Author Topic: New keyboard for typing  (Read 5064 times)
Offline brialona
« on: Sat, 09 February 2013, 17:37:01 »
I have a qfr with cherry blues and I like it.  Are there any other switches that's good for 100% typing and no gaming?  I have only tried blues, reds, browns. And realforce but those are too expensive.  The max I am willing to spend is about 100.  How are the alps? Or green and black?
ozil
Re: New keyboard for typing
« Reply #1 on: Sat, 09 February 2013, 17:38:44 »
I have a qfr with cherry blues and I like it.  Are there any other switches that's good for 100% typing and no gaming?  I have only tried blues, reds, browns, and realforce but those are too expensive.  The max I am willing to spend is about 100.  How are the alps? Or green and black?
ah... Get the quiet pro then..
Have you tried some O-rings? The soft ones are fun... the hard ones are pointless...
Make some ghetto rings tonight for fun..
Offline inteli722
« Reply #2 on: Sat, 09 February 2013, 17:39:49 »
I would assume that Greens would be great for typing. Blacks are basically heavy reds, so if you liked those but thought they were too light, then Blacks are the way to go, but otherwise, if you like Blues, you'll likely like Greens, as they are basically heavy blues.
Waiting for: Phantom Plate
« Reply #3 on: Sat, 09 February 2013, 17:45:37 »
VERY heavy..   I measured a few of my green switches 88g right before click.
Offline brialona
Re: Re: New keyboard for typing
« Reply #4 on: Sat, 09 February 2013, 21:20:17 »
I always read people talking about orings but I never quite understood what it does and where to get it.  What does it do if I add it to my blues? And what the heck are ergo clears?
On the other hand, What is the closest thing to a topre realforce but not as expensive?  I tried it when I was in Tokyo and I really enjoyed it
ozil
Offline inteli722
« Reply #5 on: Sat, 09 February 2013, 21:28:04 »
If you add O-rings to your blues, you get a shorter travel distance and a quieter key.
Ergo-Clears are Clear switches
with Blue/Brown/Red springs. They are less hard than regular Clears.
As far as I've heard, Topres feel one-of-a-kind, so i'm not sure if you can get a substitute. I'd say if you really liked Topres, go with Topres. Now it's just a matter of: variable, uniform 45g, or uniform 55g!
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #6 on: Sat, 09 February 2013, 21:30:02 »
Maybe give buckling springs a try? You might be able to pick up a Model M on eBay for under $100.
Quote from: Samuel Adams
Offline Hyde
  • White Tofu Extraordinaire
« Reply #7 on: Sat, 09 February 2013, 21:53:08 »
Yeah from what I've gathered, if you just want a keyboard for typing there are a few choices.
MX Blue
MX Green
Buckling Spring
ALPS
Topre
I'd recommend a Unicomp or Matias if I were you  :)
Offline sordna
« Reply #8 on: Sat, 09 February 2013, 21:55:55 »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Sat, 09 February 2013, 22:00:13 »
Get a Cherry G80-something and stick whites in it. They are lovely.
Offline 1839cc
« Reply #10 on: Sat, 09 February 2013, 22:16:02 »
I love my clears. I use them for everything. They have a firm definite tactile point with an oddly soft cushion of rising spring rate underneath.
Not for everyone, but worth trying if you get the chance.
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #11 on: Sat, 09 February 2013, 22:36:41 »
I would recommend a Quiet Pro based on everything I've read, but I just ordered one and haven't actually tried one yet. The reviews (professional, enthusiast and otherwise) have been resoundingly positive across the board and that is what I'm basing my decision on (that and the fact that I prefer tactile switches).
BTW, don't want to sound too strident, but O-rings are a half-@zed way to make a keyboard quieter. I would much rather hear a key hit both at the bottom and top of the keystroke than just at the top (which conveys no useful information as opposed to hearing the key reach the bottom); noise from only the top is just a distraction IMHO.
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
« Reply #12 on: Sat, 09 February 2013, 22:38:16 »
If you are unsure about O-rings, order the WASD sampler kit.  It comes with a selection of O-rings, plus one of each colour keycap plus, optionally, one of each major MX switch (blue, black, brown, red).
Offline tauburn
« Reply #13 on: Sat, 09 February 2013, 22:38:41 »
get greens. theyre not that heavy people just have baby fingers. they're like blues but harder to bottom out so you end up typing faster. not to mention the click and bump happen at the same time which is a huge improvement over blues
Offline Hyde
« Reply #14 on: Sat, 09 February 2013, 22:53:06 »
I don't know why you guys recommend o-rings, the OP never mentioned anything regarding noise.
