Author Topic: Keyboards w/ Reactive Lighting?  (Read 10093 times)
Offline Smallville
« on: Mon, 03 June 2013, 11:44:15 »
I just found out about reactive lighting and I MUST HAVE IT. What keyboards have this? I checked Google and only came up with Duckys and the Corsair K70.
Re: Keyboards w/ Reactive Lighting?
« Reply #1 on: Mon, 03 June 2013, 11:48:24 »
My ducky shine II has this as a mode!
« Reply #2 on: Mon, 03 June 2013, 11:48:47 »
ah, right there on the video it says ducky shine 2, LOL ;D
« Reply #3 on: Mon, 03 June 2013, 11:49:27 »
And I obviously can't read :'(
Offline Dubsgalore
« Reply #4 on: Mon, 03 June 2013, 11:49:57 »
the next series of deck keyboards coming out will have reactive lighting
Offline fateswarm
« Reply #5 on: Mon, 03 June 2013, 11:51:35 »
As if it wasn't already bad form to look at the keyboard when typing, now also drawn to it by light!
It sounds cool for showing off though.
Offline jabar
« Reply #6 on: Mon, 03 June 2013, 11:54:47 »
You won't see the reactive lighting.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline elttaboi
« Reply #7 on: Mon, 03 June 2013, 12:04:16 »
unless you have light colored keycaps
Offline Photoelectric
« Reply #8 on: Mon, 03 June 2013, 12:52:09 »
I can see reactive lighting on my Ducky Shine II when I turn up brightness.  Can't really see it at minimum brightness, but it's very apparent at medium-to-high brightness levels.
« Reply #9 on: Mon, 03 June 2013, 12:53:51 »
WHICH never happens given the crowd on this forum
« Reply #10 on: Mon, 03 June 2013, 12:55:18 »
You don't need to look at the keyboard to see flashes of colored light popping up in your peripheral vision.  Unless your monitor is really high up, or your keyboard is right by your chest.  Just sayin' :)
« Reply #11 on: Mon, 03 June 2013, 17:05:59 »
I still think it would be cool (in a show off kinda way) if teh LED lights as you press the key, but stays lit for a second or so afterwards, instead of either flashing or just staying lit while the key is pressed down.
« Reply #12 on: Mon, 03 June 2013, 17:07:53 »
It's a cool novelty function.  I kept mine on that setting for the first couple days of owning my new Ducky and then swapped to non-flashing full-time (lowest setting) full backlight.  It seemed cool, but in practice it was distracting.
Offline 1391406
« Reply #13 on: Mon, 03 June 2013, 19:00:32 »
It seems like a cool idea on the face of it, but in practice it would only serve as a distraction, at least for me.
Offline calavera
« Reply #14 on: Wed, 05 June 2013, 01:53:30 »
 Not really a big fan of LED's but I must admit, it's fun. I have a custom that lights up the entire board when any keys are pressed. It's pretty cool as ****.
