Author Topic: WORST COMPUTER YOU'VE EVER OWNED/HAD TO USE  (Read 25505 times)
Offline Leslieann
Re: WORST COMPUTER YOU'VE EVER OWNED/HAD TO USE
« Reply #50 on: Mon, 23 September 2013, 03:53:53 »
I think part of the problem wasn't just DDR2, it was bad chipset options.  I think you could get some P35/P45 boards with DDR3 slots, but I think some of the chipsets had weird limits like "8Gb DDR2, 4Gb DDR3 only".  I learned that one the hard way dealing with a stupid G41-based machine.
The best chipset was the P45 and P55, but they were only Sata2 and DDR2. A few could go to 16gigs of ram, but bend over if you want it. Just as the larger ram sticks were starting to ramp up production was right when the flood happened and DDR2 was discontinued for the most part, so they aren't that common. In fact Newegg has no DDR2, but has DDR1 and DDR3.
The newer G41's could do DDR3, but the chipset is actually a downgrade and just an upgrade path to DDR3, so you get weird memory limits (some are even 10/100 and not gigabit). I honestly think it's just an old, juiced up 945 chipset, which while not fantastic has been Intel's workhorse for a while. At any rate, the G4's not meant to really replace the older chipsets, it's meant as a replacement motherboard to keep you going until you can upgrade. This is especially true for boards supporting multiple ram types.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline IPT
  • Formerly projectD
« Reply #51 on: Mon, 23 September 2013, 11:05:30 »
my bro's still using a Q6600 with Gigabyte P35-DS3R lol
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #52 on: Mon, 23 September 2013, 15:13:10 »
This is a canon computer that came in the other day at our shop
4mb ram
400 MB hdd
50 mhz processor
the comp had a BS with it too! I tried buying it off her for 60$ LOL but she liked it too much apparently
Are those ISA ports I see? Looks like we're going back to the good ol' days!
Offline roaduck
« Reply #53 on: Mon, 02 June 2014, 01:48:20 »
Tell us about the worst computer you owned or had to use on a regular basis!
I'd say the worst ones I had to work with would have been the Apple Emac's after they started getting old. They were slower than dirt with their dinky G4 processors running Mac OS X 10.5 on 1GB of ram. And half of 'em had really bad screen burn too from the MAC OS 9.2 days (OS9 didn't have screen savers for the login screen). And then the keyboards....they came with the worst feeling rubber dome keyboards imagineable.
The first modern PC I had in 1999 was called a Patriot which had an Intel  667Mhz chip, 256KB RAM memory a 10 GB HDD and 13 inch monitor...God it was terrible...Windows 98SE and it was ugly, slow and as about as reliable as a chocolate fireguard.
It regularly sparked and/or caught fire or something died on it and I had to reinstall Win 98 twelve times in one day because of catastrophic crashes.
It cost £599 and was a total dog.It was much worse than the TIME machine...that was a ferrari compared to my effort.
BS : IBM 1391406
Other keyboards - don\'t ask
Offline Kayla
  • :3
« Reply #54 on: Mon, 02 June 2014, 01:58:34 »
Anything by Lenovo
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #56 on: Mon, 02 June 2014, 03:54:09 »
Any computer that isn't mine, really.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline blackbox
« Reply #57 on: Mon, 09 June 2014, 17:57:33 »
Anything by Lenovo
Why?
My acer eee netbook and my hp g5000 was pretty bad. The HP had few connectors and had bad thermal design.
The LAN table!
Offline Prelim
« Reply #58 on: Thu, 10 July 2014, 14:24:55 »
well, anything from asus is a bad pc :p
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline blackbox
« Reply #59 on: Sun, 13 July 2014, 04:00:16 »
Can you explain your joke?
The LAN table!
Online Computer-Lab in Basement
  • Live long and prosper
« Reply #61 on: Sun, 13 July 2014, 10:34:56 »
asus laptops are notoriously warm running...
