Author Topic: Would you rather?  (Read 9999 times)
Offline Fragil1ty
  • Abre los ojos.
Would you rather?
« on: Mon, 30 September 2013, 14:48:50 »
Have a board that works perfectly but it's your least favourite keyswitch, e.g. Blacks?
or
Have a board that has your favourite keyswitch (browns, reds?) but! it has issues, maybe a faulty wire or slight chattering/key bouncing issues!
The rules are, you cannot change your cable and you cannot fix the chattering issue.
Chattering occurs on a 45% chance and the faulty wire makes it so that your keyboard randomly disconnects!
Your keyboard only has one of these issues so it's either going to be the faulty keyboard wire or the chattering issue! choose wisely.
Which do you choose and why?
Disclaimer: This is purely a study that I want to enquire about. My friend and I were curious as he did a study in University asking 'Even if your keyboard would break in x way and x way but was still usable would you buy a new one or carry on using it til it finally gives out, etc, etc.'
« Last Edit: Mon, 30 September 2013, 14:56:16 by Fragil1ty »
你搞砸了
Re: Would you rather?
« Reply #1 on: Mon, 30 September 2013, 14:49:45 »
The keyboard that works
  • Live long and prosper
« Reply #2 on: Mon, 30 September 2013, 14:54:08 »
I'd rather have a board with MX Blues and a faulty cable. Why? Because that's what I deal with on a daily basis with my QFR. The cable has a connection issue, so if I accidentally move the keyboard it disconnects and I have to re-seat the cable in the mini-USB port.
But it's still better than typing on Blacks...
tp thread is tp thread
« Reply #3 on: Mon, 30 September 2013, 14:54:47 »
Working keyboard for sure. I'd rather get used to a switch I don't like than be frustrated with something that half works, i.e. chatters.
Offline CommunistWitchDr
  • >implying keyboards
« Reply #4 on: Mon, 30 September 2013, 14:55:56 »
or
We talkin least favorite switch, or least favorite mechanical switch (maybe even least favorite mx?)? Cause it makes quite a bit of difference if I'm getting a board with browns or one with microwave button style switches.
« Reply #5 on: Mon, 30 September 2013, 15:10:13 »
Pls green ALPS with chattering. Would be the same as I've got right now.
Offline saturnotaku
« Reply #6 on: Mon, 30 September 2013, 15:16:07 »
I'd take option C: Contact the manufacturer of the keyboard with the faulty cable (or the reseller if I can't get a hold of the company) and see if I can get a replacement. Failing that, I save my money and purchase a replacement board that has the switches I like.
If it's only between the options presented, I would probably suck it up and use the functional board with the switch I hate. I could eventually grow accustomed to the new switch whereas something I know is defective would drive me up a wall.
Offline ch_123
« Reply #7 on: Mon, 30 September 2013, 15:23:44 »
The working one. Life is too short...
Offline Lu_e
« Reply #8 on: Mon, 30 September 2013, 15:28:18 »
Working one.
Kinda just wen through this when RMA my QFR. faulty left alt key had me back on a razer black widow blues... ew clicky switches :p
Just say NO to ABS keycaps
« Reply #9 on: Mon, 30 September 2013, 16:35:56 »
y'all have no sense of adventure.
I'd pick the broken one, because it's much more fun to fix it. I have "typed" using a software keyboard whilst debugging the only keyboard I had at the time. I eventually got it working, and everything was (is) awesome because of it.
« Reply #10 on: Mon, 30 September 2013, 16:38:10 »
OP says no fixing. Or else I'd happily fix mine up.
« Reply #11 on: Mon, 30 September 2013, 18:37:32 »
these studies are useless.. because any rational person would say ffff-you and ur experiment, then proceed to buy an Ergodox.
« Reply #12 on: Mon, 30 September 2013, 18:55:24 »
What kind of question is that - the working one, of course!
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #13 on: Mon, 30 September 2013, 18:58:41 »
I would type on blacks they are too heavy to me. I love browns and reds. I would rather get used to switches.
Offline Pacifist
  • on hiatus
« Reply #14 on: Mon, 30 September 2013, 19:02:21 »
or
I'd think microwave buttons would fit both categories, as they are unresponsive as hell
Offline Ch0nG
« Reply #15 on: Mon, 30 September 2013, 19:26:20 »
If the OPs options are the only ones, I'd say the working keyboard even if it's the "worst" Cherry MX switches. I can get used to any switch, but it's almost impossible to get used to a faulty cable (which is what my DasKeyboard currently has).
