suggestion, but QFR's are also a rare commodity in AUS >_>. Even on Amazon none of them seem to ship to my location :(
« Reply #6 on: Sun, 03 February 2013, 02:20:14 »
QFR is rare???????
:D
« Reply #7 on: Sun, 03 February 2013, 02:54:36 »
Filco top will NOT fit on a QFR bottom. Owner of both can confirm. As for the boards you've mentioned I'm not sure, I'll let you know if I get my hands on any.
Offline Nunez
  • BACK!
« Reply #8 on: Sun, 03 February 2013, 02:55:23 »
It probably will...
http://www.auspcmarket.com.au/multicam-filco-tenkey-less-camouflage-mechanical-keyboard-tactile-silent-brown-cherry-keyswitches-n-key-rollover-w-sheathed-usb-cable-and-ps-2-converter-puller-green-wasd-keycaps/
They also have Blues and Blacks.
Note that price is shipped.
I miss Ripster :(
HHKB Pro 2 || KBC Poker || Filco MJ2
Offline spash11
« Reply #10 on: Sun, 03 February 2013, 03:12:54 »
It probably will...
Oh, wow! That is actually very decent. How did I skim over this gem? >_>
Offline Nunez
  • BACK!
« Reply #11 on: Sun, 03 February 2013, 03:23:46 »
Not sure lol, I would have initially said PC Case Gear, but their variety seems smaller now for Filco boards.
I miss Ripster :(
« Reply #12 on: Sun, 03 February 2013, 03:31:16 »
No TKL Filco.  But they do have TK Filco camouflage.
I'm waiting to see whether PCCG get the Ducky Zero TKL in.  Might give QFR a run for its money in Australia, especially seeing as how hardly anywhere has the QFR any more.
Offline spash11
« Reply #13 on: Sun, 03 February 2013, 04:03:29 »
YES! THIS! ^^^ Ducky zero is so well priced on PCCG, if only TKL!!!
Offline LifeIsGooD2
« Reply #14 on: Sun, 03 February 2013, 10:22:20 »
how do I take the top of my filco off ? I want to switch the tops between my two filcos ... I like the top of the red ninja better but I use my old brown
« Reply #15 on: Sun, 03 February 2013, 11:17:21 »
de screw,, stick credit card between "front",  PULL outwards, gently......   then do the back... ALWAYS do the front first...
Offline Leslieann
« Reply #16 on: Sun, 03 February 2013, 16:13:41 »
The screw is ion the middle on the bottom under the silver(?) sticker.
Guitar picks and Ipad repair tools work good for opening them.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #17 on: Sat, 25 May 2013, 13:05:02 »
what about the other way around, will a QFR top fit on a FILCO bottom?
Offline cyberwave
« Reply #18 on: Sat, 25 May 2013, 13:08:50 »
i doubt it.. since the screw holes do not line up.
need an owner of both boards to confirm :o
