Author Topic: Ugliest board on the planet Azio Levetron Mech5 - $69.99  (Read 6743 times)
« on: Mon, 01 April 2013, 04:10:55 »
Offline esoomenona
  • Gnillort?
Re: Ugliest board on the planet Azio Levetron Mech5 - $69.99
« Reply #1 on: Mon, 01 April 2013, 04:32:59 »
Can you use the ten keypad separately? Or how does it connect to the board?
« Reply #2 on: Mon, 01 April 2013, 04:53:32 »
wow.. the design is really good..
If I was a little bit younger... I'd totally use this..
It's fully modular.. you can use ANY of the components separately...
Not sure if it's got a plate though...
Offline Tym
« Reply #3 on: Mon, 01 April 2013, 05:29:09 »
I've seen a guy here use that.
Offline Grim Fandango
« Reply #4 on: Mon, 01 April 2013, 05:44:46 »
I agree that it is ugly as sin. However, most gaming gear share this same sort of look. This one went over the top . Would not be surprised if there are people that get it for its looks. To each his own and all that.
« Reply #5 on: Mon, 01 April 2013, 06:04:03 »
Gotta give him props for unicorn vomiting it up though. Man that thing was a well done eyesore.
« Reply #6 on: Mon, 01 April 2013, 06:23:13 »
Am I correct that the tenkey can be moved to the left side?  That is an awesome feature.  I also like the extra column on the left.  Too bad the rest of it is so awful.  Wtf is that extra sixpack over the Fn row?
Offline esoomenona
  • Gnillort?
« Reply #7 on: Mon, 01 April 2013, 06:50:12 »
Yes. And that is apparently a customizable(?) WASD cluster for easier access to moving around while gaming. It attaches to an accessory rail, which may apparently get more accessories in the future.
Offline inteli722
« Reply #8 on: Mon, 01 April 2013, 08:19:14 »
IIRC you can if you have a cable with a USB-A Female end.
Waiting for: Phantom Plate
« Reply #9 on: Mon, 01 April 2013, 08:21:56 »
It would be cool if they had a trackball to go with it.  I'd buy that.
Offline esoomenona
  • Gnillort?
« Reply #10 on: Mon, 01 April 2013, 08:22:24 »
So a USB extension cable should work?
« Reply #11 on: Mon, 01 April 2013, 08:25:21 »
One way to find out! :))
Offline Neal
  • Skype: iNewbcake
« Reply #12 on: Mon, 01 April 2013, 08:52:44 »
My eyes! D:
Offline FoxWolf1
  • 154
« Reply #13 on: Mon, 01 April 2013, 09:50:50 »
This keyboard is really ugly, but I have to give them credit for their willingness to experiment with non-conventional features like the movable number pad, accessory rail, etc. Perhaps most interesting is what they've done to increase protection against spills...the plate actually comes up and covers the sides and part of the tops of the switches, making it harder for liquid to get to the electronics.
I actually wish that more companies were this willing to try out new ideas-- but in the form of less embarrassing-looking products, preferably with better quality, and not so large that even a decided non-minimalist such as myself would have to consider it enormous to a fault.
« Last Edit: Mon, 01 April 2013, 09:54:27 by FoxWolf1 »
« Reply #14 on: Mon, 01 April 2013, 10:21:05 »
If a little bit is good, then a whole lot more is a whole lot better.
- Oliver Willis 2026-08-01
Offline inteli722
« Reply #15 on: Mon, 01 April 2013, 11:59:32 »
It should. I know for sure that it's a standard sized USB connection, so it's more a matter of whether it's an extension cable or 2 male ends. I do think that it's the former. I'll see if I can find the NCIX Video showing it off when I get home.
EDIT: HERE IT IS
It does utilize a standard USB A male to USB A Female, so an extension cable will work just fine.
« Last Edit: Mon, 01 April 2013, 15:20:41 by inteli722 »
Offline kaotikb
« Reply #16 on: Mon, 01 April 2013, 15:00:59 »
I was actually looking at this board a while back because it was on sale pretty cheap. I liked the movable number pad and the spill protection. Mainly because i killed my old keyboard by spilling coffee on it. I bought a thermaltake meka keyboard but i didnt like it either.
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
« Reply #17 on: Mon, 01 April 2013, 15:12:11 »
I admit that it looks disgusting but at least the price isn't too bad. This, on the other hand, is overpriced as hell, just as ugly, and doesn't even use mechanical switches : http://www.amazon.com/Mad-Catz-S-T-R-I-K-E-7-Gaming-Keyboard/dp/B0090ECASW
Offline inteli722
« Reply #18 on: Mon, 01 April 2013, 15:13:54 »
You'd think that for the price it would have Mechanical switches!
« Reply #19 on: Mon, 01 April 2013, 15:29:53 »
I just threw up inside my mouth a little.
Offline MarkPharaoh
« Reply #20 on: Mon, 01 April 2013, 16:40:00 »
I would of bought this thing in a heartbeat if I as still in high school. I love the move able keypad, my old Sidewinder had that feature.
Current: HHKB Pro 2, 87u 55g 10AE, FC600C, Model M 1391401
Offline Leslieann
« Reply #21 on: Mon, 01 April 2013, 22:01:11 »
I have to agree, the idea is good, and even the execution isn't bad (if overkill in some aspects), it's just an aesthetics issue for the most part that really hurts it in my opinion.  Eliminate the geometric gamer/armored look and it could be a good keyboard for a lot of people, even in the office. Macros aren't just for gamers.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline SmallFry
Re: Re: Ugliest board on the planet Azio Levetron Mech5 - $69.99
« Reply #22 on: Mon, 01 April 2013, 23:09:39 »
I thought it actually looked decent once it had the multicolored caps. Crazy colors for a crazy board, I think I'd how i3oilermaker put it, and I agree.
Offline morpheus
« Reply #23 on: Tue, 02 April 2013, 10:56:01 »
The numpad is sort of compelling.