As for typing feel, I find o-ring reduce the travel distance and makes typing feel really weird.  Not a fan of it personally.  Unless the intent is for reducing key travel so you type "faster", in that case I'd say get a scissor switch and save yourself some money.
But from what I've gathered the OP just want different choices for typing other than MX Blue isn't it?  :confused:
Offline Burz
« Reply #15 on: Sat, 09 February 2013, 22:56:52 »
Yeah but I'll bet that pressing Shift along with the rest of the keys is just a bit too much strain with those heavy switches. :P
Offline brialona
« Reply #16 on: Sat, 09 February 2013, 23:17:54 »
Yes exactly, I was thinking either buckling springs or alps.  Which one do you guys prefer to type on? Where can you get g80 boards with green? I've been looking around and they seem hard to find
« Last Edit: Sat, 09 February 2013, 23:30:22 by brialona »
ozil
« Reply #17 on: Sun, 10 February 2013, 01:03:37 »
Do NOT do Ergo clears unless you can find those 65 g springs... I would even say we need something like 70g
« Reply #18 on: Sun, 10 February 2013, 01:04:54 »
Orings makes the landing very different. and reduced travel distance is a "technical" plus.. because it makes timing control easier when you're playing the typing games.
ALSO, i believe most people are doing O-rings "WRONG" and the 40a is still MUCH too hard.
I use the silicone rings I cut from silicone rubber dome keyboards. They're around 20-30a,  they return that walkin' on sunshine feel of bottoming out a rubber dome, which takes away the harshness of Cherry MX landing.  :D
    a. Shore 20A = Rubber Band
    b. Shore 40A = Pencil Eraser
    c. Shore 60A = Car Tire Tread
    d. Shore 70A* = Running Shoe Sole
    e. Shore 80A = Leather Belt
    f. Shore 100A = Shopping Cart Wheel
Offline sordna
« Reply #19 on: Sun, 10 February 2013, 10:56:02 »
Nice ranking! I have tried 20A durometer dampening (EK black soft-landing pads) and while wonderfully shock absorbing, I found that I couldn't tell the moment that the keystroke touches the pad, so I ended up pushing down the switches harder than needed. With 40A I can tell when I'm bottoming out, so it gives the tactile feedback that tells you to back off and type lighter. But yeah, anything over 40A is too hard for me.
Offline tauburn
« Reply #20 on: Sun, 10 February 2013, 11:01:03 »
maybe if you're 90 years old and have arthritis... seriously the "heavy switches" aren't really that heavy
Offline Burz
« Reply #21 on: Sun, 10 February 2013, 16:12:03 »
That was a riff on your apparent aversion to the Shift key...
Offline tehcliff
  • Model M Lover
« Reply #22 on: Mon, 11 February 2013, 21:46:49 »
I'm a huge fan of buckling spring so I would give a Model M (from eBay) a try if I were you.  If you want a new Model M clone, you can always get one from Unicomp.  I have both and while they're slightly different in some aspects, both are very satisfying for serious typists.
Cliff
Offline lazerpointer
  • ya gotta stay phresh
« Reply #23 on: Mon, 11 February 2013, 23:19:02 »
100% agreed! Everybody should own a buckling springs board. I type on my Unicomp Customizer 101 daily (well, my Topre board will arive tomorrow, LOL) and I probably can't go a week without at least busting out the Unicomp one or two times ;) you can get Unicomp buckling spring "Model M clones" from pckeyboard.com
i type, therefore i geekhack
Offline uzoc
« Reply #24 on: Mon, 11 February 2013, 23:25:24 »
You can try TWO o-rings for each key/switch.
If you test it with a blue switch you'll be able to hear the click right before it bottoms out.
In my other thread I post two the links from Amazon where you can get them cheaper.
« Reply #25 on: Mon, 11 February 2013, 23:57:28 »
Those rings are too hard.
Offline brialona
« Reply #26 on: Tue, 12 February 2013, 05:38:00 »
I was thinking about model m's for a long time.  Either that or the new quick fires with green switches.   Anyone know when the expected arrival is for the cm qf?
ozil
Offline hlehmann
« Reply #27 on: Wed, 13 February 2013, 16:40:57 »
Model M.  Years of typing and feeling "comfortable" on lenovo/ibm laptop keyboards dissapated in about 2 hours, now I miss my M whenever i'm in keyboard transit.  I type all day long, and about 80wpm, cant recommend it enough.
My only other experience is white alps, which is clicky and lite - a little wobbly compared with my ibm.  But who wants to compare to an M.
