Author Topic: CM Storm Trigger power supply help?  (Read 15687 times)
Offline NoobyMcnoob
« on: Mon, 11 February 2013, 14:51:29 »
I'm going to purchase a CM storm trigger, and I think I'll need the 5v power adapter. Amazon recommended one but reviews said it destroyed their keyboards, and on other ones people said that they ended up buying one and have it not fit. Could you guys recommend one to me that you know will work?
Thanks for teh help! ;D
« Last Edit: Sun, 17 February 2013, 17:51:30 by NoobyMcnoob »
Offline rootwyrm
  • The Hands of Steel
    • My Website!
Re: CM Storm Trigger Accessories help?
« Reply #1 on: Mon, 11 February 2013, 14:57:46 »
Wrist rest, I can definitely help you with.
This is the one I use. The IMAKs seem weird at first, but they are incredibly, incredibly nice. The fabric is extremely comfortable and non-abrasive (a major complaint with all the others) and once broken in, it's pretty much as good as it gets. Doesn't hurt that it's also relatively cheap. It always seems and feels high, but trust me, it's the correct height.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline CM-Rajiv
  • CM Storm Rep
  • * Commercial Vendor
« Reply #2 on: Mon, 11 February 2013, 15:53:08 »
http://www.amazon.com/Premium-External-Adapter-2-5-inch-Enclosure/dp/B001PUSERA/
That's the link I was given by our customer service rep.  Hope that helps!
Cooler Master USA - CM Storm Marketing Team - [CM Storm Trigger CherryMX Green Switch]
Offline NoobyMcnoob
« Reply #3 on: Sun, 17 February 2013, 17:50:35 »
That's the one that amazon recommended which destroyed some people's keyboards and didn't fit properly. Could you recommend me another one? >.>
Here are some of it's reviews:
"I bought this power supply to use for my CM storm trigger keyboard. It blew out two keyboards with its faulty voltage. Horrible company"
"I needed a AC/DC Adapter for my Cooler Master Storm Trigger. I was directed to this item through the Storm Trigger product on Amazon. I though it would be compatible, but the adapter plug was too big for the keyboard."
Re: CM Storm Trigger power supply help?
« Reply #4 on: Sun, 17 February 2013, 18:01:09 »
You can go and buy a "premium" ac-adapter.. but they'll be around $50, worth it?
Offline NoobyMcnoob
« Reply #5 on: Sun, 17 February 2013, 18:05:49 »
It requires a DC adapter as far as I know
Offline NoobyMcnoob
« Reply #6 on: Mon, 18 February 2013, 12:26:16 »
bump
Offline CM-Rajiv
  • CM Storm Rep
« Reply #7 on: Tue, 19 February 2013, 10:58:22 »
Hi there,
Turns out the item # we were providing from Amazon was changed and no longer is compatible with Trigger. We are currently working with Amazon to find the new correct product and updating our documentation accordingly. I'll provide an update asap.
Offline NoobyMcnoob
« Reply #8 on: Thu, 21 February 2013, 21:38:39 »
Thanks for the reply, I hope you get this sorted out before I get the keyboard! It's already in the mail :D
Offline CM-Rajiv
  • CM Storm Rep
« Reply #9 on: Fri, 22 February 2013, 12:32:55 »
http://www.ebay.com/itm/5V-2A-AC-DC-Power-Supply-Replacement-Adapter-1-1mm-x-3-5mm-Tip-Center-/190696186835#vi-content
OR
http://www.shopping.com/5v-2a-acdc-power-supply/pp4sM5ac8qBkPhLc8e36RQ==/info?sb=1
Looks like that matches the spec measurements the Trigger needs.
Offline volatilecoffee
  • Formerly ybnrmalatall
  • I don't feel any certain way.
« Reply #10 on: Fri, 22 February 2013, 12:55:30 »
-redacted
« Last Edit: Tue, 11 January 2022, 23:36:22 by ybnrmalatall »
Linear gang needs to rise up against the tactile hipsters.
Offline OwnageHN
« Reply #11 on: Wed, 24 April 2013, 16:15:18 »
I am resurrecting this thread since I just recently purchased a CM Storm Trigger.  CM-Rajiv posted 2 links back in February but only 1 of them works.  He also mentioned Amazon changing item IDs on products so old links might go to different products.  Is this still compatible with the CM Storm Trigger?
Offline Tarzan
  • formerly known as Greystoke
« Reply #12 on: Wed, 24 April 2013, 17:49:37 »
Yes, it's "compatible."  Would I recommend it?  No.   :mad: :mad:
Maybe my CM Trigger is atypical, but the tip of the power adapter (shiny metal bit) is too long, almost half of it is still exposed when the adapter is plugged into the keyboard.  May not be a big deal, but it bugs me.
Apart from the fitting, it seems to work.  But honestly, I can't tell the difference in the lighting levels, the highest level seems the same with or without the power adapter plugged in.  I haven't tried the USB ports, if you use those for charging a phone or something the power boost might be useful, but I prefer the uncluttered desk space.
Just my two cents.  Since I'm also selling my CM Trigger (I want a keyboard with Green LED back-lighting...) I may be a biased reviewer.   ;D ;D
Offline CM-Rajiv
  • CM Storm Rep
« Reply #13 on: Tue, 30 April 2013, 16:57:35 »
http://www.cmstore-usa.com/trigger-keyboard-dc-usb-adapter/
We have an official USB Adapter for this
Offline BucklingSpring
« Reply #14 on: Tue, 30 April 2013, 18:14:51 »
At that price why don't you include it with the keyboard instead of selling separately?
Boards I own, click ->
Offline Juri
« Reply #15 on: Mon, 03 June 2013, 11:00:55 »
And another resurrection.
I tried to order the official adapter because I'm getting cutouts every hour or so with my keyboard. Guess what? Doesn't ship to the UK.
So whats a Brit supposed to do?
« Reply #16 on: Mon, 03 June 2013, 11:02:40 »
Maybe you could find someone in the USA who would proxy for you?
Offline fateswarm
« Reply #17 on: Mon, 03 June 2013, 11:32:18 »
You don't need a discreet power adapter.
Get a powered hub. It's designed to work well with USB devices guaranteed and they get other devices too.
They start from ~2A and go up.
Read this experience I had for full info.
« Last Edit: Mon, 03 June 2013, 11:36:11 by fateswarm »
« Reply #18 on: Mon, 03 June 2013, 11:33:24 »
You can get a anything from 2A to 5A,  I recommend the 5A, the BIGGER the BRICK itself the better, because it's likely provide more stable voltage at lower loads.
Offline fateswarm
« Reply #19 on: Mon, 03 June 2013, 11:41:08 »
The one I got for the TK is 2.5A and it appears stable.
I suspect they also draw current from the computer if they run out, though I'm not sure. An electronics expert would know for certain.
