Author Topic: Will my mouse feet wear out faster..  (Read 12351 times)
Offline Emospence
« on: Fri, 30 August 2013, 07:55:34 »
On a hard pad?
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline Leslieann
Re: Will my mouse feet wear out faster..
« Reply #1 on: Fri, 30 August 2013, 16:40:19 »
On a hard pad?
Yes, but does it matter if they only last 6 years as opposed to 10?
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline vun
  • Just one more thing
« Reply #2 on: Fri, 30 August 2013, 16:47:01 »
If you're really worried about it just ask them to send you spares, I asked Logitech for spare G9x feet just in case I'd ever need them since it's one of my favourite mice and they sent me a set free of charge.
« Reply #3 on: Fri, 30 August 2013, 17:07:18 »
You really shouldn't have to worry about wearing out your mouse feet for years unless you are using a sandpaper mouse pad. It's just a gimmick companies use to sell you a little something extra, or for people who legitimately scratch or had their feet fall off.
« Reply #5 on: Fri, 30 August 2013, 18:21:27 »
My g300 feet only lasted a year. Logitech sent a whole new mouse.
My g700 buttons and feet are also showing lots of wear.
Offline vun
« Reply #6 on: Fri, 30 August 2013, 18:23:07 »
Man, what surface are you using?
« Reply #7 on: Fri, 30 August 2013, 18:26:51 »
SteelSeries 4HD Professional Gaming Mouse Pad (Black)
http://www.amazon.com/dp/B002J9G5AE/ref=cm_sw_r_an_am_ap_am_us?ie=UTF8
Offline vun
« Reply #8 on: Fri, 30 August 2013, 18:34:16 »
Then it would seem that surface does make a difference, since my G5 saw several years of use on a SS 5L pad, which is sort of hybrid, and while the feet are showing wear they are still usable.
Offline MJ45
  • HHKB Pro
« Reply #9 on: Fri, 30 August 2013, 18:44:26 »
I have the SteelSeries 9HD and although I like it much it wears the mouse's teflon pretty quick!
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #10 on: Sat, 31 August 2013, 13:44:05 »
I JUST TAKE THE MOUSE FEET OFF. THEY ALWAYS SEEM TO LIKE TO PEEL OFF ANYWAYS, ESPECIALLY ON DELL MICE FOR SOME REASON.
Offline domoaligato
Offline Hyde
  • White Tofu Extraordinaire
« Reply #12 on: Mon, 02 September 2013, 12:41:14 »
Yeah hard pad does wear it off faster, that's why I stick to soft pad or hybrid pad.  :thumb:
Or just get replacement mouse feet every 6 months or so.
Offline abdulmuhsee
« Reply #13 on: Mon, 02 September 2013, 12:48:01 »
Honestly, I'd be more worried about my left mouse button becoming defunct long before my mouse feet wore off.
I use a hard mouse surface and I've never had the feet wear off.  I have, however, gone through multiple mice due to exhausting the left mouse button to where it becomes mushy and no longer clicks.
Offline domoaligato
« Reply #14 on: Mon, 02 September 2013, 12:52:08 »
I have had a mx 518 since it first came out and have replaced the feet at least 5 times because I was using hard gaming mouse pads.
the buttons still work perfectly and I have had that mouse for about 10 years.
Offline domoaligato
« Reply #15 on: Mon, 02 September 2013, 15:10:34 »
btw that tape I linked above is magic.
