Author Topic: Cherry Brown/Red Keyboard for $70  (Read 3146 times)
Offline DoubleB
« on: Thu, 21 March 2013, 13:10:19 »
So I'm looking to buy my first mechanical keyboard and after doing my research I think I've decided I would like either Red or Brown switches. My budget is fairly tight so I would like to spend $70 or less. Does anyone know of any keyboards that are in this price price range? I'm fine with either full size or ten-keyless.
Offline calavera
Re: Cherry Brown/Red Keyboard for $70
« Reply #1 on: Thu, 21 March 2013, 13:34:17 »
Quick Fire Rapid
Offline khaangaaroo
« Reply #2 on: Thu, 21 March 2013, 14:03:56 »
Offline DoubleB
« Reply #3 on: Thu, 21 March 2013, 14:42:03 »
Quick Fire Rapid
I was thinking this as well but everywhere I see them they are $80-$90.
Offline khaangaaroo
« Reply #4 on: Thu, 21 March 2013, 16:16:26 »
Not mine! ;)
Offline Chase5delta
  • Keyboardoholic
« Reply #5 on: Fri, 22 March 2013, 21:54:27 »
QuickFire Rapid is a great first MechKeyboard, same build quality as some more expensive stuff, with a great price :D
Filco MJ2 TKL (Mx Blues) Keycool 84 (Mx Reds)
Offline morpheus
« Reply #6 on: Fri, 22 March 2013, 23:33:56 »
I got my first QFR Blue on Amazon for $64. I haven't seen anything cheaper in its quality range.
« Reply #7 on: Fri, 22 March 2013, 23:47:47 »
Keep your eyes open, they routinely go for $65 new.  I think I actually picked mine up for less than that.
Offline khaangaaroo
« Reply #8 on: Sat, 23 March 2013, 01:45:42 »
Blues go for $65 new, but browns and reds don't. At least not routinely. Just check Amazon price history.
EDIT: But if you were talking about something other than a QFR, like a Rosewill, then that's a different story.
« Last Edit: Sat, 23 March 2013, 01:48:55 by khaangaaroo »
« Reply #9 on: Sat, 23 March 2013, 02:10:34 »
I got my Blacks for less than $65.  Browns seem to stay high and I've seen Reds go down quite a few times, but Blues and Blacks are the most common on sale.
I got my Rosewill with Reds for $35.
« Reply #10 on: Sat, 23 March 2013, 02:28:18 »
for that price, you have no choices. other than the qfr,
or the QF-pro which suxxx
Offline morpheus
« Reply #11 on: Sat, 23 March 2013, 03:37:22 »
Where did you get Rosewill Reds for so cheap?
« Reply #12 on: Sat, 23 March 2013, 04:39:41 »
Bought it used.
Offline morpheus
« Reply #13 on: Sat, 23 March 2013, 04:50:09 »
Bought it used.
On Amazon? or on GH Classifieds? or Somewhere else?
« Reply #14 on: Sat, 23 March 2013, 12:52:22 »
Off of Reddit.  Now it's in the middle of a switch swap and paint job.
Offline iri
« Reply #15 on: Sat, 23 March 2013, 14:19:32 »
+1, don't even think about buying this board
-Ray Bradbury