Das Ultimate - Blues - Converted to removable USB (Mimic-Cables) - 40 A-L WASD ORings
ErgoDox - ErgoClears ErgoDox - 65g Blues
Offline Dubsgalore
« Reply #16 on: Mon, 30 September 2013, 19:27:13 »
The Working one..no question
Even if it had the worst switches known to man...reds *hngg*
Offline C5Allroad
« Reply #17 on: Mon, 30 September 2013, 20:09:45 »
or
Some are actually nice buttons.... Mine are pretty good lol.
Offline FoxWolf1
  • 154
« Reply #18 on: Mon, 30 September 2013, 20:16:31 »
If I follow the implied guidelines suggested by your examples, than I would say that I'd go for the working keyboard. The non-working one would drive me crazy. If I can't fix the problem, I'll sooner destroy the keyboard attempting to do so than I would accept living with the problem.
I should note, though, that this answer depends on certain boundary assumptions...that is, when you say "least favorite keyswitch" that you are only considering switches that, at the current time, are common in mechanical keyboards. If "least favorite keyswitch" includes every switch ever made by any modder or company at any time in history based on any kind of technology, I might be persuaded to reconsider.
Offline divito
« Reply #19 on: Mon, 30 September 2013, 20:38:21 »
When thought hypothetically, it would seem obvious to have a fully working keyboard with my least favorite key switch. However, when trying to really put myself in that situation, the severity of the intermittent issues and such could be liveable with the the desired key switch.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline zoolzoo
« Reply #20 on: Mon, 30 September 2013, 20:42:24 »
Ergotrash!!!
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline Linkbane
« Reply #21 on: Mon, 30 September 2013, 20:53:26 »
I'd take the non-working one and then take the switches out and swap them with my new board. MX Blues/possibly Topre VW, here I come!
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline BliTzKiN
« Reply #22 on: Mon, 30 September 2013, 21:00:03 »
I'd probably take the working one and try to get used to it. I cant see myself having to constantly fiddle with a cable, it'll drive me nuts!
Offline Reomero
  • Manual breather
« Reply #23 on: Mon, 30 September 2013, 21:02:21 »
I'll take the working one. The one with issues will be too irritating for me on the long run.
« Reply #24 on: Mon, 30 September 2013, 22:38:00 »
And why is this in keyboards, and not off topic?
Offline genkidama
« Reply #25 on: Tue, 01 October 2013, 04:12:45 »
I'd take the working keyboard and get used to the black switches, althought I already tried and hate them. It's much less of a worry and frustration than having a keyboard that's faulty, disconnects randomly and stuff like that. This would drive you crazy and with the black switches you just need to suck it up and get used to it and get Arnold Schwarzenegger (in his better and younger days) hands and you got no problems anymore. :D
My finger training is over 9000!!!!
Offline Fragil1ty
  • Abre los ojos.
« Reply #26 on: Tue, 01 October 2013, 07:05:37 »
I thought this applies to keyboards? If not, I have no problems with a Moderator moving it to that section, :).
你搞砸了
« Reply #27 on: Tue, 01 October 2013, 08:46:05 »
My answer remains: I'm putting up with useless firmware on one keyboard: kmac, and I have an odd debounce issue with my phantom. These are the keyboards I use the most. If I wanted a working keyboard, I'd use my QFR or model M more.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #28 on: Tue, 01 October 2013, 09:04:48 »
I guess it is a keyboard related question, sorta lol.
And I'd take the working keyboard, if I were to use a keyboard with problems (chatter, non-register keys) I'd rather just use a working generic rubber dome.
In general even the worst mechanical *might* still be better than rubber dome therefore I'd take the working one.  :)
« Reply #29 on: Tue, 01 October 2013, 18:00:06 »
It is more a hypothetical question about personal preference rather than discussion about an actual keyboard.
But anyway.
