Author Topic: Leapold Questions  (Read 3318 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
Leapold Questions
« on: Fri, 22 February 2013, 12:30:00 »
So I wanted to get a good quality board with cherry stabilizers to give them a try and I wanted an additional switch type anyway.
I heard great things about Leapold but didn't like their case design. Until I saw the FC700R which has the exact style I like. Only thing is, I don't see them on EK.
Is this an old model? Or just the new one? Is it carried, or limited supply or something?
I also noticed they come with PBT caps. I want one.
Thanks guys <3
« Last Edit: Fri, 22 February 2013, 12:31:33 by OnTheBrink »
Re: Leapold Questions
« Reply #1 on: Fri, 22 February 2013, 12:32:55 »
It is a current model. It seems like they're only being carried in Asia right now. You can try to get someone to proxy it over from Australia. I have one but I bought mine in a sale from the classifieds. I will say it is a very very nice board.
Edit: It's also spelled Leopold :P
« Reply #2 on: Fri, 22 February 2013, 12:36:00 »
Just remember.. the MX white case is painted white.. and the caps are a slightly different white than the case.
Offline OnTheBrink
    • Wired In Store
« Reply #3 on: Fri, 22 February 2013, 12:40:17 »
Although, I see they make a black version.
« Reply #4 on: Fri, 22 February 2013, 12:41:00 »
I have the charcoal one, just FYI
Offline Jocelyn
  • 조셀린
« Reply #5 on: Fri, 22 February 2013, 12:42:07 »
They're actually graphite and that's exactly what I'd get. It's the perfect dark grey color imo.
Offline Lastpilot
  • Power stance
Leapold Questions
« Reply #6 on: Fri, 22 February 2013, 12:42:58 »
I'm not sure how helpful this is but you can order internationally from Leopold.co.kr as long as you have a Korean credit/debit card. This is what I plan on doing when the 660M comes out but I haven't looked at their shipping rates yet.
So I guess if you can somehow get a proxy with a Korean card, you can order directly from the manufacturer.
Offline OnTheBrink
    • Wired In Store
« Reply #8 on: Fri, 22 February 2013, 12:48:17 »
Sorry, you're right :D
Offline OnTheBrink
    • Wired In Store
« Reply #9 on: Fri, 22 February 2013, 12:48:21 »
It looks like they have black too:
http://down.playwares.com/xe/files/attach/images/53/130/072/f4673ac41b533172d5fa0af117671d23.jpg
Although, graphite with black keys... Mmmm yum
Offline Jocelyn
  • 조셀린
« Reply #10 on: Fri, 22 February 2013, 12:50:39 »
Yes. I'd love to buy a set of the blank grey shown in that photo, but I can't find them anywhere.
Offline OnTheBrink
    • Wired In Store
« Reply #11 on: Fri, 22 February 2013, 12:59:41 »
So is anyone willing to proxy for me!?
« Reply #12 on: Fri, 22 February 2013, 14:47:29 »
Shipping is gonna be hella pricey, just FYI. I did a check on shipping for just caps. ~$20 AUD for packages under 2kg.
Offline OnTheBrink
    • Wired In Store
« Reply #13 on: Fri, 22 February 2013, 15:13:02 »
Maybe a better option would be to try and find someone willing to buy the Korean key caps from me when I get it since GMarket has them available but only with English/Korean key caps.
« Reply #14 on: Fri, 22 February 2013, 15:23:42 »
Just buy it now and swap it with PBT caps later?