TBH I've had worse experiences with HP laptops. Almost every single one with AMD CPUs overheats and fries the motherboard after like 2 years. Personally dealt with 5 such cases of this, and will never buy an HP laptop because of it.
tp thread is tp thread
« Reply #62 on: Sun, 13 July 2014, 12:39:27 »
the problem with those was that because the amd cpus ran so hot, the fans on average ran at higher rpm..
and the higher rpm leads to higher dust buildup.. which means..... even more heat.. more dust.. it's a dust-heat spiral..
If however you clean out the Inside of the cooler,, the laptop will run like day one..
if you look at the image below.. that inevitably happens to EVERY laptop..  happens faster to warmer running laptops than cooler running ones..
the only way to fix it is to take the cooler assembly apart.. usually not accessible.. without disassembling the entire board.
Manufacturers can actually make this section easily accessible and cleanable, but alas, they don't want to, they'd rather have you buy a new laptop..
Offline paicrai
  • mindblank
« Reply #63 on: Sun, 13 July 2014, 16:43:47 »
ive heard toasters are pretty bad
THE FEMINIST ILLUMINATI
Offline iLLucionist
  • Topre is Love.
« Reply #64 on: Tue, 15 July 2014, 08:17:06 »
Compaq Presario 2200 Desktop:
http://en.wikipedia.org/wiki/Compaq_Presario_2200
It was horrible. It was actually sold with a "Pentium inside" processor, but it was a f***king cyrix. I felt so ripped of. GPU shared memory. Horrible display. Lots of IRQ conflicts (Win95, not second edition). The buttons on the front panel stopped working with six months, the cd drive became flaky within one year.
But well, for as far as nostalgia goes, it played Command and Conquer and some FPS so I was happy. Also, it ran VB 5.0 and Borland Delphi 4.0 quite well.
The only thing that still seems to work, is the display that came with it.
Offline iLLucionist
  • Topre is Love.
« Reply #65 on: Tue, 15 July 2014, 08:18:55 »
Toshiba laptop with Vista. It was purchased about a week after Vista launched. And that's how I became a fan of Macs.
SO THAT WAY YOU COULD BE A FAN OF THE ONLY THING THAT WAS WORSE THAN WINDOWS VISTA?
He said Mac, not ME :p
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #66 on: Tue, 15 July 2014, 09:47:16 »
Every HP/Compaq DV xxxx laptop ever created, hate the things the amount of times I have seen, them with issues bleh never going to buy anything from HP also put me off Nvidia for a while since they where selling fautly GPU's to HP you can still buy them as a plastic keychain >_>
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline deltuhhh
« Reply #67 on: Tue, 15 July 2014, 10:06:27 »
My HP laptop oh god.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #68 on: Tue, 15 July 2014, 10:59:55 »
I used to have a desktop from HP with a Pentium D CPU, one of the first dual cores that comprised of two dies slapped together. After a while it would randomly shut down without warning and wouldn't start anymore. It was not a heat related thing either and after six trips back to their RMA service where they replaced pretty much all the internals I sent a letter to ask for my money back.
The money was used to build my first PC which is still working till this day.
I was never able to figure out what it was. :/
|||My other keyboards :
x
Offline Turkishrambo
« Reply #69 on: Wed, 16 July 2014, 18:31:21 »
Wonder why this customer's computer was turning off
« Last Edit: Wed, 16 July 2014, 18:37:32 by Turkishrambo »
Offline belac
« Reply #71 on: Wed, 16 July 2014, 19:11:18 »
mmm... love that dust buildup.  reminds me of my days back when I worked in IT at the hospital. 1000s of PC's with too few caretakers. most looked like that on the inside.
« Reply #72 on: Wed, 16 July 2014, 19:15:38 »
I thought hospitals had the special air filters..
Offline Coreda
« Reply #73 on: Wed, 16 July 2014, 19:46:20 »
My last laptop allowed for this via a little section on the side, removable with screws. Dust built up again fairly quickly though.
