Author Topic: What Keyboard Are You Using Now?  (Read 5248630 times)
Offline nelamvr6
Re: What Keyboard Are You Using Now?
« Reply #6150 on: Tue, 25 September 2018, 17:20:38 »
Right now I'm using my PFU Limited 87U:
Keychron Q6 w/ Zeal Clickiez | IBM Model F AT | Leopold FC660C | HHKB Type S
Offline livewirerc
« Reply #6151 on: Wed, 26 September 2018, 09:27:29 »
Sorry for crap lighting but this is my office keyboard. I have a matching one in rose gold at home, and a HHKB BT for moving around with.
204365-0
Tokyo60 - Space Gray
Cherry MX Clear switches
Cherry MX Grey space bar and escape key switches
Stock S1 Tokyo60 keycaps
Red cherry profile escape key from... I don't remember where
Offline Ruskie
« Reply #6152 on: Wed, 26 September 2018, 11:27:21 »
My current daily driver is a modded FC980M that I had used at work for a while. It is using 67g Kailh Pro Purples, Lubed, clipped, band-aided genuine cherry stabs, and the stock PBT front printed keycaps! I also have a Kira60 with a Zeal60 and 78g zilents, but I never felt comfortable taking that ****er to work. I also use a Prime-M as a CAD-pad, as I am an engineering major at GMU. That is using lubed Tealios with a mishmash of GMK Violet Tendencies mods and OG WoB cherry doubleshots for the alphas!
Ive got myself a beefy boi
-Alf F62PE
-PCB Mount ZealV2 67g
-GMK KA1953 "OG Classic Retro"
8 pounds of clack
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #6153 on: Wed, 26 September 2018, 14:28:19 »
VEA with copper plate, pandelios switches, custom copper cable and twin sets of GMK Solarised Dark.
Sent from my iPhone using Tapatalk Pro
Offline Playa-V
« Reply #6154 on: Fri, 28 September 2018, 16:06:28 »
That VHT dye worked out nicely.
« Last Edit: Fri, 28 September 2018, 16:20:12 by Playa-V »
    • Jae | Top Clack
« Reply #6155 on: Sun, 30 September 2018, 18:16:57 »
TGR Alice in Pink with EPBT BoW and Nixie switches
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #6156 on: Mon, 01 October 2018, 10:48:13 »
HHKB Pro 2 in Black
Offline Fearian
    • 3D
« Reply #6157 on: Tue, 02 October 2018, 06:42:16 »
I don't see many ISO 60% with arrows! I had to file away bit of the plate to fit these in.
204800-0
Offline Lansky
  • Realest motherthocker
« Reply #6158 on: Wed, 03 October 2018, 08:35:06 »
Finally put together my velvet red Singa R2 with a brass plate, polished stainless steel weight, retooled MX blacks lubed with Tribosys 3204 and spring-swapped with 68 g. catweewee gold springs. The stabilizers are GMK screw-in stabilizers that have been clipped, lubed (3204/SuperLube) and band-aid modded.
Yes, I know the spacebar doesn't fit but I didn't have a set with a 7u spacebar laying around. The keycaps are temporary, still waiting on a different set for this board. :)
Offline daerid
    • Rossipedia
« Reply #6159 on: Wed, 03 October 2018, 17:02:51 »
I want, and very much need, this.
Currently back on a Filco MJ2 with Browns.
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« Reply #6160 on: Thu, 04 October 2018, 01:39:08 »
Using my current favorite layout + favorite switches.
Nightfox (Whitefox PCB) with lubed Blue Zilents 78g and SA Industrial. Cable is from CoolCableUK :cool:
Customized the right shift to be my play/pause button, which I use a lot.
Bugs me that I don't have the 1.5u backspace for this set though. Hoping to pick up a new SA set soon!
I just love the feel of these switches and the layout is perfect for my use. I'm typing much more efficient on this than a plain 60% or a 100%. Considering getting a Whitefox for my home build :)
Offline malu1989
« Reply #6161 on: Mon, 08 October 2018, 14:58:25 »
Using a self built 60% with tmk firmware and spacefn layout.
205088-0
Parts are from a cherry G80-3000 which I salvaged for switches, stabs and caps.
