Author Topic: Went back to a cheap rubber dome for a day  (Read 19736 times)
Offline BlindRAGE606
  • Prince of All Saiyans
Re: Went back to a cheap rubber dome for a day
« Reply #50 on: Sun, 17 February 2013, 20:08:16 »
I'm forced to use a crappy rubberdome at work. Tempted to bring my topre to work, but the school's IT policy is a bit rough.
DUCKY TKL MX BLACK | HHKB PRO 2 | BEAST PH&LACEWOOD
Offline inteli722
« Reply #51 on: Sun, 17 February 2013, 20:20:04 »
My school uses those Lenovos...they're TERRIBLE
Tempted to pack my Leopold, but I'm afraid of losing it (almost forgot my laptop once) and/or it getting stolen :( (I also don't have anything else to use at home when I get there...)
Waiting for: Phantom Plate
Offline MKULTRA
  • telling it how it is
« Reply #52 on: Mon, 18 February 2013, 00:28:27 »
They won't even let you bring a keyboard to school?  The ****?
Offline stingrae
« Reply #53 on: Mon, 18 February 2013, 02:22:31 »
It's funny because most people don't seem to have any clue how expensive my keyboards are. Any thief probably resides here on geekhack :D.
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
Offline vivalarevolución
« Reply #54 on: Mon, 18 February 2013, 08:58:32 »
My work has a strict IT policy, but what I did was ask permission until somebody said yes in writing that I could bring my own devices. I also explained the benefits of ergonomic devices. Now I have that permission in writing and I can reference that email anytime somebody might comment. Here's the thing about IT: they probably despise their job as much as the next person, so they most likely will not bring down the hammer if they see you using your Leopold.
Offline inteli722
« Reply #55 on: Mon, 18 February 2013, 09:55:07 »
I happily spread the word on how much I spend on keyboards :D
Offline Mainian
« Reply #56 on: Mon, 18 February 2013, 12:01:14 »
Currently at work. One PC is using a Noppoo Choc Mini (Red) and the other is using a Membrane from 10 years ago.
T_T. The pains of an intern.
Offline HybridCore
« Reply #57 on: Mon, 18 February 2013, 12:38:32 »
I cringe whenever I'm at school. I can't stand rubber domes any more because they're so mushy under my fingers (I personally don't like Topre that much either because of the little bit of mushiness I can feel because of the rubber dome in it).
Some scissor switch keyboard I can deal with and can actually make me type faster. The shorter travel distance until I bottom out helps me a bit just in case I bottom out by accident.
Offline zoolzoo
« Reply #58 on: Mon, 18 February 2013, 20:35:11 »
I just got around to replacing my dell membrane board at work with a QFR, very refreshing.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline rodo111
« Reply #59 on: Mon, 18 February 2013, 22:00:49 »
After using mechanical boards (blue switches) for just a few weeks, I don't HATE rubber domes (per say), but I do notice how not nice they feel all of a sudden.  I guess it's only a matter of time...
Offline sth
  • 2 girls 1 cuprubber
« Reply #60 on: Mon, 18 February 2013, 22:06:57 »
My teenage daughter has one of those. She loves it because "it is white"
It is a truly horrible board, even worse than the "Apple Design Keyboard" - which is at least worth buying out of a junk pile for a dollar for the nice Alps-compatible PBT caps.
JESUSSSSS buy her a white keycap white base mechanical
Are you trying to make your daughter finger less? :P
there is no better way to make your teenage offspring think your hobby is lame than to try to get them into it.
« Reply #61 on: Tue, 19 February 2013, 02:55:29 »
Well regarding my work's IT policy, any type of peripheral could potentially be a keylogger or unverified storage on the network that could collect, steal, macro functions. PSU strips can do this even, along with mouse and keyboard+usb stuffs. Its funny cause, our department isn't exactly needing rigorous policies as much due to our location as the IT HQ is in the same building. Seemingly more ironic, i'm not even doing anything related IT in the building so I get to endure the wrath of the overzealous nerds enforced to the building plebs.
« Last Edit: Tue, 19 February 2013, 02:58:38 by BlindRAGE606 »
« Reply #62 on: Tue, 19 February 2013, 16:32:10 »
sth - exactly right
However, I did get out a nice clean AEK2 and set it up on her desk, without a word. Since it doesn't click, and has a little rainbow Apple on it, she may take to it. Those dampened creams are OK, if a bit heavy.
- D Trump 2026-10-24
Offline HybridCore
« Reply #63 on: Tue, 19 February 2013, 20:27:13 »
Hover between the two so in the future you won't feel tempted to replace the keyboards you use at work and such with mechanical ones. :P MUST NOT SPEND MORE MONEY!
