Author Topic: Things I've read on Chinese keyboard forums...  (Read 8250 times)
Offline dante
« on: Fri, 01 March 2013, 07:59:33 »
So after spending a couple weeks on Chinese forums here is what I've learned:
- Based on posts I've read I'd say the most popular keyboards are in this order 1) Keycool, 2) Ducky, 3) Filco (!?)
- When a keyboard is listed as coming out at least a few people pray that a large "L" enter key will be available (!?!?)
- If pictures are posted of traditional/retro White/Gray combinations it's almost never referred to as Model-M'esque but Wyse.
- In a random sampling 2 out of 3 users prefer MX Black switches.
Very interesting on the Keycool though - I had no idea they had some sort of following.
Offline laffindude
Re: Things I've read on Chinese keyboard forums...
« Reply #1 on: Fri, 01 March 2013, 08:06:39 »
Keycool is the first "domestic" brand that has acceptable quality, hence its popularity. The Chinese layout traditionally include the bigass enter.
Offline YongJK
« Reply #2 on: Fri, 01 March 2013, 10:13:06 »
It is really not bad though.
For such cheap price tag you can hands on a mechanical keyboard along with some accessories included.
I got this at roughly MYR 225.00 shipped to Malaysia, Grey PBT version.
Disregard that Dota 2 caps and lousy printing PBT RGYB ( RMB 58.00 per set )
some image here
Note that inconsistent QC for arrow key.
http://imgur.com/RWqXLC8,OIAQnfz,OELnTm8,9v6lB1f
« Last Edit: Fri, 01 March 2013, 10:16:32 by YongJK »
Keyboard: PLU ML87 Mx Blue
Offline FoxWolf1
  • 154
« Reply #3 on: Fri, 01 March 2013, 10:31:50 »
I have to say, I do somewhat sympathize with them about the large L enter...it's actually kind of satisfying to have a huge key to slam when you finish a bit of text, and once you get used to it, it's hard to use a narrow enter key without half your text lines accidentally ending in \. That said, it has to be implemented sensibly, i.e. with a normal-sized backspace; I don't mind \ being moved, since I don't use it often, but a small backspace definitely reduces both speed and comfort.
« Last Edit: Fri, 01 March 2013, 12:25:48 by FoxWolf1 »
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #4 on: Fri, 01 March 2013, 11:50:33 »
I have to say, I do somewhat sympathize with them about the large enter...it's actually kind of satisfying to have a huge key to slam when you finish a bit of text, and once you get used to it, it's hard to use a narrow enter key without half your text lines accidentally ending in \. That said, it has to be implemented sensibly, i.e. with a normal-sized backspace; I don't mind \ being moved, since I don't use it often, but a small backspace definitely reduces both speed and comfort.
I always liked the smaller enter key because of how much more proportioned it makes the keyboard look.
Also why I like 3 key space bar then three key window setup as well (not sure what that's called)
« Reply #5 on: Fri, 01 March 2013, 12:09:33 »
I'm Totally cool with the Large enter like the ISO, but not the big L enter.. that takes away too many of my precious keys...
Offline harrison
« Reply #6 on: Fri, 01 March 2013, 12:57:44 »
somehow, i feel vindicated knowing that ducky is gathering a larger following than filco
underdogs ftw!
[work]ducky tiger dk-9008G2, cherry mx brown|logitech performance mx
[home]corsair k70 LUX RGB, cherry mx brown|logitech G700s
Offline OnTheBrink
    • Wired In Store
« Reply #7 on: Fri, 01 March 2013, 13:03:37 »
underdogs ftw!
Lol, but who are you considering the underdogs? Ducky isn't so under anymore :p
Offline daerid
    • Rossipedia
« Reply #8 on: Fri, 01 March 2013, 13:50:30 »
On the Ducky vs Filco thing, I'm pretty sure that just has to do with backlighting and community involvement. Personally I'd still take a Filco over a Ducky any day of the week.
Now, if Ducky started using Costar stabs that might change...
Offline calavera
« Reply #9 on: Fri, 01 March 2013, 14:17:24 »
You get what you pay for.
Offline harrison
« Reply #10 on: Fri, 01 March 2013, 14:23:00 »
underdogs ftw!
too true
Offline mechanisch
« Reply #11 on: Fri, 01 March 2013, 14:32:55 »
To Ducky's credit, they've come a long way.  Could still see some improvements though.
Offline gigibecali
« Reply #12 on: Fri, 01 March 2013, 15:57:13 »
how thick are these KC pbt keycaps? Can someone post a picture? Or a link?
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
« Reply #13 on: Fri, 01 March 2013, 15:59:13 »
they're a "tad" thicker.. but not as thick as the crazy thick ones from imsto/feng
Offline gigibecali
« Reply #14 on: Fri, 01 March 2013, 16:05:42 »
Thanks tp4issue.
Are they what's called OEM profile? Or lower?
« Reply #15 on: Fri, 01 March 2013, 16:26:08 »
Only a matter of time before we see a Filco backlit board.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #16 on: Fri, 01 March 2013, 16:30:05 »
http://item.taobao.com/item.htm?spm=a230r.1.10.60.xiwOjx&id=22625184812
Well other than completely nonsensical legending ("ABCD"? "Neptune"?! Coffee in a hexagon? Camera? Huh?) I am seriously considering trying to get my hands on one of these when I'm able. Couldn't care less about the keycaps or the rest of it. It's new MX Whites (the 65/80).
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #17 on: Fri, 01 March 2013, 17:59:44 »
That's my deciding point too.  If Ducky go Costar Stabilizer then I'm sold.  It shouldn't be too hard for them to do considering both are made in Taiwan.
Offline Grim Fandango
« Reply #18 on: Sat, 02 March 2013, 05:03:25 »
Interesting. I have seen these keycool keyboards around an never really knew what to  make of them. The idea that a large community of enthusiasts seems to like them is somehow really reassuring.
Also, large "L"? Does anyone know what that is about?
Offline laffindude
« Reply #19 on: Sat, 02 March 2013, 05:12:50 »
bigass enter, aka reverse L enter.
Offline RickyJ
« Reply #20 on: Sat, 02 March 2013, 14:27:50 »
I think I read recently about Ducky having pissed off Costar in the past, so they won't be able to get their stabs or use them as an OEM again?
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline Hyde
« Reply #21 on: Sat, 02 March 2013, 17:07:49 »
ISO Layout big enter lol.
Really?  Nooooooooooooooo it's literally the only thing stopping me from buying Ducky.
Looks like I have to wait for CM Storm's QuickFire XT backlit version (it's been announced by the new CM rep on this forum forgot his name, if I remember correctly the model is QuickFire XTL).
Offline davkol
  •  Post Editing Timeout
« Reply #22 on: Sat, 02 March 2013, 17:35:35 »
What? It has nothing to do with ISO. ISO Enter is like mirrored P, mirrored L is big-ass Asian Enter.
« Reply #23 on: Sat, 02 March 2013, 17:43:09 »
Ahhh, so that is what they mean. Living in Holland, I sometimes have to go through a lot of trouble avoiding these weird shaped enter keys. There are like three different common layouts over here. I try to stick with a general ANSI layout.
Offline feng
« Reply #24 on: Sun, 03 March 2013, 03:59:05 »
Keycool's price rance is basically between $48 to $80, while Filco's price range is $112 - $177.
I don't know why they like big "L" enter, but most of them would prefer regular enter key.
The reason that MX black is so common is because it is called "gaming switches" due to its reaction velocity, and most people are using their mechanical keyboards for gaming purpose, instead of typing.
