Author Topic: ErgoDox round 3 GB is ON at Massdrop!  (Read 25358 times)
Offline SubGothius
    • HTDoctor.com
« on: Thu, 13 June 2013, 17:16:54 »
[crossposting here for those who don't check the geekhack marketplace > great finds subforum]
Massdrop is now rerunning the ErgoDox kit group buy for round 3! Same URL as round 1 this time:
https://www.massdrop.com/buy/ergodox/
Here's the original thread where ErgoDox was developed and build/customization discussions are ongoing:
http://geekhack.org/index.php?topic=22780
FWIW, here's mine that I just finished building from round 1:
25393-0
"In theory there's no difference between theory and practice, but in practice there is." -Jan L.A. van de Snepscheut
Offline linziyi
  • The one with many questions
Re: ErgoDox round 3 GB is ON at Massdrop!
« Reply #1 on: Thu, 13 June 2013, 17:25:15 »
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline dadgh
« Reply #2 on: Thu, 13 June 2013, 17:28:26 »
Cool, signed up. I hope the price goes down.
Offline daerid
    • Rossipedia
« Reply #3 on: Thu, 13 June 2013, 18:55:10 »
I might actually have to pick up a second one of these
Offline grips
« Reply #4 on: Thu, 13 June 2013, 18:59:25 »
Dammit. No money now.
Offline vun
  • Just one more thing
« Reply #5 on: Thu, 13 June 2013, 19:09:29 »
Would so want one of those, but I have neither the equipment or skills necessary to build one nor a convenient source of caps.
Might be a good place to start learning how to solder and stuff though.
Offline vivalarevolución
« Reply #6 on: Thu, 13 June 2013, 19:13:30 »
Gosh another one of these is tempting.
Offline Jagriff
« Reply #7 on: Thu, 13 June 2013, 19:15:43 »
I learned how to solder to prepare for building my round 2 ErgoDox. It's definitely worth it!
You can add on blank black PBT DSA keycaps for $37.
Offline daerid
    • Rossipedia
« Reply #8 on: Thu, 13 June 2013, 19:22:22 »
That's exactly what I did (got the blank DSA).
Hopefully they'll run the DCS caps too, pretty sure a DCS/DSA combination is the best way to go
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #9 on: Thu, 13 June 2013, 19:39:20 »
Gosh - wrong time again ...
Offline vun
« Reply #11 on: Thu, 13 June 2013, 20:39:58 »
Oh, so when you sign up you get the option to add caps?
I might just go for it, I sorta know how to solder already as I did a teensy bit at school several years ago, so it's not completely foreign to me.
Hmm... Decisions...
« Reply #12 on: Thu, 13 June 2013, 20:55:28 »
Hmm... Decisions...
you just can't help yourself..... :))
Offline SubGothius
    • HTDoctor.com
« Reply #13 on: Fri, 14 June 2013, 19:56:02 »
FWIW, I hadn't soldered anything to a PCB since I built a transistor radio kit in high school shop class 25 years ago, and I had no trouble building this kit. I did spring for a decent used temp-controlled soldering station off eBay, spent about the same for that ($~45) as what TheProfosist was charging for a full assembly service in the first round. Now for the same price, I've got the satisfaction of having built it myself, and a good soldering station I can use for further projects. I can recommend using the .022" 62/36/2 rosin-core solder from Radio Shack; it melts and flows real easy, and it's fine-gauge enough to apply in controlled amounts.
Offline linziyi
« Reply #14 on: Fri, 14 June 2013, 20:23:06 »
I think I know how to solder... just built a function generator at schol couple days ago, vut that’s light work
Ducky DK9008G2 Pro
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #15 on: Sat, 15 June 2013, 08:39:01 »
This may be answered somewhere, but there is many threads and such about these now...
It's possible to only use one half, specifically the left half by itself? I was thinking left side only would be a nice gaming pad.
« Reply #16 on: Sat, 15 June 2013, 09:14:27 »
I was also wondering this.
Offline Larken
« Reply #17 on: Sat, 15 June 2013, 10:16:18 »
possible, but I assume it's not easily done. there have been talk of this before, but no news of an operational model. see:
http://65.111.241.205/index.php?topic=42088.0
http://geekhack.org/index.php?topic=22780.msg844259#msg844259
| Ergodox #1 | Ergodox #2 |
Offline daerid
    • Rossipedia
« Reply #18 on: Sat, 15 June 2013, 10:32:24 »
Can the side with the teensy be used without the other side plugged in? If so, you could just flip the plates and wire everything up on the left side. You'd have to be careful though as the printing  on the PCB would be backwards.