As for worst computer I've owned? Probably would be a Toshiba Satellite laptop ages ago running Windows 98. Crashes were a fairly regular occurance. Installed XP on it later which made it more bearable.
Actually tried a laptop with Windows 3.1 given to me by an uncle who was into old computers. Not too shabby, but certainly no Mac OS. Somehow stumbled upon a PC mag column about the editor-in-chief still using it. I'd like to imagine it's true, even though it was published April 1st  ^-^
« Reply #74 on: Wed, 16 July 2014, 23:40:13 »
which laptop is this that had the slide
Offline Coreda
« Reply #75 on: Thu, 17 July 2014, 10:41:31 »
Toshiba Tecra A2. Loved it. I'm sure there would be others with a removable section, but I suppose more recent computers are tending to favor all-in-one designs.
Offline D01
« Reply #76 on: Thu, 17 July 2014, 10:59:37 »
Honestly the Asus desktop my wife bought a year ago.  I've had good luck with Asus products over the years when assembling a pc but this thing seems like they took every bad part they had a threw it in a case.
« Reply #77 on: Thu, 17 July 2014, 11:46:08 »
Asus, I've heard is fine.. Acer is the one you gotta worry about ... haha .. even the womenz no Acer is not to be trusted.
« Reply #78 on: Thu, 17 July 2014, 12:28:45 »
more like, -recent computers favor the fvk you customers are sheep to be farmed- design...
That laptop is sooo awesome.. my god... that feature can easily extend the life of the laptop by 5-8 years....
71242-0
« Reply #79 on: Fri, 18 July 2014, 08:06:00 »
Looks slightly dusty there.
Offline blackbox
« Reply #80 on: Fri, 18 July 2014, 09:50:36 »
Heatsinkbrownie.  Someone should make fan filters for heat sinks. Like an easy to clean one.
The LAN table!
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #81 on: Fri, 18 July 2014, 23:33:30 »
These thin clients at work pretty much suck ass. My WASD no longer works on them and they are slow as ****. (yes I have 2 screens and 20 windows open at once, but I neeeeed them goddamit!)
one of the guys in another department is going to push a new build to mine over the network for more USB power to see if I can get my WASD working again.
Offline D01
« Reply #82 on: Sat, 19 July 2014, 09:14:10 »
Aye.  The thin clients I have to deal with at work are crap as well.
Offline blackbox
« Reply #83 on: Sat, 19 July 2014, 13:14:16 »
I work with Wyse t10 thin clients at work and they work great. Ofc thin clients depends very much on the infrastructure.
The LAN table!
Offline inteli722
« Reply #84 on: Sun, 20 July 2014, 21:48:10 »
My old Dell Latitude D800 with the Pentium M and a gig of RAM. Had to use that thing through 2009 cuz poor.
Waiting for: Phantom Plate
Offline davkol
  •  Post Editing Timeout
« Reply #85 on: Mon, 21 July 2014, 07:04:48 »
I used a D400 in 2009, but didn't consider it to be a problem, except uneven screen backlighting and bad battery life.
Offline berserkfan
« Reply #86 on: Mon, 21 July 2014, 12:25:43 »
At present I am very angry.
You guys can see my threads about computer problems.
Frustrated as heck.
So I'll say, ALL COMPUTERS WITH MICROSOFT OS. Doesn't matter which computer.
Offline thesupergeek
« Reply #87 on: Mon, 21 July 2014, 12:40:22 »
Worst computer ever has to be my plastic MacBook 2,1. The sides chipped, the keyboard was very squishy, the hard drive failed once every two months, it overheated, the battery died after 20 cycles. Worst POS I have ever won at a developers conference. Eventually stuck it under my desk, booted it up on to a Debian flash drive, and used it to monitor my network. That is all it is worth to me now.