Switches are MX Clears modded to lubed ergo clears. Top plate is steel, bottom is lasered plywood.
Offline Delmondo
  • matias lover, toilet flusher
« Reply #6162 on: Sat, 13 October 2018, 15:48:44 »
i super love this layout. i would love to do a project like this.
at the time of writing, i'm using mainly an ikbc cd108 with box jades and some dye sub SA keycaps. when i feel like it, i use a matias mac mini.
here is the ikbc:
diet soda drinker
Offline typo
« Reply #6163 on: Sun, 14 October 2018, 00:46:33 »
I am using Topre RGB PCB in custom Titanium case with mixed sets of GMK key caps. A few 3d wonky keys I don't touch a lot like ESC, ALT. I think this as of now is my grail. I have over 2 grand invested in it. It really does not seem like 45g. Almost as stiff as Clears. Of course lubed, o-ring.
Offline SBJ
  • Tactile pls
« Reply #6164 on: Sun, 14 October 2018, 02:13:30 »
Pictures please. :D
Offline ander
  • I type, therefore I am
« Reply #6165 on: Sun, 14 October 2018, 03:40:26 »
Realforce 87UB55, model SE18T0 (uniform 55g TKL, black on charcoal)
205358-0
...because:
• It's practically the same size as my Dell XPS (8th-gen Core i7, 16GB, 500GB SSD, 3200x1800).
• It doesn't disturb my wife sleeping down the hall here in the condo.
• It combines the long-term reliability of Topre capacitive switches with that famous...
205360-1
So thanks for asking, my good geeks.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #6166 on: Sun, 14 October 2018, 12:06:03 »
...because:
Nice. However, do my little eyes spy Windows 7? Or did you change the Windows 10 start icon?
Offline danwomansan
  • Also known by my real name, ********!
« Reply #6167 on: Wed, 17 October 2018, 09:36:46 »
this keeb
better to me than people said me it would be
G84-4100 from cherry
it's pronounced "danw omansen", not "dan woman san"
Offline atectatifern
« Reply #6168 on: Thu, 18 October 2018, 16:52:06 »
« Last Edit: Thu, 18 October 2018, 16:53:52 by atectatifern »
Offline switch10
« Reply #6169 on: Thu, 18 October 2018, 18:44:50 »
This Levinson is my current favorite.
« Last Edit: Thu, 18 October 2018, 18:46:45 by switch10 »
Offline fishinaspacesuit
« Reply #6170 on: Wed, 24 October 2018, 08:53:57 »
Rocking this as my daily driver - Astrophysical Norbatouch with Masterkeys Pro S resoldered with lubed Zilents 65g and two layers of Sorbothane damping film
It's a quiet beast  :p
« Reply #6171 on: Wed, 24 October 2018, 12:07:29 »
This keeb is so Deep in hobby addiction that it would scare most people..
We know ur just like us, but others may think, Serial killer fur sure..
« Reply #6172 on: Wed, 24 October 2018, 12:11:02 »
...because:
Where be them 1337 mice.
206118-0
Offline frydaja
  • "It's my last keyboard, I swear"
« Reply #6173 on: Wed, 24 October 2018, 13:42:48 »
Compaq-branded NMB RT101. It's a rubber dome, but it feels nice (and so.. non-rubbery for a rubber dome), PBT keycaps.. also I love the older Compaq logo.
206120-0
Anne Pro 2 w/ Kailh Box Browns | CM Storm Quickfire TK Stealth w/ MX Browns | Unknown Chinese keyboard w/ Outemu Reds | Compaq-branded NMB RT101 | Gigabyte Force K81 w/Kailh Reds
« Reply #6174 on: Wed, 24 October 2018, 13:48:44 »
Offline AJM
« Reply #6175 on: Wed, 24 October 2018, 15:24:00 »
Since Monday I use an "XT" at work as well, so finally I can get used to a proper layout again.
206123-0
Offline supamesican
« Reply #6176 on: Wed, 24 October 2018, 19:29:02 »
This ibm model m 2. Honestly if it was tkl it would be the best throw in my backback keyboard i could think of. Feels almost as good ad my model m ssk and unicomp model m, but its much lighter than ether. o206152-0
Offline smarmar
  • It don't mean a thing if it ain't got that swing
    • Short Stories from an Old Library
« Reply #6177 on: Mon, 26 November 2018, 11:41:14 »
I have one of these Compaqs. I can confirm that the rubber dome does feels good under-finger. Mine came from a soldering plant or something; it has long melted scars on the case. It's seen some action!