« Reply #19 on: Sat, 15 June 2013, 10:35:46 »
I think the argument moot.
2 reasons.
Even IF it were possible, why would you want to do it.
The ergo dox is superior in every way to traditional staggered
Secondly, you have a tkl, and just half the dox,, then you now have all this unnecessary stuff on your desk space as opposed to just using the ergodox, WHICH CAN DO IT ALL.
Had there been any limitation to the ergodox's functionality , then perhaps you'd keep a second keyboard, but this is not the case..
« Reply #20 on: Sat, 15 June 2013, 13:59:22 »
2 reasons.
« Last Edit: Sat, 15 June 2013, 14:01:28 by nubbinator »
Offline daerid
    • Rossipedia
« Reply #21 on: Sat, 15 June 2013, 17:37:15 »
2 reasons.
Actually, it IS possible. Personally I think that the 'Dox should have been flipped anyways, because then you could use it as a normal every day board, and then unplug the right-hand side when it comes to game time, and have a dedicated gaming layout on the left side. It would actually give the 'Dox more flexibility/usefulness IMO.
Offline linziyi
« Reply #22 on: Sat, 15 June 2013, 22:02:59 »
Two small questions: are the keycaps "thick" PBT? And how do the different layers work? Can I switch and stay in a particular layer?
Ducky DK9008G2 Pro
« Reply #23 on: Sat, 15 June 2013, 22:05:50 »
No the dsa caps from sp that are $37 are not thick pbt, they are regular DSA profile regular thickness pbt.
There are 2 type of layer switching..
You can either Toggle layer, which means, hold down toggle layer button, and press the corresponding key to trigger.
OR, you can Push Layer, which means you press the layer button, it holds that layer until you POP layer which returns you to Normal, Or alternatively, You can setup links from any layer to any layer within any layer.
The layers are very powerful, and you can pretty much do whatever you like.
And if you know C, well, then, there's actually no limitations to what you can do, just limitations on how much time you have.
OMG, the teensy also supports overclocking.. i just found out.
Offline linziyi
« Reply #24 on: Sat, 15 June 2013, 22:12:30 »
Thanks a lot for the fast respond!
Ducky DK9008G2 Pro
Offline daerid
    • Rossipedia
« Reply #25 on: Sat, 15 June 2013, 22:32:28 »
What would you need to OC it for?
« Reply #26 on: Sat, 15 June 2013, 22:37:05 »
I got a bunch of extra vrm heatsinks from other stuff. :D
Offline linziyi
« Reply #27 on: Sat, 15 June 2013, 23:09:03 »
Kind’a feel bad because I keep asking questions... Are the switches plate mounted or PCB mounted? I think I’ll buy green switches from the DT groupbuy if the 199 price of ergodox is reached
Ducky DK9008G2 Pro
Offline Jagriff
« Reply #28 on: Sat, 15 June 2013, 23:11:14 »
The ErgoDox supports plate and pcb mounted switches afaik. You will probably want to mount on the acrylic plate, though, so get the plate mounted switches if possible.
« Last Edit: Sat, 15 June 2013, 23:12:52 by Jagriff »
Offline Larken
« Reply #29 on: Sat, 15 June 2013, 23:15:03 »
its non-exclusive. You can use pcb mounted switches along with the acrylic plate - best of both worlds when it comes to stability and alignment.
Offline linziyi
« Reply #30 on: Sat, 15 June 2013, 23:24:51 »
I notice that the PCB has LED holes on it, is it possible to make it a backlit keyboard?
Ducky DK9008G2 Pro
Offline daerid
    • Rossipedia
« Reply #31 on: Sat, 15 June 2013, 23:51:16 »
I'm fairly certain yes you can.
Offline Larken
« Reply #32 on: Sun, 16 June 2013, 00:09:14 »
except for the three inside modifiers on the right side of the board, there aren't holes for leds on the rest of the board.
unless you're willing to do your own hacking and wiring, you can't.
Offline daerid
    • Rossipedia
« Reply #33 on: Sun, 16 June 2013, 00:14:20 »
Dorpe. My bad. I was mistaking the non-SM diode holes for LED holes. Larken is correct.
Offline bbl
« Reply #34 on: Sun, 16 June 2013, 11:27:58 »
How do you toggle between and push to different layers on a ErgoDox using the standard layout?  I am considering joining round 3.
« Reply #35 on: Sun, 16 June 2013, 12:23:24 »
you can assign a button for toggle. or you can assign a button to push..
Once in Push, you can assign another button to pop, or another button to push to another layer higher, like a sequential shifter.
It's unlikely that you'd have more than 3-4 layers, but should that happen, then that is how you would do it.
