Author Topic: CM Storm trigger - keycrap  (Read 9062 times)
Offline BucklingSpring
« on: Sat, 19 October 2013, 16:45:07 »
Hi guys,
Just wanted to show what my CM Storm trigger spacebar looks after about 6 months of use.
39915-0
Waow... Grayish plastic already showing under the thin black paint.
It's a first for me. None of the black boards in my sig has displayed such a cheap behavior. Not even my TVS Gold.
« Last Edit: Sat, 19 October 2013, 16:49:30 by BucklingSpring »
Boards I own, click ->
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
Re: CM Storm trigger - keycrap
« Reply #1 on: Sat, 19 October 2013, 17:04:52 »
Hi guys,
Its evolving!  :p
« Reply #2 on: Sat, 19 October 2013, 17:16:18 »
well, the trigger caps are translucent caps with a black coating...
So it has a weak coating.
« Reply #3 on: Sat, 19 October 2013, 18:47:04 »
ROFL you mean it's going to shed a skin and turn into a big translucent snake?
I'm going to have nightmares.  :eek:
Its evolving!  :p
« Last Edit: Sat, 19 October 2013, 18:51:43 by BucklingSpring »
« Reply #4 on: Sat, 19 October 2013, 18:50:57 »
Right... So does my iOne/XArmor POS and although its keycaps turned shiny real quick. The coating was still holding after 6months.
« Reply #5 on: Sat, 19 October 2013, 19:26:01 »
The space bar might be under different stresses than the rest of the keys.  Mine usually shine at about the exact point, but slightly more on top.  if you press the space with your thumb sliding slightly, it would speed up the coating removal, as opposed to most of the keys where you would just press the key straight down.
Offline Linkbane
« Reply #6 on: Sat, 19 October 2013, 19:41:21 »
Hi guys,
My god, what do you do with your keyboard?  :eek:
I've used my TK for six months, and they have no dirt or wear on them besides some stuff on the plate (which I suppose I'll clean for the first time today).
Perhaps the Trigger uses cheaper keycaps. I ended up swapping my spacebar for the one on a Corsair K60, because it happens to be the same size, I think it's a 6.5x, and that one's much better so there haven't ben issues.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #7 on: Sat, 19 October 2013, 20:00:41 »
Hell no it doesn't.
Hi guys,
That's not really normal, I've had mine for almost a year and the only key that has some kind of failure is the right arrow (kinda weird, since I almost never use it), but if you find CM Storm Trigger keycaps bad, don't even dare getting a CM Quick Fire TK/Razer Blackwidow Ultimate 2013/Corsair K70 or K95/*Insert Gaming Keyboard here*.
Here's a comparison between a Logitech G710+, Tt Meka G-Unit, Metadot Das Keyboard Model S Professional (Costar), Corsair K70 and CM Storm Trigger keycaps:
Anyways, if you find them bad, go straight for a Déck Legend or ofc, a good nonbacklit keyboard, always prefered those myself as well  :p
« Last Edit: Sat, 19 October 2013, 20:02:26 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
« Reply #8 on: Sat, 19 October 2013, 20:12:44 »
Might have been a bad batch of keycaps - thinner coating or something.
Offline PadawanGeek
« Reply #9 on: Sat, 19 October 2013, 22:15:34 »
I agree, the Trigger has one of the absolute worst key caps I've ever had the misfortune of buying. I'd gotten a used Trigger (wanted it as it has MX Green switches), was told it was in 'perfect' condition but when I'd taken possession of it, I was thoroughly disappointed with the condition of the WASD and space bar.....the space bar on mine look like it had similar wear like those of the TS/OP. I've always said that CM should take a look into this, absolutely unacceptable quality from them. Anyway, I'd replaced the WASD and space bar since I use it mainly for gaming, and these keys see the most wear...
« Reply #10 on: Sun, 20 October 2013, 11:28:37 »
I don't do anything special. As for the dust, it's really not that bad. The lightning for the picture was from the side and it really makes it look worst than it is.
« Reply #11 on: Sun, 20 October 2013, 11:45:21 »
*Insert Gaming Keyboards here* Yeah I know. I originally picked the CM QFR with Green cause it was what I thought the best option out there for Green at the time.
I ended up with a QFR with many defective non clicky Greens. The story turned into a Customer Service nightmare after countless back and forth, CM finally replaced the QFR Green with a Storm Trigger with Greens because they were going to be out of stock for a while.
Try (more) on my sig... You'll see that I already own 2 Decks. Trust me, if they were making Legend with Greens, I would have never go the CM route.
I whish Deck were selling keysets... Anyway as for the CM Storm Trigger, CM could have used black plastic for its spacebar since there is no fonts to light up on it, thus no need to use a coated translucent key.
« Last Edit: Sun, 20 October 2013, 11:49:43 by BucklingSpring »
Offline wetto
« Reply #12 on: Sun, 20 October 2013, 11:56:56 »
Yeah, I saw your signature only later. I also wish Déck had more switch choices (and especially, font choices, for god's sake, the only company that does a backlit keyboard with a font that doesn't looks bad is Corsair).
Anyways, unfortunately that happens on other backlit keyboards as well, they probably just can't use other kinds of keycaps on the keyboard... :(
My collection:
Offline gigibecali
« Reply #13 on: Sun, 20 October 2013, 19:12:19 »
I still don't understand what people expect from coated caps.
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
« Reply #14 on: Sun, 20 October 2013, 21:23:51 »
I guess once you get burnt once, you know what to expect.
I now like the [insert gaming keyboard]=[Junk keycap] rule of thumb.
Of course with the exception of Deck's where they search and replace "Junk" by "ugly"
« Last Edit: Sun, 20 October 2013, 21:25:34 by BucklingSpring »
Offline PrisonSex
« Reply #15 on: Mon, 21 October 2013, 01:57:49 »
I think your best bet is replacing the keys with higher quality caps, but most of the higher quality caps aren't back light friendly.
Offline Signature
  • master of puppers
  • snoozing
« Reply #16 on: Mon, 21 October 2013, 02:21:22 »
Its evolving!  :p
And thats only the first part of the evolve  :confused:
Offline wetto
« Reply #17 on: Mon, 21 October 2013, 02:24:02 »
Ducky Shine keycaps sets are 100% compatible:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=228
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=229
My collection:
« Reply #18 on: Mon, 21 October 2013, 17:22:16 »
As I wrote on one of the reply. The spacebar on the CM Trigger is not backlit so I wouldn't care if it is not backlit friendly.
« Reply #19 on: Mon, 21 October 2013, 17:26:39 »
Thanks I'll think of it. I don't own any Ducky yet. Are these keycaps any better than the CoolerMaster?
I don't feel to spend $40 + shipping just to get 4 quarters for a dollar.
Offline perche
« Reply #20 on: Sun, 01 June 2014, 10:53:54 »
a,s and d
L, m and n
the rubber coat
after 3 moth
http://imgur.com/a/qu9oZ#4
after 1 year.
btw i send a mail to cm support with this pictures and they send me a new wrist and new key for change the damaged one.
« Last Edit: Sun, 01 June 2014, 11:05:02 by perche »
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #21 on: Sun, 01 June 2014, 10:58:39 »
Keycaps from the backlit KC boards are good.
Offline perche
« Reply #22 on: Sun, 01 June 2014, 11:08:06 »
yes but my problem is the iso  spanish layout   :(.
