Author Topic: any one can help me on this picture?  (Read 2958 times)
Offline jonathanyu
« on: Fri, 16 August 2013, 18:05:21 »
any body can help me to make the backgroud of this picture become white?
I don't know how to use photoshop, so can anyone help me?
Re: any one can help me on this picture?
« Reply #1 on: Fri, 16 August 2013, 18:08:29 »
That's an itty bitty image. What are you going to use it for?
Edit: Here you go. The blue might not be exact.
« Last Edit: Fri, 16 August 2013, 18:13:06 by Findecanor »
Offline jonathanyu
« Reply #2 on: Fri, 16 August 2013, 18:11:28 »
i think i am going to use it on the geekhack custom engrave keychains
« Reply #3 on: Fri, 16 August 2013, 18:14:56 »
Ah. Then I think that you would need a larger, sharper image. That one is quite small and blurry. I think that the engraving would need sharp edges to give a good result.
BTW. I edited my post to post an edited image above.
Offline jonathanyu
« Reply #4 on: Fri, 16 August 2013, 18:18:57 »
 :D Thank you!
I know it need a sharper image, but the available engrave is very small, i think is 15mmx10mm  :blank: so i think should use a small picture
Offline jonathanyu
« Reply #6 on: Fri, 16 August 2013, 20:52:24 »
is this from that mermaid anime
 :D nope, this logo was designed by my friend
Offline vun
  • Just one more thing
« Reply #7 on: Fri, 16 August 2013, 20:53:56 »
If that's the case then surely your friend can provide you with a larger resolution picture with any colour background you want?
Offline jonathanyu
« Reply #8 on: Fri, 16 August 2013, 21:40:59 »
I have thought that before, but my friend doesn't have any program like photoshop any more. :blank:
Offline Topre
« Reply #9 on: Sat, 17 August 2013, 00:05:18 »
How are you using a .png for laser engraving? My laser machine only accepts vectors.
Offline TheSoulhunter
  • ~ BOOO ~
A Ghost From The Past
Offline jonathanyu
« Reply #11 on: Sat, 17 August 2013, 14:14:00 »
oh, so i need to convert it to a vector image first?
« Reply #12 on: Sat, 17 August 2013, 15:00:59 »
I used Gimp, which his free. The interface is a bit different, but there should be a version that looks and feels more like Photoshop.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #13 on: Sat, 17 August 2013, 16:13:44 »
If this is the image you want to use, I will try and convert it for you/
  • ~ BOOO ~
« Reply #14 on: Sat, 17 August 2013, 16:16:24 »
Upscale -> Upload to Vectormagic (the first few processings should be free iirc) -> Download generated vector file -> Tweak in Inkscape (free)
EDIT: Or wait for MOZ :D
