Author Topic: Should I send my FC660C back?  (Read 10797 times)
Offline Sniping
« on: Thu, 16 May 2013, 16:45:34 »
I have this issue with my Leopold FC660C that just arrived yesterday. There's some pretty audible noise that's made when I apply some pressure to the case. There's another video on YouTube about another FC660C making this weird noise. Do you guys think this is worth sending back?
Video of the issue with my keyboard here:
The other video of this happening (not my keyboard):
Offline Jocelyn
  • 조셀린
Re: Should I send my FC660C back?
« Reply #1 on: Thu, 16 May 2013, 16:48:49 »
I was going to tell you to sell it to me lol, but I don't know what to think after seeing both videos. I'm interested in seeing what others have to say about this.
Offline kelske
  • The North Borders
« Reply #2 on: Thu, 16 May 2013, 16:54:14 »
Does it make any creaking noises while just using it normally? Or is it only apparent when you squeeze it front to back like that?
Offline Sniping
« Reply #3 on: Thu, 16 May 2013, 16:56:49 »
Only when I try to make that sound, I never hear it when I'm just typing. I didn't even know that my FC660C did that until I remembered the video and tried to see if mine did that too, which it did unfortunately =/
« Reply #4 on: Thu, 16 May 2013, 16:56:59 »
Ah... that's an extra feature.. :D
not a manufacturing mistake..
i'm surprised this issue wasn't fleshed out before all you guys bought one? was it released everywhere at once? or did it come out in corea already before the EK orders.
« Reply #5 on: Thu, 16 May 2013, 17:00:05 »
Interesting. I tried that on mine after I saw the video, nothing.
Must be only on some.
If it bothers you, get a replacement. But seeing as its fine for typing, I don't think it's a big deal.
Offline Shuki
« Reply #6 on: Thu, 16 May 2013, 17:02:24 »
Don't squeeze your keyboard imo.
Offline kelske
  • The North Borders
« Reply #7 on: Thu, 16 May 2013, 17:13:02 »
I'm not sure I'd be too worried.. Yea it's an expensive board and it shouldn't have such issues - but just the headache of trying to get it RMA'd is a bit much D:
« Reply #8 on: Thu, 16 May 2013, 17:40:56 »
did you squeeze hard enough?
Offline zoolzoo
« Reply #9 on: Thu, 16 May 2013, 17:41:30 »
Mine doesnt do that but, I wouldnt worry about it at all.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
« Reply #10 on: Thu, 16 May 2013, 17:42:53 »
maybe the case isn't tightened down enough.
Push down on it.
Offline Grim Fandango
« Reply #11 on: Thu, 16 May 2013, 17:45:01 »
In the video it looks like you need to squeeze/push it with quite a lot of force, and the force needs to be applied in a way that would never happen when using the board normally. I would personally not worry about it at all, if the case looks good otherwise (not bent out of shape or anything). It seems that there would be no practical issues you would run into if you keep it.
Offline fatmav
« Reply #12 on: Thu, 16 May 2013, 17:52:58 »
Seems like there was some mistake in the assembling. Most likely the top cover was not sit properly on the housing before screwing.
If that is the case, then you will have a lot less trouble if you fix it yourself by unscrewing, re-sit, and re-screw.
Offline kelske
  • The North Borders
« Reply #13 on: Thu, 16 May 2013, 18:03:54 »
This probably void's the warranty though doesn't it??
Offline fatmav
« Reply #14 on: Thu, 16 May 2013, 18:12:20 »
Most likely yes. :P
« Reply #15 on: Thu, 16 May 2013, 18:13:22 »
Not sure about Leopold since I do not own one, but for most brands it will. Since it is something that bothers the OP and you are not 100% certain this will work, I would not void warranty like this. You also have to take into account that this is a new keyboard and you want to make sure no other issues come up before you go and void warranty for whatever reason . I found that in consumer electronics, either issues show up in the first weeks of use or not at all.
« Last Edit: Thu, 16 May 2013, 18:15:38 by Grim Fandango »
Offline Sniping
« Reply #16 on: Thu, 16 May 2013, 18:16:26 »
I agree that I shouldn't be too worried because I can't apply the same force while just typing, but I can make that sound in the video by just picking up the keyboard from that position, not much force at all.
I think I'm probably just going to keep it, but I might use this as an excuse later on to get a replacement with blanks/white.
Offline Jocelyn
  • 조셀린
« Reply #17 on: Thu, 16 May 2013, 18:25:40 »
This is exactly what I'd do :)
« Reply #18 on: Thu, 16 May 2013, 18:32:02 »
My experience has been that you will find an excuse not matter what  ;)
If you are the type who is really bothered by these type of things and can not let it go, then you may just be better off returning/exchanging it.