Offline paradox
« Reply #64 on: Fri, 01 March 2013, 00:22:35 »
Same here...or when I still had a job anyway.   We were not allowed to attach 'any foreign devices' to our PCs.  It was more to do with keeping all of computers uniform with standardized equipment.  So if you were to call up tech support with any issues, or your computer suddenly broke, there would be no fingers to be pointed.
We also had the no USB device rule since it was a government agency but I couldn't explain my way out of having my Noppoo Choc at work as hard as I tried.  If I ever get a typing-heavy job again I'm celebrating with another keyboard purchased specifically for use in the office.
Offline h2gofast
« Reply #65 on: Sat, 02 March 2013, 09:00:40 »
I keep a rubber dome model m on my sons pc and when I have work. on it,  its not that bad.  and the thing takes a beating.
Offline Mountain Man
« Reply #66 on: Sat, 02 March 2013, 10:11:42 »
I've been using mechanical keyboards regularly for over a year (first a Razer Black Widow with MX Blues and now a WASD custom with MX Browns) and it surprises me just how stiff and unyielding a rubber dome feels in comparison.  It just doesn't make for a pleasant typing experience.  I could never go back to using rubber domes every day.
Offline mechanisch
« Reply #67 on: Sat, 02 March 2013, 11:29:27 »
Whenever I have to type on a rubber dome board again (usually for a family member or client), its like stepping through the Twilight Zone into this alternate weird dimension where all the things that could go wrong did!
Hehe, seriously though, after any significant time on mechs, its *very* hard to appreciate the dome.
Offline iri
« Reply #68 on: Sat, 02 March 2013, 12:36:29 »
...before you buy a topre board and start writing "i ****ing love my topre" on gh.
-Ray Bradbury
« Reply #69 on: Wed, 15 January 2014, 14:13:29 »
Did it again today.  Forgot my mechanical board at home.  Had to use the company provided Dell rubber dome.
The horror!
I'll be recovering for the next week.
Offline ideus
  • Björkö.
« Reply #70 on: Wed, 15 January 2014, 14:27:37 »
I really love my rubber dome??????? Haha! Just kidding, but I really hate my browns, but I just can't justify the price of a topre.
Offline JPG
  • Model F is my new passion!
« Reply #71 on: Wed, 15 January 2014, 14:31:44 »
Sometimes I need to help a coworker and go at his desk and sometimes, rarely at least, I need to use his keyboard else it would be too long to tell him what to do.
The pain. I hit the keys, then double watch what I just entered since the signal that my fingers sends to my brain is: Error, feedback from keyboard is corrupted. Plz contact your administrator and tell him your keyboard is broken.
Then I go back to my desktop, use my keyboard, and enjoy the feeling of money well invested!
« Reply #72 on: Wed, 15 January 2014, 14:36:05 »
This is all in your head... guys..
The difference is NOT so radical between dome vs cherry mx..
and between topre and dome, there's virtually no difference at all.
Even with my beloved Egdx, the only difference that's notable is LONG term usage. where the regular flat keyboards give me shoulder and wrist pain..
Ya'll xaggeratin'
« Reply #73 on: Wed, 15 January 2014, 15:04:45 »
Ya'll xaggeratin'
More than anything, I think the build quality and metal plates make the biggest difference.  Switches are just a nice bonus.
Offline davkol
  •  Post Editing Timeout
« Reply #74 on: Wed, 15 January 2014, 23:13:54 »
Bottoming out is painful at times. The times when I'm forced to use the Apple Aluminium keyboard and alikes. I don't mind soft, light rubber domes, but nothing beats linear Cherry MX switches in this regard.
« Reply #75 on: Wed, 15 January 2014, 23:20:04 »
I bottom out most of the time, even with blacks, greens and BS.
I like bottoming out :)
Offline atlas3686
  • HHKB Elite
« Reply #76 on: Thu, 16 January 2014, 01:13:06 »
I have one normal rubber dome that I still make use of and that's the logitech dinovo edge keyboard. Pretty well built keyboard and it's bluetooth and has a little track pad on the bottom right so it's perfect as a lounge media pc keyboard. Not an entirely terrible typing experience either. Lasted over 5 years so far as well.
« Reply #77 on: Thu, 16 January 2014, 02:59:52 »
I still reckon that typing on a rubber dome keyboard feels like typing on a sponge.
« Reply #78 on: Thu, 16 January 2014, 03:15:32 »
some people like sponge...
« Reply #79 on: Thu, 16 January 2014, 03:47:51 »
But not to type on.
Offline iri
« Reply #80 on: Sun, 19 January 2014, 03:28:48 »
i really like high quality rubber domes.
that said, when i go help a colleague, i have to type on their logitech k120. domes far from perfect, very slippery caps surface, no stabilization, awful experience. and also their caps lock keys usually act like caps lock, which is also awful.
-Ray Bradbury
