Author Topic: Beige filco yellowing.  (Read 4163 times)
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« on: Wed, 24 April 2013, 13:56:24 »
I'm wondering if it's an issue. I love the looks of beige Filco and I'm thinking about buying one to try out MX Red, but i'm kind of worried about yellowing...
Re: Beige filco yellowing.
« Reply #1 on: Wed, 24 April 2013, 14:08:53 »
If you limit sun exposure, it'll be fine.. especially considering you don't want alotta sun around your monitor to begin with.
Besides... a filco ages with grace due to it's luxury branding nature :D
A beater Quickfire rapid for example, just turns into garbage or something you're embarrassed to lug around or have the neighbors see.
Offline czarek
    • FalbaTech
« Reply #2 on: Wed, 24 April 2013, 14:12:51 »
Check out my black Filco after about year use:
The shine is not skin oil, it's actual plastic wear due to extensive use. My keyboards work and earn money, don't just look cool on a desk ;)
« Last Edit: Wed, 24 April 2013, 14:14:36 by czarek »
Offline SmallFry
« Reply #3 on: Wed, 24 April 2013, 14:14:27 »
Looks well loved. Like TP4Tissue stated, stay away from sunlight with white plastic to truly avoid ABS yellowing. The sun promotes the ABS yellowing. Also, if you smoke, stay away from it while smoking, as it also promotes yellowing.
Offline Grim Fandango
« Reply #4 on: Wed, 24 April 2013, 14:18:50 »
I am the same. Though for me it is just the keycaps that wear out, the case always looks decent. Your case seems to have a lot of wear however. For example the area above the arrow keys, I hardly ever touch it. Everyone has different habits I guess (I can also tell for example, that you hit the spacebar in a completely different location than I do).
I am also interested in what would happen with a white filco in sunlight. When I bought my most recent filco this was also something I worried about, knowing that it would sit next to a window and catch a lot of sunlight every single day. The caps would no doubt yellow since they are just ABS, but I am not sure if the case is made of a material that would not yellow.
« Last Edit: Wed, 24 April 2013, 14:20:21 by Grim Fandango »
Offline SmallFry
« Reply #5 on: Wed, 24 April 2013, 14:24:40 »
If I'm going through a paper, (or code, in some environments) I touch the area above the arrow keys for Page Down/Up and Delete for editing stuff quickly. I also use the arrow keys, so my boards show some of the same shine.
Offline czarek
    • FalbaTech
« Reply #6 on: Wed, 24 April 2013, 14:34:09 »
My desk is located next to window so no doubt keyboards get fair amount of sunlight every day. Although I must say I used HHKB with white keys (where spacebar is ABS) for over a year and there is no yellowing visible on keys. Obviously there is absolutely no color change in IBM and Unicomp keyboards which I use mostly.
I may get this white Filco just to see how it goes on. Is it hard to get the aluminium case for it in case i wear the plastic out like the last one? I already have few G81-3000 keyboards with thick lasered PBT caps so could reuse them on Filco I guess...
Offline SmallFry
Re: Re: Beige filco yellowing.
« Reply #7 on: Wed, 24 April 2013, 20:19:40 »
There is a ready, though somewhat unsatisfactory, aftermarket aluminum case available for $150 from MechanicalKeyboards.com
« Reply #8 on: Wed, 24 April 2013, 20:22:41 »
well there's certainly "some" skin oil in there, and 'some" you know wa.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #9 on: Wed, 24 April 2013, 23:05:29 »
I've had my beige filco for about 8 months now, it still look about the same.  Filco made it beige instead of pure white for a reason.
Because when pure white turns yellow, you'll definitely know it turns yellow, but when beige turns yellow, it will look roughly about the same.  Many people hate on the fact that it's not pure white but it's actually a smart design decision  :)
Offline PointyFox
« Reply #10 on: Wed, 24 April 2013, 23:06:58 »
Don't type with gloves made from sandpaper.  Also, how did you manage to use every key that much, and even wear out spaces between keys?
« Last Edit: Wed, 24 April 2013, 23:08:52 by PointyFox »
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #11 on: Thu, 25 April 2013, 01:40:26 »
Because contrary to what people keep insisting, ABS is nowhere near that durable and in fact, wears out and through very very easily. It is not abuse, and it is not people wearing "gloves of sandpaper," and it is not "grinding the keys."
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline czarek
    • FalbaTech
« Reply #12 on: Thu, 25 April 2013, 06:39:42 »
Just bare hands man. I used all of them because I write in English and Polish, also I write perl at least 8 hours a day using Vim so pretty much use all the keys, maybe not F1-F15 ;) In meantime i rest my hand on the space above the arrows.
Offline PointyFox
« Reply #13 on: Thu, 25 April 2013, 17:47:01 »
You dissolved that thing.  I had a generic Dell keyboard I used for like 12 years, playing video games on ~6 hours a day.  The keys were pad printed and after 12 years, only a small part of the A was partially rubbed away.
Offline rootwyrm
    • My Website!
« Reply #14 on: Thu, 25 April 2013, 17:55:47 »
And this is a Thermaltake Meka G1 after just a few months. ABS is low quality junk, the end. Or what, you're going to claim keys don't shine ever?
Quit trying to blame owners for shoddy quality components.
Offline PointyFox
« Reply #15 on: Thu, 25 April 2013, 22:29:21 »
Clearly Dell keyboards > Filco