1992 IBM Model M | Tesoro Durandal[Browns] | Hi-Tek Series 725[Space Invaders] | Tandy Enhanced[Sliders] | Dell Quiet Keys | Mitsumi[AT]
Offline tradercreep
« Reply #6178 on: Fri, 30 November 2018, 06:21:50 »
Filco majestouch red silent switch. The most silent keyboard at my workplace  ;D ;D ;D
Offline Lansky
« Reply #6179 on: Fri, 30 November 2018, 11:34:50 »
Singa R2 with lubed retooled MX blacks and ePBT 9009 R3.
Offline BigDov
« Reply #6180 on: Fri, 30 November 2018, 12:46:56 »
At work: Ergodox EZ w/ MX Browns + a few MX Clears I tossed in just to get a feel for them (mostly at thumbs; space and return, a couple others). A mix of their PBT caps that came with the board, and some of my Granite caps for a little color.
At home: O.G. Ergodox w/ MX Blues modded with Red springs (I think.... 35g springs, anyway), the rest of the Granite caps and few others tossed on for good measure, no pics currently. Also in use at home is a CM QFR w/ MX Reds that is waiting for the Jukebox caps to show up from the MD Black Friday drop :thumb:
« Last Edit: Fri, 30 November 2018, 12:48:40 by BigDov »
ergodox w/ MX Blues & Granite R4 + grifiti wrist rests || CM Storm QFR w/ Reds & black PBT laser-etched caps
Offline danwomansan
« Reply #6181 on: Fri, 07 December 2018, 11:08:08 »
blurry pic, new tada68 with gat yellows, spacebar flibbed, i put on the left shift stabs backwards so i cant put a cap on it now, also didn't have a full single keycap set for it which fit all the keys so most of the keys are from one keyset and the others are from one which is invisible in the eyes of my camera
Offline Luciqueii
  • 【Luciquell & Co.】
« Reply #6182 on: Fri, 07 December 2018, 11:15:00 »
My first build ATM... Tofu case, Knock off Chocolates, Box Whites, Brass Plate and PCB GH 60 SATAN
Cheers,
- F.L.
Offline Sup
« Reply #6183 on: Fri, 07 December 2018, 13:22:56 »
Canoe R1 with stock Gateron red switches  :p .
current
Coming soon
Offline frydaja
« Reply #6184 on: Fri, 07 December 2018, 17:14:54 »
CoolerMaster Masterkeys Lite L.
(Chyros's room-temperature butter)
Offline fossilcodger
    • Classic sci-fi author
« Reply #6185 on: Fri, 07 December 2018, 18:58:38 »
Ultimate Hacking Keyboard (UHK60):
Offline Oni74
« Reply #6186 on: Sat, 08 December 2018, 09:32:49 »
Work - K-type with lubed gateron yellows with sprit 65g springs
Home1 - Alt with lubed Zealios 65g
Home2 - KBD75 PCB + XD84 Case + Lubed gateron yellows with sprit 65g springs
Float - KBD75 with Zealios 62g
Here's a family portrait:
Offline invariance
  • ...here with all the other boson's
« Reply #6187 on: Sat, 08 December 2018, 17:07:58 »
Wyse 85 for this month
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline pureiridium
« Reply #6188 on: Tue, 11 December 2018, 12:58:57 »
Hi guys...
My first post here... I know this is the wrong sub-forum for this question, but this is the one of the best threads to ask this given who is posting in it; being that it's about what keyboards you guys are actually "using now".
I noticed that the big majority of you are all using the normal rectangular layout of keys be it 60%, TKL or the full set with what look like normal switch travel and keycap profile. Now I am puzzled as to how you guys get by since I find that I can't type on a normal rectangular key layout unless I:
a. Type on a setup where the keyboard is hip-height or close to it; like one would find on a table with an under-desk pull-out tray. (Which I don't have at the moment)
b. Allow the keyboard to be on the desktop, but then I will have to take quite some care in terms of how I position myself in relation to the keyboard. If I just move the keyboard so much as a few little degrees from the ideal orientation or shift the keyboard just one or two centimeters to the right or left, then I'm going to feel the aches and discomfort about 30 to 40 minutes into the typing session. (This is my current situation.)
