Author Topic: First Mechanical Keyboard Guide  (Read 6068 times)
Offline ShakeR
  • * Commercial Vendor
    • http://mechanicalkeyboards.com
« on: Sat, 02 February 2013, 23:35:29 »
My best (beta) effort for the often asked geekhack question...
What is the first mechanical keyboard I should buy?
http://mechanicalkeyboards.com/first_mechanical_keyboard.php
Yes, I know many recommendations are out of stock.  Sorry about this!  We're working on adding stock, and I'm working on adding a 'show in stock only' feature. I didn't want to automatically limit options to what we had in at the time.
I also know that not all brands are represented (cough filco...) BUT that's not my fault. I tried!
Bug reports are much appreciated! Suggestions will be met with extreme graciousness or hostility. :D
MechanicalKeyboards.com - What do you type on?
Offline jabar
Re: First Mechanical Keyboard Guide
« Reply #1 on: Sat, 02 February 2013, 23:37:55 »
9/10 of the suggestions are out of stock  :p
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #2 on: Sat, 02 February 2013, 23:45:28 »
not so sure on the keycap question... that one removes alot of choices, because you can buy a cheaper board and separate keycaps and come up with the SAME cost as the boards that come with "stock pbt caps"
So,, maybe work that into your matrix. ;D
Offline ShakeR
« Reply #3 on: Sat, 02 February 2013, 23:46:44 »
Blasted!
I need to add the feature sooner than I expected.
Can you post your result URL or PM it to me?
So much for sleep tonight...
« Reply #4 on: Sat, 02 February 2013, 23:59:36 »
Brilliant!
Offline ShakeR
« Reply #5 on: Sun, 03 February 2013, 00:23:58 »
'In stock only' button added!
Offline jabar
« Reply #6 on: Sun, 03 February 2013, 00:24:55 »
Blasted!
That was before the feature. It seems to work well now!
Just need to make the output grid a bit nicer then it'll be just fine.
e: get some sleep! it's like 1:30am on a Sunday
Phantom 7bit
Offline ShakeR
« Reply #7 on: Sun, 03 February 2013, 00:28:42 »
Blasted!
So says the guy who's still awake ;)
Offline ShakeR
« Reply #8 on: Sun, 03 February 2013, 00:30:45 »
Added the word 'stock' to key cap question.  Should help clarify.  Thanks for your input!
edit: I also made sure to mention this in the 'results explained' section for the key cap question.
« Last Edit: Sun, 03 February 2013, 00:32:57 by ShakeR »
Offline Nunez
  • BACK!
« Reply #9 on: Sun, 03 February 2013, 02:39:56 »
It's broken. I don't want any of the suggested keyboards :(
That being said, well done! Looks like it'd work quite well for a first buyers guide.
Edit: I said no to backlit and yet every (I think) result were backlit keyboards? Not sure what happened there.
« Last Edit: Sun, 03 February 2013, 02:42:41 by Nunez »
I miss Ripster :(
HHKB Pro 2 || KBC Poker || Filco MJ2
Offline laffindude
« Reply #10 on: Sun, 03 February 2013, 05:41:20 »
I own 4 of 6 top results (3 of them are Pures ;)). 5th is on the way, and 6th is fullsized Ducky of which I have no interest in.
My recommendation is changing the numpad question to include whether or not they want a board smaller than tenkeyless. Although I love my Pures, it isn't for everyone.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #11 on: Sun, 03 February 2013, 05:50:14 »
It's genuinely broken for me. Clicking doesn't reliably give results.
My results
Results are miles off, too. Noise not a concern, it recommended Reds and Browns - should be recommending Blues. Especially for mix typing/gaming and spreadsheet work.
Also inappropriately high placing on the DK9087G2 TKLs.
KBT ONE should definitely be well above KBT ONI, unless you know something I don't about the differences there? Both are PBT. Most troubling of all though is that there were zero blues recommended. Not a one. Not even an Alps Green. :(
« Last Edit: Sun, 03 February 2013, 05:53:34 by rootwyrm »
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline AKIMbO
  • HHKBro
« Reply #12 on: Sun, 03 February 2013, 08:58:14 »
This is a pretty cool little advanced keyboard search disguised as a guide.  I like it!
| KBD75 (box reds)
Offline ShakeR
« Reply #13 on: Sun, 03 February 2013, 12:58:10 »
My results
Originally, Blues not included for any type of gaming.  I just changed it so Blues do get suggested for mixed use.
Re: One vs ONI, I'm working on a keyboard rating based on reviews / sales, but that isn't active yet so differences like this aren't factored yet.
« Last Edit: Sun, 03 February 2013, 13:05:19 by ShakeR »
Offline ShakeR
« Reply #14 on: Sun, 03 February 2013, 13:03:07 »
Keep in mind that it will offer the best possible keyboards even if not all of them fall perfectly inline with all 10 answers.  It should show you which answers line up with each keyboard - you can hover your mouse over the Green Checks and Red X's to see what does and doesn't match a certain suggestion.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #15 on: Sun, 03 February 2013, 13:08:34 »
Good job. Seems to have worked well for me, reccomending me Pokers and Pures primarily with Ducky and CM tenkeyless for the rest with red and black switches.