« Reply #30 on: Tue, 14 October 2014, 12:21:13 »
Would you rather lose an arm or a leg?
edit: woops, this isn't an off-topic post  :-[
« Reply #31 on: Tue, 14 October 2014, 12:28:31 »
dat necro :eek:
« Reply #32 on: Tue, 14 October 2014, 12:53:29 »
dat necro :eek:
I was thinking about the question and couldn't decide, so I wanted to see what other people would choose. Thank you based GH search
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #33 on: Tue, 14 October 2014, 12:54:16 »
A keyboard that works is useless if I'd have to type on blacks or browns. I'd take a faulty one anyday
edit: oh wow yeah sweet necro
Offline Premonition
  • HHKB Elite
« Reply #34 on: Tue, 14 October 2014, 13:02:28 »
Obviously the working one, you sell it to someone and buy a keyboard you actually like. My 'least favorite switch' just so happens to be on the Kishsaver Model F..  ;)
« Last Edit: Wed, 15 October 2014, 20:38:38 by Premonition »
Offline heedpantsnow
  • Old enough to know better
« Reply #35 on: Tue, 14 October 2014, 13:06:38 »
I would rather have the working board and both arms but one leg over the board with issues and two legs but only one arm.
I'm back.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #36 on: Tue, 14 October 2014, 13:19:26 »
I would rather have the working keyboard with my least favorite switches because I don't find any MX switches unbearable.
Offline johndavis33
« Reply #37 on: Tue, 14 October 2014, 17:36:49 »
I'd probably take the one with my least favorite switches.
I could use it occasionally to remind myself of why I hate it. Even if I never use it, it's nice to have variety in your collection.
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
Offline user 18
« Reply #38 on: Tue, 14 October 2014, 17:53:22 »
What kind of 'worst mechanical switch' are we talking here?
If it's Fujitsu peerless, I'm going with the board with the bad cable, because I know how to work with bad cables.
If it's MX Black, that would be a really hard choice. I love stiff switches (MX Clear, Green, etc.) but hate blacks for whatever reason. Probably still the board with the bad cable.
As said above, neither situation is really realistic. You use what you have until it becomes unusable, then you get something else that works for you. Worst case, you get a same-layout board with the terrible switches and swap the switches across. I assume you didn't immediately dumpster your broken board :P
Avatar by ashdenej
Offline Kisuaca
« Reply #39 on: Tue, 14 October 2014, 19:24:09 »
I would by topre 55g
Offline FrostyToast
  • Litshoard
« Reply #40 on: Tue, 14 October 2014, 19:43:09 »
I could flip a working board in a trade  :p
Quote from: elton5354
Offline eth0s
  • Peace & Love
« Reply #41 on: Tue, 14 October 2014, 20:09:25 »
I would get a Topre keyboard.  No mechanical chattering.  EVAR.  Due to superior electro-capacitive switching technology.  Be a part of the future, not a slave to the past.
Would you rather?
« Reply #42 on: Tue, 14 October 2014, 20:23:03 »
Yep I've never had a rubber dome chatter either!
« Last Edit: Tue, 14 October 2014, 21:17:56 by heedpantsnow »
I'm back.
Offline Drewchompski
« Reply #43 on: Tue, 14 October 2014, 21:18:28 »
Working.
Cant stand dealing with half broken stuff.
Offline Rebral
« Reply #44 on: Tue, 14 October 2014, 21:31:21 »
Working keyboard with least favorite switch.
I'd have to go with light switches (reds/blues). NOT that I hate them, but I'm a heavy typist and I prefer a heavier switch.
Offline Tony
« Reply #45 on: Tue, 14 October 2014, 22:37:06 »
Depends on the price. Usually I choose the working one, but if I could get the broken one for free, then I might reconsider.
Offline Oobly
« Reply #46 on: Wed, 15 October 2014, 04:55:49 »
Neither. I'd buy a working board with my favourite switch rather than settling for something either broken or horrible to use. Actually I'd use the one with the broken cable and replace the cable... You can't tell me I'm not allowed to fix stuff, fixing stuff is what I do.
If I used it for only a short time, though, I could settle for the working one. I'd get too frustrated using the one with chattering or cable issues, particularly knowing that it can be fixed... would just irritate me beyond belief.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline genkidama
« Reply #47 on: Wed, 15 October 2014, 12:32:20 »
But you need to chose one of the two without fixing. You are not allowed to fix stuff :p
Offline exitfire401
  • The Force is Re/\l
« Reply #48 on: Wed, 15 October 2014, 12:35:18 »
Board that works with least favorite switch (in my case reds). My reasoning is that I make enough errors on my own while typing, and chatter would just further the issue while writing a paper for school. I also need the reliability for gaming.
Offline ksm123
« Reply #49 on: Wed, 15 October 2014, 12:39:55 »
You mean at work?
If there was no possible way to get to the keyboard with solder iron, cleaning agent and lubricant then I would choose working one, even if it was rubber dome.
I do not have enough patience to code on chattering board.