Now I'm not even a big or wide guy, so I don't have to scrunch my arms or shoulders to get my fingers on the home row. I'm not old or suffering from past injuries or such either. Still, I get typing discomfort very easily if I don't follow the directions above.
And the big problem is that I need to move my keyboard around my desk a lot because I read on it, do drawings on it and all kinds of things on it that require the keyboard to be shifted everywhere and when I do type on it, I can't move my papers or works aside that easily because they are usually oriented in a particular way around me to maximise productivity.
So for the vast majority of you guys who are using the standard non-split/angled keyboard layout, how do you get by? Does a wrist-rest solve all your issues for you? Do you not move your keyboard about much and thus restrict it to a very specific position on the desk where you don't feel like ergonomics are an issue? If yes to those, then your bodies are like mine me and then I guess I would be doing what you guys are doing and drooling over more rectangular KBs!
But if you are also like me in that you have to move your KB about your desk a lot and often have to type on it at not the ideal location, how do you get by?
Just curious... Not trying to derail this thread or anything, but if just one or two of the more experienced members could tell me how it is that ergonomic keyboards aren't dominating this thread and what most most posters here are doing with their typing setups that allows them to use the normal keyboard layout -that would be extremely helpful...
Me personally, I will have to either get a low-profile keyboard with minimal switch travel (somehow it makes ergonomics much less of an issue for me) or get a split keyboard or something like that.
« Reply #6189 on: Tue, 11 December 2018, 19:51:24 »
I'm using my CODE with MX clears but keep looking at the QFR with MX greens on the shelf over there.
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #6190 on: Tue, 11 December 2018, 19:55:23 »
Currently using a NMB RT8255C+ I haven't found a board that I like as much in a little while(better than my omnikeys because they are in poor condition). Plus waiting on some boards I have designed to go in GBs so I can get one.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #6191 on: Tue, 11 December 2018, 21:04:10 »
Omg so jealous, I really want to buy it but the price is so steep compare to regular Topre.
And I currently own a 104UW modded with KBDFans silence rings so it would be a minor upgrade for me, so it's a tough call even though I really want it.
Offline ArchDill
« Reply #6192 on: Tue, 11 December 2018, 22:00:22 »
Revo RJ with lubed MX Silent Black Stems in Zeal housings on a brass plate.
Soooo gooooooood.
Offline ollir_
« Reply #6193 on: Wed, 12 December 2018, 10:02:47 »
Decided to give my Monterey K108 some desk time. The switches are $$$ like always, and the board is so light and flexing that a big bad wolf could blow it apart.
Excellent fun just the way it is!
Offline Tactile
« Reply #6194 on: Wed, 12 December 2018, 11:17:05 »
Dug the old GH60. haven't used this in quite a while.
208794-0
REΛLFORCE
Offline Lansky
« Reply #6195 on: Thu, 13 December 2018, 04:06:59 »
LZ GH V2 with Zealios V1 (67g, springs lubed with 3204), GMK stabilizers (lubed, clipped and band-aided) and ePBT 9009.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #6196 on: Thu, 13 December 2018, 10:48:21 »
 So nice  :thumb:  I have to start building mine soon.
I wish LZ would also make a LZ-GH 60%.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline abhixec
« Reply #6197 on: Thu, 13 December 2018, 13:40:35 »
Left is 40% mini niu, then GH60 satan with 5degree case and to the right is the numpad(YMDK 21)
right now I taking my 40% mini niu with me everywhere with my back pack. :D (office, remote work place, everywhere my backpack goes) occassionally connect it to my galaxy tab s 3 to work on it as well :)
« Last Edit: Thu, 13 December 2018, 14:20:18 by abhixec »
Offline Lansky
« Reply #6198 on: Thu, 13 December 2018, 14:34:47 »
Thanks, my guy. You should definitely start building it! It’s a great board.
Offline danwomansan
« Reply #6199 on: Thu, 13 December 2018, 17:44:20 »
excuse the bad pic, my light burnt out and im using an old phone as a camera
tada68 with new stock box navies
