Author Topic: QFR with Blacks or TK with browns?  (Read 2816 times)
Offline DamnDan
  • The Insane One
    • My Deviantart
« on: Mon, 23 September 2013, 11:28:31 »
Hello there :)
After happily clacking away on my Dell AT101W i decided that i need something for my home use as well. As i am living in a place where mechanical keyboards are not a big thing and getting one which is high quality is an issue, I narrowed my choices to QFR with Blacks and TK with Browns.
My question is (it may be a bit silly, brace yourselves): After using Black ALPS for almost half a year, which is a better option in your opinion?
I really have no way of trying and testing them both prior purchase, so I am yet again reaching out to your knowledge and experience in this topic :(
I fear that browns will be too big of a jump from hard ALPS to light springs that browns have, and would not like to go through the pain of returning item back to seller :P
Help a fellow geek decide ;-)
Re: QFR with Blacks or TK with browns?
« Reply #1 on: Mon, 23 September 2013, 17:09:43 »
I am not familiar with black Alps, but QFR with MX blacks roxors! (using one to type this)
Offline do_Og@n
« Reply #2 on: Mon, 23 September 2013, 17:26:05 »
I've used the Black ALPS and if you are looking for an easier transfer from them to an MX switch I would suggest the QFR w/blacks. Blacks are linear and stiff (almost as stiff as Black ALPS) but move smoother.
Personally I would think if you moved to a Brown switch it would take longer to get used too. Good Luck!
Offline Tony
« Reply #3 on: Tue, 24 September 2013, 00:41:12 »
QFR Black is like Dell without the bump (60g)
TK brown is like Dell with a lighter bump (45g)
You decide.
Offline DamnDan
  • The Insane One
    • My Deviantart
« Reply #4 on: Tue, 24 September 2013, 02:41:02 »
I'm going with QFR blacks then :) Thanks guys :) I am probably going to miss out on the whole LED mod thingie but hell with it :P I simply like harder switches :)
Thanks ALOT guys :)
Probably will buy TK some day anyway :P
THANKS!
« Reply #5 on: Tue, 24 September 2013, 19:21:31 »
Thanks ALOT guys :)
THANKS!
Let us know what you think of it once you have been using it for a week or so.  First impressions are also nice :)
Offline Gunni
« Reply #6 on: Tue, 24 September 2013, 19:27:07 »
Nooo, I wanted a TK Brown Buddy D: Oh well.
Hope you like your QFR!
CM Storm Quickfire TK w/ Browns HHKB Pro 2
Offline Fragil1ty
  • Abre los ojos.
« Reply #7 on: Wed, 25 September 2013, 10:46:28 »
Hello there :)
I'm using MX Blacks on the Keycool 84 and I would not advise it in my opinion what so ever, I have never used browns but they're suppose to be the 'sweet spot', but I cannot verify that I'm afraid.
你搞砸了
« Reply #8 on: Wed, 25 September 2013, 10:47:52 »
I definitely wouldve voted for a QFR with Blacks as well.
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
« Reply #9 on: Wed, 25 September 2013, 11:01:20 »
QFR with greens!
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
Offline gh_pp
« Reply #10 on: Sat, 28 September 2013, 03:36:16 »
I'd have to agree with Tony.
I have both dell at101 & QFR brown and I think dell is closer to brown than black.
Dell's a bit noisy (but not clicky like blue), actuation force is between brown and black and it definitely have a tactile bump like brown (unlike black).
Both Dell & Brown are pretty light so you won't get tired easily but also easier to accidentally activate if you are not careful when typing fast.
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
« Reply #12 on: Sat, 28 September 2013, 04:49:02 »
Why not try to get another Dell AT101W?
Offline DamnDan
  • The Insane One
    • My Deviantart
« Reply #13 on: Fri, 22 November 2013, 08:22:37 »
Thanks for all of the comments guys ;-)
I said to myself, why on earth shouldn't I try another switch that i don't know :) I went with MX Browns :)
I made a quick auciton search and found QFR Ultimate with MX Browns, and bought it immediately ^^
Here it is, next to new mouse fitting the theme :)
Took it to work, cause I wanted to test the switches with long typing. I must say that I fell in love with MX Browns ^^
Cause getting one in Poland is a miracle ;p I found mine and didn't see one in here again :P
To all of you wanting to switch to MX from ALPS - Go for it :) My friend bought G80-1800 with Blacks, I use MX Browns and i must say that these switches do not differ greately in terms of strenght from what ALPS have to offer :)
Thanks again to all of you :) And now, it is time to spend money on some caps xD
Offline Flyersfan1
  • Hi!
« Reply #14 on: Fri, 22 November 2013, 18:45:15 »
I really like that wrist rest.
Quote from: Photekq
Offline terran5992
  • One With The Cup Rubber
« Reply #15 on: Fri, 22 November 2013, 21:29:49 »
Good choice. Browns are excellent for typing
Offline Tony
« Reply #16 on: Sat, 23 November 2013, 04:53:28 »
Good decision. Brown is always a safe bet, and I prefer brown at work and at home.
Coming from Dell AT101w, you have to learn to type lighter with the right force, just enough to register. I mean, your fingers can dance on the keyboards instead of punching the keys.