Offline WhiteFireDragon
    • youtube
« Reply #19 on: Thu, 16 May 2013, 18:54:49 »
If you routinely squeeze your keyboards like that before you start typing, then yeah that warrants an exchange. Otherwise, just keep it. Also this may not matter to you much, but if you exchange it, EK (assuming that's where you got it?) won't be able to sell it off as new anymore, so they might take a loss on it.
Mine doesn't do that, but if it did, I would keep it but would fix it myself. It looks like the notches from both outer and inner surfaces are not flush. If you're ok with "fixing" it yourself, take off the cover to heat it with a hair dryer, while applying pressure inwards. Pretty much similar procedure to straightening a bent PBT spacebar.
Offline jabar
« Reply #20 on: Thu, 16 May 2013, 19:41:00 »
There's been a number of posting here of Realforce keyboards whose cases don't quite exactly fit. This seems to be an extreme case where flexing the case produces noise. Either way, for keyboards in the $200 range it wouldn't be acceptable for me. Yes, EK would be hurt from lots of RMA returns but if the product isn't up to snuff they shouldn't be stocking it.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Inept
« Reply #21 on: Thu, 16 May 2013, 19:41:22 »
I got 2 and don't have this issue.
Offline elitekeyboards
  • * Commercial Vendor
    • http://elitekeyboards.com
« Reply #22 on: Thu, 16 May 2013, 19:44:39 »
Hi Sniping; et al.,
I've discovered this same issue on a couple of units and I've notified Leopold. I'm just waiting to hear back from them as to how they'd like to proceed.
Also, I've investigated the problem a bit and I've found a very simple, non-destructive fix, but it requires opening the case. So, I'm requesting and recommending that anyone who has this issue to please resist the temptation to improvise a fix and give me a few days to hear back from Leopold
In the meantime, if you purchased the keyboard from EK and would like to RMA it; now is the time. Eyebrows will be raised if you wait 6 months to inform us that it's a bother! Please contact support@elitekeyboards.com with your order number.
Brian
Offline jooks1184
« Reply #23 on: Thu, 16 May 2013, 22:32:16 »
Hey Brian,
   I'm planning on ordering a Leopold 660c within the next day. If I do, would it be possible to send one without that bezel problem?
Offline calavera
« Reply #24 on: Thu, 16 May 2013, 23:01:13 »
FYI Mine doesn't do that at all. It doesn't sound like a defect, more like improper assembly may be.
Offline PointyFox
« Reply #25 on: Thu, 16 May 2013, 23:11:31 »
You're typing wrong.
Also, you're just flexing it, causing the two shells to flex at different rates and slide on each other, which makes that sound.
Offline daerid
    • Rossipedia
« Reply #26 on: Fri, 17 May 2013, 00:51:08 »
If I apply pressure in the same place as shown on those two videos, my FC660C's case flexes noticeably (and lets out a little squeak, actually), but there's no popping like in the vids.
Most people's RF cases slide around a little bit (one of mine used to), so as far as I'm concerned there's nothing wrong with my 660C, but I'd definitely suggest those with this issue RMA the board. What is shown in the video definitely sounds wrong.
Oh, and
I'd qualify improper assembly as defective.
Offline therecorder
« Reply #27 on: Fri, 17 May 2013, 02:52:15 »
Just checked my FC660C from Elite, and my FC660M from Qtang.  Both are absolutely fine...  Solid...  Not possible for me to flex in demonstrated way...  Fit is tight.  If yours is defective, and especially if you tend to be OCD, I'd follow Brian's instructions...  Otherwise, you'll never be satisfied.
Offline baller1308
« Reply #28 on: Fri, 17 May 2013, 10:56:29 »
If it's not normal and you are not happy I would return it or exchange it.  I don't know how much you'll have to pay for shipping but for a board at that price and not being completely satisfied, makes sense to return/exchange it.
Noppoo Choc Mini [Browns]
HPE 87 [Browns]
Offline AJCarrington
« Reply #29 on: Fri, 17 May 2013, 14:37:49 »
Too bad...my FC660 from EK seems to be working perfectly. Comments from others are pretty sound...if you're happy now, get it exchanged.
Offline Hypersphere
« Reply #30 on: Thu, 18 July 2013, 21:41:45 »
My FC660M (Cherry blue version) is as solid as a stainless steel brick. If your FC660C (Topre version) seems not to be assembled correctly, I recommend returning it. Ultimately, you will be happier with a properly assembled keyboard, and the company will realize that they need to tighten up their assembly procedures and their quality control.
Offline velvetdon25
« Reply #31 on: Thu, 18 July 2013, 23:46:13 »
The top of the FC660C seems to be protruding?
Offline Hypersphere
« Reply #32 on: Sun, 01 September 2013, 19:11:05 »
Just got my Leopold FC660C with Topre switches. Overall, I like it very much, but I found the same issue that you did with the top of the case. If I squeeze the case in the middle, it flexes and makes a popping noise. This does not happen with my Leopold FC660M, the Cherry mx switch model of this keyboard.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #33 on: Sun, 01 September 2013, 19:34:14 »
Yeah my g/f's Leopold FC660C has the same issue.  I guess I'll wait a bit to see what Brian/Leopold says before opening it up.