For example, you pick any 1 button on the ergodox in layer 0 to push layer 1, now you press it, now in this layer 1, you can assign that button separately to do anything, including push layer 2.. now you press that, and assign the same button in layer 2 to push layer 3. and so on.
Now alternatively, if you know what layer you're going to be in, you can set it to directly go there.
Offline TD22057
« Reply #36 on: Sun, 16 June 2013, 12:52:35 »
Do they have the keycaps up for purchase?  All I see are inactive buys for the caps...
Offline Jagriff
« Reply #37 on: Sun, 16 June 2013, 12:54:20 »
When you go to order, you can add keycaps for $37.
Offline TD22057
« Reply #38 on: Sun, 16 June 2013, 13:09:02 »
Thanks.
Offline linziyi
« Reply #39 on: Tue, 18 June 2013, 16:54:26 »
:( they won't let me drop the case
Ducky DK9008G2 Pro
Offline Grim Fandango
« Reply #40 on: Tue, 18 June 2013, 19:33:17 »
I know I will catch some flack for this , but it does not seem all that comfortable for me to use.
I would like to try it out, but the price is a little too high for something I only half expect to like. It does look interesting though, and I have been a big fan of ergonomic keyboards that I have tried in the past.
« Reply #41 on: Tue, 18 June 2013, 19:49:34 »
You're right to be suspicious.  but the design philosophies are well tested and carried out in numerous other keyboard iterations.. All of the best features have been combined to create the ergodox.
The straight column key layout, great success on the truly ergonomic
The thumb buttons/cluster,  kinesis
The splitting down the middle,  needs no introduction.
Ontop of that, it's fully programmable and cheap to buy...
easy mod plate for any conceivable spring/stem combination...
« Reply #42 on: Tue, 18 June 2013, 20:01:24 »
So what's the time frame on these once the sale is over. From reading on the mass drop site, sounds like they are having issues sourcing switches.
« Reply #43 on: Tue, 18 June 2013, 21:26:03 »
yea... if we had any other place to buy an ergodox.. this would be a lively discussion.. :D,
Offline tricheboars
  • Keyboards are Important!
« Reply #44 on: Tue, 18 June 2013, 22:26:31 »
i dont like split keyboards. i hate soldering diodes. so why do i still want to buy this?
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #45 on: Tue, 18 June 2013, 23:38:22 »
an expensive educating keyboard building experience?
« Reply #46 on: Wed, 19 June 2013, 02:22:21 »
get yourself some "solder paste" for the smds..
I didn't want to wait 3 days so I built mine without it, but if I were to do another one i'd try to save a little time with solder paste.
Offline bbl
« Reply #47 on: Wed, 19 June 2013, 03:03:38 »
MassDrop is offering only blank keycaps this time round.  As the learning curve of switching to blank is going to be rather steep, what GB I should join for legend keycaps?
- Will probably use the "standard" layout on Layer 0 provided at MassDrop.  (So much time/effort has put into it, got to be good.)
- Other GH participants have suggested harvesting keycaps from used keyboards offered at eBay.  However, the shipping cost is 3-4 times that of the used keyboard.  May as well buy new.
- Thick PBT is highly recommended here.  Nice to find out how good they are with this opportunity.  However, I do like the color scheme of the RED ALERT design.
Given the unique layout, it seems I need to join a keycap GB of a TKL keyboard.  Throw away the spacebar and, may be, buy one or two 1u or 1.5u for the thumb cluster.  (The thumb cluster seems to have more keys than a standard TKL.)
Any advice?
« Reply #48 on: Wed, 19 June 2013, 03:23:52 »
Any advice?
The "THICK" part of the thick pbt makes very little difference.. I think for most people that are reviewing the thick pbt, they are feeling the difference of cherry profile vs oem rather than anything to do with the THICKness
The shorter cherry profile will feel smoother because the shorter keycap generates less torque as it pivots the switch stem against the switch housing. This reduces the friction of the keypress
I recommend getting the DCS instead of the DSA profile keys from ergodox.
It is similar to the cherry profile.
It really doesn't make sense to buy a thick pbt set just for the ergodox, because you wouldn't use half the caps, and again, people are not correctly attributing the Advantage/ difference they are perceiving.
The default layout on massdrop is a good starting point.. but def don't be LIMITED by it or your own familiarity with qwerty.
Built the layout to Your specifications.
Offline CommunistWitchDr
  • >implying keyboards
« Reply #49 on: Wed, 19 June 2013, 07:25:20 »
If you're not touch typing the edox is useless, and if you are the curve shouldn't be too bad.