My collection:
GON HHKB (62g MX Clears), CM Storm Novatouch, Poker II (MX Blues)  ., HHKB 2 Pro ., Cherry G80 (MX Blacks), JD40 (In the mail as soon as Margo builds it!), Plank Keyboard (parts in the mail!)
Offline ShawnMeg
« Reply #88 on: Tue, 29 July 2014, 23:44:09 »
I used one of those old iMac G3's with the round base,  swivel neck monitor and round speakers.  It lagged from the start even with maxing out the RAM.
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
« Reply #89 on: Wed, 30 July 2014, 14:46:13 »
I remember those. Think they had G4 CPU's in them though. They were pieces of ****.
« Reply #90 on: Wed, 30 July 2014, 20:35:44 »
I remember using it to do some 3d cad.. renders took like an hour..
« Reply #91 on: Thu, 31 July 2014, 08:56:42 »
Only an hour? You must have been using the fast 1GHz version. The 800MHz G4's were so slow they ran backwards.
Offline Senthura
  • Your Doom
« Reply #92 on: Sun, 03 August 2014, 22:12:13 »
The Dell Optiplex computers in the shared lab at school. They're like 5 years old and are SO slow. It takes 5 minutes before you can log in. Any time I have a project or something and we have to use those I just do it on my laptop, put it on a flash drive, and use them to print it if a wireless printer isn't available.
Ducky Shine 3 TKL Blue switch & Green backlight
Offline ShawnMeg
« Reply #93 on: Mon, 04 August 2014, 22:56:36 »
Probably, there's so much s hit on the hard drive that it gets bogged down.  I have an Optiplex at work with an i5 and SSD running Win 7 Enterprise, small form factor.  It's wonderful.  The business class computers Optiplexes, as I understand, use better components.  I've had this computer for 2 years and never turned it off.  It's been rock solid, never a BSOD,, never lagging.
Offline korrelate
  • iubeo stultum esse libenter
« Reply #94 on: Mon, 04 August 2014, 23:16:25 »
anything osx lion.
Topre REALFORCE
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #95 on: Mon, 04 August 2014, 23:25:18 »
Yes, when OSX hit all those older cpus and motherboards they were literally real slow and useless to ever use again.   I use to remember had to go and make a cup of coffee sit down with a biscuit and finish the coffee and biscuit and still arrive to my Apple whilst to was still working on finishing an Excel spreadsheet calculation.
That was when a jumped on over to the Dark Side, and never looked back.  I still despise Jobsie for what he did to that once great PC manufacturer that went on to produce hardware that was so slow compared to anything Gatesie had made after 2009.
Imagine being beaten in Photoshop by a lower performance PC outfit when you've just wasted over $4'500AUD on a Powermac Tower  :'( .
« Last Edit: Mon, 04 August 2014, 23:26:50 by Elrick »
Offline blackbox
« Reply #96 on: Tue, 05 August 2014, 00:48:10 »
Since optiplex is Dells line of business-oriented computer there is no other versions of optiplexes. They have had issues with components in the optiplex line. Most notably the capacitors used in the optiplex sx270. Opened a sx270 some months ago and 90% of the capacitors where bad.
The LAN table!
« Reply #97 on: Sun, 31 August 2014, 13:33:58 »
Hahaha i was reminded by a really old p3 computer of this... i had totally forgotten. Back when a power button would kill the power to your computer completely no matter what.
Offline Senthura
  • Your Doom
« Reply #98 on: Sun, 31 August 2014, 14:29:07 »
Optiplex GX520. Cleared the hard drive and reinstalled the OS. Still pretty slow but functional. Better than nothing. They got new ones to kill and gave them away.
Offline Oobly
« Reply #99 on: Mon, 01 September 2014, 07:19:18 »
I was assigned to a client project end of 2006. Had to use Celeron laptop with 128MB RAM for developing server side Java / PHP and Javacsript... Had to keep rebooting it to clear out the memory so the IDE would actually be responsive (Eclipse).
Buying more keycaps,
it really hacks my wallet,
but I must have them.