Offline Sniping
« Reply #34 on: Sun, 01 September 2013, 20:21:41 »
When he emailed me he told me that Leopold will accept RMA's for this, but ultimately I've decided to just keep the board. It really doesn't bother me as much as it did when I first bought the FC660C months ago. I would be out of a Topre board for several weeks and I've just decided that it's not really worth it.
Offline Michael
  • Formerly Bro Caps
« Reply #35 on: Sun, 01 September 2013, 20:24:16 »
You can probably just do a little DIY and locate the squeak, and maybe add some foam in between the problem areas.
Offline Hypersphere
« Reply #36 on: Sun, 01 September 2013, 20:26:52 »
You should do this for a board that costs 189 USD?
Offline Michael
  • Formerly Bro Caps
« Reply #37 on: Sun, 01 September 2013, 20:28:55 »
mistakes happen in production, it might be a little warped possibly. It is ABS material.
Do you live in a perfect world where everything is perfect and nothing ever goes wrong? As the OP explained, he didn't want to be without a keyboard while they replace it. So I offered him a solution.
PS - if you think 189 is an expensive keyboard, you must be new here :)
Offline Hypersphere
« Reply #38 on: Sun, 01 September 2013, 22:23:39 »
Just sayin', as they say. ;)
No, I've spent far more than 189 USD on a keyboard. Nevertheless, money is money, and in this particular instance, given that, for example, the case on the FC660M does not flex at all, even though nothing is perfect, we should expect the more expensive FC660C to be at least as good.
Nevertheless, it was good of you to offer an alternative solution to the problem so that the customer would not be without a keyboard. It all depends on the relative values of expediency versus being temporarily inconvenienced to help the company correct a problem and perhaps help not just one, but many customers in the long run. :)
Offline s0ckpupp3t
« Reply #39 on: Thu, 19 September 2013, 11:15:41 »
Awww man, the FC660C I got yesterday flexes when I squeeze the top and the bottom too.  Initially it also made the clicking/popping sound when squeezed but it stopped clicking after a bit.  At this point I just hear the plastic case bumping against the metal plate when I squeeze it, which I suppose is an improvement but still disappointing.
I purchased this through EK's Amazon.com storefront.  Not sure if I should return it or just grit my teeth and bear it.  I would hate to go through the return and replacement process only to get a board that's worse.   :(
Offline Hypersphere
« Reply #40 on: Thu, 19 September 2013, 12:40:41 »
If you prefer a DIY fix rather than returning the board, you can contact EK customer support and they will send pics and material. The repair involves popping open the case and installing a piece of adhesive foam. I am still debating if I will do a return, try the fix, or just forget about it. I'm leaning toward just forgetting about it, because there is no problem during normal use. It's like the old joke about the guy who visits his physician and complains, "Doc, when I move my arm like this, it hurts." To which the doc replies, "Then don't move your arm like that and you'll feel fine."
Offline s0ckpupp3t
« Reply #41 on: Thu, 19 September 2013, 13:03:56 »
Human psychology being what it is, tell someone they can't do something and they'll only want to do it more.  Right now, I find myself squeezing the board like it was a pack Charmins tissues (yes, I'm that old).    ;)
Offline Hypersphere
« Reply #42 on: Thu, 19 September 2013, 14:10:05 »
Yes, it is like telling someone, "Don't think about elephants!" And of course, then they can think of nothing but elephants. So it is with my FC660C. Even if I can resist squeezing the case, I know that the defect is there, lurking beneath the surface like a disease unseen yet diagnosed, taunting me to do the surgery.
Offline insilica
  • Keyboard Geeza
« Reply #43 on: Thu, 19 September 2013, 16:34:15 »
Oh, and
My FC660C is exactly as described (flex but no pop).
Personally it doesn't bother me but if it bothers you I suggest you don't disassemble it as you will void your warrently. RMA it if it's not too much hassle.
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
« Reply #44 on: Thu, 19 September 2013, 17:22:18 »
I'm just wondering how often people squeeze their keyboard case (FC660x or otherwise).
I tend to put it on the desk and type on it.  The only time I might squeeze it is when I feel lonely swap keyboards around, which happens only once every few weeks.
Offline baotung
« Reply #45 on: Fri, 20 September 2013, 01:46:27 »
I've tried my friend's 660C and I must say that his doesn't have this issue :( I would definitely send it back for a new one... even if I never squeeze my keyboard, knowing it does it would bug the hell out of me.
« Reply #46 on: Fri, 20 September 2013, 01:51:01 »
But if you never squeeze your keyboard, how would you know if it creaks or not?