Offline FoxWolf1
  • 154
« Reply #16 on: Sun, 03 February 2013, 13:13:28 »
When I tell it I want backlit-compatible caps, it counts that against Deck, since they're not ABS. >.<
And it seems to really, really like recommending Ducky...
Offline nsrexler
« Reply #17 on: Sun, 03 February 2013, 13:57:16 »
No big surprise there, Ducky is one of the biggest brands that MK sells.
Offline rootwyrm
    • My Website!
« Reply #18 on: Sun, 03 February 2013, 15:07:48 »
My results
Ahha, that would do it then, definitely. And the One vs. ONI should have happened due to the layout (104 vs TKL) IMO. Believe me, I am finding the lack of numpad ... difficult when I'm dealing with my spreadsheets. ;/
Offline ShakeR
« Reply #19 on: Mon, 04 February 2013, 15:58:42 »
It's hard making everything concise and simple - keep in mind it's for a first time buyer, so having the PBT cap answer say something like "Some of these will work with backlit too!" concisely is really tough.
The main reason I used 'Backlit ready' as the first item for ABS keys is I was worried there would be a lot of people saying "Yes, I want backlit" and then picking "Durable, expensive keycaps" (PBT), this would pretty much limit all the top choices to Deck.  There are some exceptions like this that do improperly skew the results.
Regarding Ducky being favored: Until we get our 'keyboard ranker' up and running, TIED results are ordered by our favorite brands. This only applies to tied results though.  Even our least favorite brand will outrank a Ducky if it fits more of the criteria specified.  (8/10 vs 7/10)
Offline uJalled
  • Shrimp cracker enthusiast
« Reply #20 on: Mon, 04 February 2013, 16:18:29 »
Wow that's pretty neat. I never found that
Offline BucklingSpring
« Reply #21 on: Mon, 04 February 2013, 18:48:29 »
I don't like question #8 and #10 - The rest is great.
8) Describe your preference in stock key caps.
Undecided / Don't Care
Backlit ready, less expensive, and less durable. More expensive and more durable.
- As other said... Take out the Backlit ready.
10) Not including 'modifier' keys like CTRL and Shift, how many keys will you need to press simultaneously?
Never more than 3. Never more than 4. Never more than 6. Never more than 20. All of them.
Lol at never more than 20 and all of them. I mean cmon. We know this is about KRO, but anything over 10 doesn't make much a difference.
Boards I own, click ->
« Reply #22 on: Mon, 04 February 2013, 18:53:43 »
I'm surprised you didn't ask about WPM's to figure what kind of polling rate would be good.
Something to highlight those 1000Hz keyboards :-)
1000Hz - Yet another LoL, - what was wrong with 1Khz?
Offline LifeIsGooD2
« Reply #23 on: Mon, 04 February 2013, 19:45:36 »
pretty cool
« Reply #24 on: Mon, 04 February 2013, 19:51:51 »
Because 1000Hz > 1kHz, it's a bigger number duh. :))
Offline rootwyrm
    • My Website!
« Reply #25 on: Mon, 04 February 2013, 20:32:18 »
That actually is the truth. It's pure marketing. Just like that "feature."
Offline LifeIsGooD2
« Reply #26 on: Tue, 05 February 2013, 08:46:29 »
this is really cool
Offline ShakeR
« Reply #27 on: Tue, 05 February 2013, 08:55:40 »
Quote from: BucklingSpring
You'd be surprised how many people ask about NKRO when deciding what to buy. I don't think it matters either, but I give the people what they ask for. :)
See poll results here http://mechanicalkeyboards.com
Offline ShakeR
« Reply #28 on: Tue, 05 February 2013, 08:56:43 »
this is really cool
Thanks! :) It took a while to develop.
Offline iri
« Reply #29 on: Tue, 05 February 2013, 14:17:13 »
why on earth do people need backlighting?
-Ray Bradbury
Offline 1839cc
« Reply #30 on: Tue, 05 February 2013, 18:21:12 »
NKRO is a great thing if you want to play certain REALLY OLD games with 2-4 people trying to use one keyboard at the same time. I can't think of too many other uses for it though.
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
Offline FoxWolf1
  • 154
« Reply #31 on: Tue, 05 February 2013, 19:15:35 »
You don't even need two people to break six keys at once, just a game that is played entirely via keyboard-controls with any significant degree of complexity to them. Even with a game that's right on the border of exceeding the limit, you can occasionally break it if you accidentally catch both the key you're trying to press and the one next to it (not good if the one you're trying to press is the one that then gets omitted).
Now, once you get over 10KRO, then you start getting into the realm where you'll only hit the limit with multiple users...but in that case, your keyboard has already got to have some way around the normal 6KRO limit anyway.
Offline ShakeR
« Reply #32 on: Thu, 07 February 2013, 21:22:47 »
Yeah, I agree with this.  A keyboard only game seems to justify 10KRO+.  It's about the only thing I can come up with though.
