Author Topic: Looking for an all white keyboard.  (Read 3430 times)
Offline Chase5delta
  • Keyboardoholic
« on: Sat, 16 March 2013, 04:26:40 »
Anybody know a place where I can get a keyboard that is completely white, blank keycaps, and comes in reds/browns? Thanks
Edit: Tenkeyless, sorry for not putting this :P
« Last Edit: Sat, 16 March 2013, 04:45:58 by Chase5delta »
Filco MJ2 TKL (Mx Blues) Keycool 84 (Mx Reds)
Offline affect656
Re: Looking for an all white keyboard.
« Reply #1 on: Sat, 16 March 2013, 04:37:44 »
What size
I like linear.
Offline Chase5delta
  • Keyboardoholic
« Reply #2 on: Sat, 16 March 2013, 04:46:12 »
Tenkeyless sorry
Offline Q404
« Reply #3 on: Sat, 16 March 2013, 04:55:25 »
Maybe a ducky like thishttp://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=184 or you can buy a QFR and buy white keycaps seperatly .
« Last Edit: Sat, 16 March 2013, 04:58:16 by Q404 »
Offline Chase5delta
  • Keyboardoholic
« Reply #4 on: Sat, 16 March 2013, 04:59:56 »
I want the entire keyboard to be white including the frame so that ducky is out.
Offline Q404
« Reply #5 on: Sat, 16 March 2013, 05:10:48 »
I think you can manually color the case.
If you dont want to do that i have no more suggestion for you.
The cheapest and imo best solution is to buy a QFR ,color the case and buyu white blank PBT keycaps ,as i said above.
Offline morpheus
« Reply #6 on: Sat, 16 March 2013, 05:22:52 »
I would go for an HPE 87.
Offline Chase5delta
  • Keyboardoholic
« Reply #7 on: Sat, 16 March 2013, 05:24:33 »
Is there really no tenkeyless keyboard with a white base, I've looked around a bit but no luck so far
Offline Jocelyn
  • 조셀린
« Reply #8 on: Sat, 16 March 2013, 05:30:32 »
PLU-87, HPE 87, or Keycool 87
The others can also be found on qtan's site, but you'll have to replace the caps if you want blanks.
Keycool 87 - http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-br/key-cool-87-mechanical-gaming-/lid=26561692
« Last Edit: Sat, 16 March 2013, 05:35:07 by Jocelyn »
« Reply #9 on: Sat, 16 March 2013, 06:00:44 »
There's the Filco white - http://www.amazon.com/Filco-Majestouch-2-Tenkeyless-Keyboard-FKBN87ML/dp/B005JC4QLS
but it only comes in black switch. There's also the Filco white ninja, which does come in red mx but good luck finding one.
Offline Saturn
« Reply #10 on: Sat, 16 March 2013, 06:24:16 »
The filco white with red switches is available on keyboard co.  It's not exactly a pure white though.
I think Leopold has a white FC700R.
Offline Reomero
  • Manual breather
« Reply #11 on: Sat, 16 March 2013, 07:11:55 »
Yeah there is a white Leopold FC700R. The problem is availability unless you're in Asia (a friend got mine for me when he went to HK) or Australia.
Offline badcop
  • thorpe thocking master race
« Reply #12 on: Sat, 16 March 2013, 07:44:29 »
That white filco is pretty badass
Offline t2russo
« Reply #13 on: Sat, 16 March 2013, 18:29:44 »
You can either try to get the HPE-87 or you have to wait for Filco white/beige Ninja TKL to come into stock.  Personally, I almost bought an HPE to convert into a Phantom, but ended up with a second Filco.  It's definitely a beige, it is not as pure white as the PBT keycaps I have on it, but is generally quite striking.
« Reply #14 on: Sat, 16 March 2013, 19:06:02 »
THE ONLY white one from the list posted so far is the LEOPOLD, but alas it's PAINTED, not white plastic....
The other choices are actually all "CHALK"// "Beige" //"mustard-white"
Offline gigibecali
« Reply #15 on: Sun, 17 March 2013, 04:48:02 »
hpe is white. White for real. No paint. Paint is stupid. Don't almost everyone love their doubleshots? :)
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
Offline Reomero
  • Manual breather
« Reply #16 on: Sun, 17 March 2013, 05:10:19 »
The only thing I find off-putting with the HPE is that massive logo thing above the arrow keys. :-X
Offline lazerpointer
  • ya gotta stay phresh
« Reply #17 on: Sun, 17 March 2013, 07:15:32 »
But its all metal and shiny and stuff.
I would suggest a Matias keyboard and harvest some white caps from another alps board
i type, therefore i geekhack
« Reply #18 on: Sun, 17 March 2013, 10:58:16 »
HPE is "not white" it's Beige-ish..
most of the photos are tweaked, and used flash to get "whiter--"
« Reply #19 on: Sun, 17 March 2013, 11:03:39 »
Pff. No, it's white. Except the cable and the rubber feet on the bottom which are more beige or yellowed.
Edit;
and the lazer etched legends (the OEM key caps that come with it are terribad)
15956-0
« Last Edit: Sun, 17 March 2013, 11:20:06 by Flip »
« Reply #20 on: Sun, 17 March 2013, 11:09:57 »
Edit;
There are lots of different shades of white.. But if anyone is looking for the Generally agreed upon "white", they will be disappointed with the HPE..
Offline MJ45
  • HHKB Pro
« Reply #21 on: Sun, 17 March 2013, 11:33:21 »
On the Ducky with the white caps you could paint the case.
Offline gigibecali
« Reply #22 on: Sun, 17 March 2013, 12:53:59 »
Edit;
mine is white. really white.
« Reply #23 on: Sun, 17 March 2013, 13:38:41 »
Mashby has a pretty good list over here that might help you
Offline Lastpilot
  • Power stance
« Reply #24 on: Sun, 17 March 2013, 14:22:30 »
Also, please know that the white Leopolds have a bit of an egg-shell white case while the keycaps are more of a pure white. I read this about the FC200R model, so I'm not sure if they changed this with the 700.
