Author Topic: QuickFire rapid switches  (Read 3106 times)
Offline HotKillerZzz
  • Ammesia
« on: Mon, 02 September 2013, 10:18:29 »
How do u remove the switches? I want to change my blue with the reds.
Offline AGmurdercore
Re: QuickFire rapid switches
« Reply #1 on: Mon, 02 September 2013, 12:13:39 »
You have to desolder them to change them.
What the hell am I even doing
  • Ammesia
« Reply #2 on: Tue, 03 September 2013, 03:41:14 »
Is there a guide?
« Reply #3 on: Tue, 03 September 2013, 04:10:35 »
There are alot actually this is the first one i got when i wrote that in google so check it out but i am pretty sure that you can find many more videos and guides
Offline SquawkVFR
« Reply #4 on: Tue, 03 September 2013, 04:22:18 »
Please don't take this as me trying to crap on your thread, but wouldn't it be cheaper to just buy another QFR with reds pre-installed?  Unless you are looking to gain experience soldering, just checking prices over at WASD Keyboards, this would cost you $174 for the switches alone.
Offline Tym
« Reply #5 on: Tue, 03 September 2013, 04:30:24 »
No-one buys their switches from WASD, they get them from 7bit over on DT for >half the price.
« Reply #6 on: Tue, 03 September 2013, 04:34:11 »
You can even get them second hand here in the classified for around 0.50 to 0.60$ each. But yeah wasd are selling everything super overpriced, some stuff there is more then double on what you can get from other websites. They are only good if you want to get some custom engraved/lasered keys and thats it.
Offline SquawkVFR
« Reply #7 on: Tue, 03 September 2013, 04:37:16 »
Thanks for the heads up, and I just saw his prices.  Equates to about a $15-20 savings for a customer in the US, but I have no idea on the cost of a new QFR in Singapore.
Good luck OP, I hope I didn't muddy your thread too much.
Offline Photoelectric
« Reply #8 on: Tue, 03 September 2013, 10:41:19 »
This thread should not be in this sub forum anyway.  It should be somewhere in "Keyboards".
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #9 on: Tue, 03 September 2013, 12:01:33 »
Yep.  Moved.
Offline tricheboars
  • Keyboards are Important!
« Reply #10 on: Tue, 03 September 2013, 12:08:25 »
you shouldnt ever pay more than $.64 cents for stock switches. now if you get some stickered and lubed switches that is another thing all together. mouser, 7-bit, onlinecomponents.com, and other places offer switches around this price.
« Reply #11 on: Tue, 03 September 2013, 12:10:57 »
Don't do this....
Takes forever...
Just buy another board...  there's no way you can do this with $30 worth of "your own labor + materials"...
sell your old board for $50 or less $40,  and pay the difference for the MX RED.
  • Ammesia
« Reply #12 on: Wed, 04 September 2013, 04:12:40 »
Thanks for advice guys,
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #13 on: Wed, 04 September 2013, 13:34:40 »
You mean 0.64 EUR right?
IF you do mean USD where do you get it??
Please???
I'm kinda crazy trying to get a hundred blues and browns per a decent price (anything below 0.70 USD) ...
« Last Edit: Wed, 04 September 2013, 13:41:49 by agodinhost »
Offline elttaboi
« Reply #14 on: Wed, 04 September 2013, 17:38:36 »
I'd say it wouldn't be worth it if you just want reds because you can just go and buy a red QFR for cheap.
It would be worth it to put some clears or whites on it since you can't get those on stock QFRs.
Offline BliTzKiN
« Reply #15 on: Wed, 04 September 2013, 20:54:11 »
Fellow Singaporean! Its probably more advisable in our country to desolder only if you already have the tools to do so. The price it takes to get the switches and have them shipped to our country is already more that half of what a new QFR would cost here, adding the soldering equipment would already make it more expensive than just buying a new one. Unless you have access to used red switches (which goes fairly cheap), and have someone to borrow the needed tools from, I would strongly just recommend getting another QFR with Reds and settle for 2 boards :D
  • Ammesia
« Reply #16 on: Thu, 05 September 2013, 00:39:55 »
Hey another fellow Singaporean, thanks!! Btw I am wanting to get a replacement panel for my quickfire rapid, may I know if u know where to get one?
Offline pagosElite
  • This website clings to you.
« Reply #17 on: Thu, 05 September 2013, 01:20:54 »
What exactly is stickering?
Offline Lu_e
« Reply #18 on: Thu, 05 September 2013, 01:31:02 »
When you open the switch halves and stick a sticker between the switch halves. Not exactly sure how soft the stickers are but all I could think of them doing is perhaps slightly changing audio produced and maybe slightly better feel? or placebo cool points
Just say NO to ABS keycaps
Offline BliTzKiN
« Reply #19 on: Thu, 05 September 2013, 09:40:19 »
Actually, both of it, and additional points for reducing the amount of movement between the switch top and bottom housing. The stickers are also fairly fragile because some parts of it run quite thin. A rather time consuming mod that I find worth doing :)
